MIDAS rtems Port
Joel Sherrill
joel at rtems.org
Wed Jul 25 22:33:37 UTC 2018
On Wed, Jul 25, 2018 at 12:40 PM, Konstantin Olchanski <olchansk at triumf.ca>
wrote:
> On Wed, Jul 25, 2018 at 09:54:41AM -0500, Joel Sherrill wrote:
> > This can work on qemu as well. I would recommend the arm zynq BSP variant
> > for
> > qemu. That should be the easiest way to test and it would work without
> > dedicated
> > HW for RTEMS. Just a simulator on Linux talking to whatever MIDAS has on
> > the Linux host.
> > Feel to ask questions on our mailing list. But you have to be subscribed
> > for the message to go through.
> > And asking there for advice on setting up qemu/zynq with network is a
> good
> > thing for the list. I am sure someone is better than I am at helping you
> on
> > that specific topic.
> Thank you for your information. Somehow what you have just is not the
> direction
> of things we do locally at TRIUMF - for ARM processor based machines
> we buy kits like RaspberryPi that run straight linux. Then for FPGA based
> devices,
> it is either straight FPGA (no CPU, cannot run MIDAS) or NIOS2 synthetic
> CPU (usually
> not enough on-FPGA and external RAM to run MIDAS, with any OS), or have an
> FPGA with
> built-in ARM CPU (Cyclone 5 SoC, etc), which again run straight linux.
You can run RTEMS on the Raspberry Pi also. My suggestion was just to
make things easier to debug without spending any money on any hardware.
RTEMS supports the NIOS2 and ARM Zynq.
> But for general MIDAS use, it is good health to have non-Linux, non-UNIX
> ports,
> keeps the hardware and os abstraction layers honest.
Similarly, RTEMS currently has 15+ processor architectures and ~175 BSPs.
We have probably removed that many or more over the years.
--joel
> K.O.
> > --joel
> > > Regards
> > > Lee
> > >> K.O.
> > >> On Fri, Jun 08, 2018 at 10:48:06AM +0200, Lee Pool wrote:
> > >>> Hi,
> > >>> So I finally got around to "publish" work I did in 2009/2010 with
> RTEMS.
> > >>> The work was mainly between myself and Till Straumann (SLAC), and
> > >>> Dr. Joel Sherill, to get VME support for vme universe/vme tsi148 (
> > >>> basic support ), into the i386 bsp.
> > >>> From there I "ported", which wasn't difficult, MIDAS :
> > >>> https://bitbucket.org/tmidas/midas/src/develop/
> > >>> to
> > >>> https://bitbucket.org/lcpool2/midas-k600/src/develop/ ( our rtems
> port
> > >>> What this did was to allow us to run our various VME single board
> > >>> controllers, with a single frontend application.
> > >>> It is still classified testing but its been very successful, so
> > >>> far, and I hope to use it in the next experiment, if possible.
> > >>> The midas port, contains a makefile, and some changes to the
> > >>> midas.c/system.c/mfe.c files. I've not tested the full
> > >>> functionality
> > >>> as I'm super time limited.
> > >>> Hope this is help full to others...
> > >>> Regards
> > >>> Lee
> > >> _______________________________________________
> > > users mailing list
> > > users at rtems.org
> > > http://lists.rtems.org/mailman/listinfo/users
> Data Acquisition Systems: The Bytes Must Flow!
> Email: olchansk-at-triumf-dot-ca
> Snail mail: 4004 Wesbrook Mall, TRIUMF, Vancouver, B.C., V6T 2A3, Canada
URL: <http://lists.rtems.org/pipermail/users/attachments/20180725/2b26b92d/attachment.html>
