rsb
Joel Sherrill
joel at rtems.org
Fri Jul 6 19:28:49 UTC 2018
On Fri, Jul 6, 2018 at 2:24 PM, Siddons, David <siddons at bnl.gov> wrote:
> I looked at the Github site, got to the 4.11 branch, and the window had an
> https link for cloning. THat seems to have worked:
> git clone https://github.com/RTEMS/rtems-source-builder.git rsb
Weird. I would expect both to work from home. Even a new home router
wouldn't
get in the way of something like that.
> More as I continue 😊
Weird that you are at home and having trouble. That's usually where
everything works. :(
On an odd note, I had an 8-port switch die in my house this week. Was the
last
thing I expected to have broken. Got a new one and then my son plugged both
ends of a cable into the new switch and the network here suffered greatly.
In
the end, we found a number of cables that weren't needed anymore but we
had never untangled them to remove them.
Also installed an access point attached to the far end of the wired network
and that has helped some of the weak signal points.
> Pete.
> *From:* users <users-bounces at rtems.org> on behalf of Siddons, David <
> siddons at bnl.gov>
> *Sent:* Friday, July 6, 2018 3:14:13 PM
> *To:* joel at rtems.org
> *Cc:* rtems-users at rtems.org
> *Subject:* Re: rsb
> Hi Joel,
> I'm doing this from home, so not going through the BNL firewall. It has
> worked in the past, but not for the last few weeks. I made an attempt a
> while back and had partial success, then cleaned everything out and started
> again, with this result. I thought maybe something was in transition, so I
> waited until now to try again.
> Pete.
> *From:* Joel Sherrill <joel at rtems.org>
> *Sent:* Friday, July 6, 2018 3:08:52 PM
> *To:* Siddons, David
> *Subject:* Re: rsb
> On Fri, Jul 6, 2018, 2:06 PM Siddons, David <siddons at bnl.gov> wrote:
> Hi Joel,
> No it doesn't. Is it possible there's something wrong with my git
> installation?
> Any chance bnl has blocked git?
> I doubt it is something on your computer. There is supposed to be a way to
> fetch git via https which would get around firewall issues.
> Pete.
> *Sent:* Friday, July 6, 2018 2:59 PM
> *Cc:* users at rtems.org
> *Subject:* Re: rsb
> Hi
> By any chance does it work for you now? At least one of the servers
> was being bombarded yesterday and ran out of disk space with logs.
> This worked for me today with no hiccups.
> --joel
> On Fri, Jul 6, 2018 at 1:41 PM, Siddons, David <siddons at bnl.gov> wrote:
> I just tried again to clone rsb:
> ~/development/rtems$ git clone git://git.rtems.org/rtems-
> Cloning into 'rsb'...
> fatal: repository 'https://git.rtems.org//rtems-source-builder.git/' not
> found
> Looking at the contents of this link gets:
> No repositories found
> I found this same clone command in various places throughout the RTEMS
> documentation. Am I doing something wrong?
> Pete.
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20180706/fbc8e536/attachment.html>
