jffs2 summary problem
bin.wang at qkmtech.com bin.wang at qkmtech.com
Tue Jan 30 06:45:20 UTC 2018
>On 30/01/18 05:16, bin.wang at qkmtech.com wrote:
>> hi everyone
>> now i use jffs2 as my flash filesystem. but the  time  of the scan the
>> device is two long , i find that  someone said that when i set the
>> CONFIG_JFFS2_SUMMARY macro ,the time will reduce too much。
>This looks like a Linux configuration option.
yes , i has view some of the information,jffs2 is ported from linux environment to rtems. but i think the mount time is too long  for me
>> but i did not find the realization of the summary.  i only find the
>> summary.h and no function realization.
>> if i want to use this to reduce the scan time . how should i do ?
>You have to figure out how it works on Linux and how we can enable/port
>this to RTEMS.
because i did not find the realization of this feature in the rtems source code . i just find the header file of the summary.
i think i has no much time to do the port work and also i am not familiar with linux too .
is rtems develop group want to support this feature in jffs2?
thank you very much.
>> i use rtems 4.11.2 and zynq 7000 platform.
>> best wishes
>> ben
>> users mailing list
>> users at rtems.org
>Sebastian Huber, embedded brains GmbH
>Address : Dornierstr. 4, D-82178 Puchheim, Germany
>Phone   : +49 89 189 47 41-16
>Fax     : +49 89 189 47 41-09
>E-Mail  : sebastian.huber at embedded-brains.de
>PGP     : Public key available on request.
>Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
URL: <http://lists.rtems.org/pipermail/users/attachments/20180130/10d3805f/attachment-0002.html>
