4.11 RSB was Re: rsb
Fri Jul 13 12:53:10 UTC 2018
On Sat, Jul 7, 2018 at 4:10 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 8/7/18 3:47 am, Joel Sherrill wrote:
>> Chris.. hoping you see this..
> Just now, I am back in NZ for the week.
>> I started a test of 4.10 before the server was shut down to be moved
>> to OAR's new location yesterday but not 4.11.
>> On Fri, Jul 6, 2018 at 7:07 PM, Siddons, David <siddons at bnl.gov
>> <mailto:siddons at bnl.gov>> wrote:
>>     The RSB installed OK. I tried to then get the 4.11 branch, assuming that was
>>     the latest released branch. However, it couldn't find it:
>>     ../source-builder/sb-set-builder --prefix=/home/peter/development/rtems/4.11
>>     4.11/rtems-arm
>>     bash: ../source-builder/sb-set-builder: No such file or directory
> It is hard to say without seeing all the shell output, for example what $PWD is.
>>     Changing 4.11 to 5 resulted in a good build. So what happened to 4.11?
> I had a quick look at 5 and I cannot see http in the git source path ..
> https://git.rtems.org/rtems-source-builder/tree/rtems/config/tools/rtems-kernel-4-1.cfg#n84
> ... so I am finding the http in the git URL confusing. I am not sure what else I
> can without more information.
>>     Do I now have to install the kernel source by hand, and build it like in the
>>     old style? I couldn't see it anywhere in the resultant tree.
> Building the kernel should work. It is now not enabled by default in releases
> which is a change.
I addressed other issues in my email to OP, but I should clarify, this
should work by using --with-rtems option to RSB. I don't remember, by
default I think this builds all the BSPs for the architecture(s)
enabled for the build.
> For 4.11 I suggest you try a release ..
>  https://ftp.rtems.org/pub/rtems/releases/4.11/4.11.3/
> Chris
> users mailing list
> users at rtems.org
