MIPS with Qemu
Rehab Massoud
rehab.massoud at gmail.com
Thu Jan 4 22:08:36 UTC 2018
Thanks a lot Hesham for your reply.
I'd post the steps here hopefully after it works so that future qemu
newbies, like me now, might find it useful. Now as a start: is it correct
that Redboot is the way to go as a boot loader? (following
http://ecos.sourceware.org/docs-latest/redboot/malta.html) Although it is
ecos based, but still could point to the start address of the rtems image,
right?
Because the steps mentioned in
https://devel.rtems.org/wiki/TBR/UserManual/QemuTutorial does not specify
the architecture of the floppy image, also the file floppy.img.bz2 , when
trying to unzip it I get:
$ bunzip2 floppy.img.bz2
bunzip2: floppy.img.bz2 is not a bzip2 file.
Best regards,
Rehab
On Jan 2, 2018 23:24, "Hesham Almatary" <heshamelmatary at gmail.com> wrote:
> Hi Rehab,
> On Tue, 2 Jan 2018 at 11:26 pm, Rehab Massoud <rehab.massoud at gmail.com>
> wrote:
>> Hi all,
>> as in https://devel.rtems.org/wiki/TBR/UserManual/Simulators
>> Qemu mips/malta - is said to work with -M malta option. But when I tried
>> different variants of qemu-mips, I get either a segmentation fault,
>> architecture does not exist or a non compatible image. Has anyone succeeded
>> to run qemu-mips with rtems can guide me where to start?
> I recently ran RTEMS/malta on QEMU. I guess what’s wrong is that you use
> “qemu-mips” instead of “qemu-system-mips”
>> I wish I could just run a simple application for now (like those
>> mips-linux-gcc compiled executable I can run with qemu-mips-linux-user); or
>> this will not work without a complete bootable machine?
> You need a complete bootable machine. RTEMS applications are linked with
> the whole RTEMS kernel and libs, producing a single bootable image (e.g.
> hello.exe). That’s why you need qemu-system-mips.
>> Any hints are highly appreciated...
>> Thanks in advance and best regards,
>> Rehab
>> users mailing list
>> users at rtems.org
> Hesham
URL: <http://lists.rtems.org/pipermail/users/attachments/20180104/39117f97/attachment-0002.html>
