rtems-libbsd bpf BIOCSRTIMEOUT behaviour
Nicolas Tsiogkas
lou.nick at gmail.com
Tue Jul 3 10:00:10 UTC 2018
Hi,
So I have done some debugging.
there were 2 issues.
First issue regarding the timer is the way the timeout is calculated. It
requires at least 11 milliseconds of timeout to be able to handle it.
Second issue that I faced is that flags were not passed correctly to the
bpfopen function so the bpf was not opened in read/write mode. That's why
packets were not received.
Attaching a patch.
Thanks for the help!
Cheers,
Niko
On Fri, Jun 29, 2018 at 9:40 AM Nicolas Tsiogkas <lou.nick at gmail.com> wrote:
> Thanks!
> Shouldn't net have some device though since I want to debug the networking
> stack?
> For now I run it with -nographic -serial stdio -serial
> mon:tcp:localhost:12456 -M xilinx-zynq-a9 -net
> nic,model=cadence_gem,macaddr=0e:b0:ba:5e:ba:11 -net
> tap,ifname=tap0,script=no,downscript=no -m 256M -kernel slaveinfo.exe
> I'll check soon and report back. Thanks again!
> Cheers,
> Niko
> On Fri, Jun 29, 2018 at 9:32 AM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> On 29/06/18 09:14, Nicolas Tsiogkas wrote:
>> > I see thanks.
>> > Any idea or documentation on how to do that on qemu? I'm afraid that
>> > my experience is rather limited.
>> > I'm running on qemu 2.10 using the xilinx_zynq_a9_qemu bsp.
>> You can run the xilinx_zynq_a9_qemu with
>> QEMU_AUDIO_DRV=none qemu-system-arm -serial null -serial mon:stdio -net
>> none -nographic -M xilinx-zynq-a9 -m 256M -kernel app.exe -s -S
>> It waits for a GDB client connection on localhost:1234.
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone : +49 89 189 47 41-16
>> Fax : +49 89 189 47 41-09
>> E-Mail : sebastian.huber at embedded-brains.de
>> PGP : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
URL: <http://lists.rtems.org/pipermail/users/attachments/20180703/2a68b71f/attachment.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20180703/2a68b71f/attachment.bin>
