IMFS on ram-disk
Ian Caddy
ianc at goanna.iinet.net.au
Tue Jul 24 09:19:02 UTC 2018
Hi Udit,
While I am not familiar with your exact setup, we had issues with larger
files on the IMFS using RTEMS4.10.
We discovered that there is a default max size of an IMFS file which is
around 4.3MBytes.
It can be changed by changing the bytes per block in the CONFDEFS:
/* IMFS file system block size increase to make max file size
68,173,568, instead of 4,329,344 */
#define CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK 256
We performed this update to increase the maximum file size as shown above.
Hope this helps.
regards,
Ian Caddy
On 24/07/2018 4:48 PM, Udit agarwal wrote:
> Hi all,
> I've been trying to use IMFS with a ramdisk on BBB. Here's what i did:
> After creating a ram disk (block size:512, block count:262144), i used
> mount_and_make_target_path("/dev/rda","/mnt",RTEMS_FILESYSTEM_TYPE_IMFS,RTEMS_FILESYSTEM_READ_WRITE,NULL)
> There is no error during bootup, but when allocating a file(in the
> /mnt directory) of size 10MB(or even of 1MB) it gives a file too large
> error.
> I've used similar config for RFS too and that did worked, so probably
> there's no issue while setting up the RAM disk.
> I've also tried testsuite/fstests/imfs_support setup, but looks like
> similar method doesn't work with ram-disks
> Regards,
> Udit kumar agarwal
> http://uditagarwal.in/
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20180724/f0734496/attachment.html>
