'UNEXPECTED_SECTIONS' error
Wed Jan 24 07:01:01 UTC 2018
On 24/01/18 01:58, xuelin.tian at qkmtech.com wrote:
> When I tried to compile and link my application, an error came up,
> saying,
> ../../../../arm-rtems4.11/bin/ld:
> myapp.elf section `.unexpected_sections' will not fit in region `UNEXPECTED_SECTIONS'
> makefile:50: recipe for target 'myapp.elf' failed
> ../../../../arm-rtems4.11/bin/ld: region `UNEXPECTED_SECTIONS' overflowed by 1048577 bytes
> collect2: error: ld returned 1 exit status
> make: *** [myapp.elf] Error 1
> I didnot define any new sections, so any help here? Thanks.
You use sections which are not covered by the linker command file. Look
in the linker map file to figure out what these sections are and then
find a place for them in your memory map.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
