MVME3100 FPU Support on RTEMS 4.10.2
Joel Sherrill
joel at rtems.org
Wed Jun 6 22:00:51 UTC 2018
On Wed, Jun 6, 2018, 4:29 PM Michael Davidsaver <mdavidsaver at gmail.com>
wrote:
> On 06/06/2018 02:24 PM, Matt Rippa wrote:
> > Thanks for the fast reply. Of all the mvme boards you listed,
> > the 3100 hits a nice price point and we're attempting to find
> > suitable replacement stock
> > (quantity 30+)
> > for the 2700 which are no longer
> > manufactured.
> Last I checked (~5 years ago) the newer mvme2500 had a price similar to
> the mvme3100.
> The issue was software support. At the time there didn't seem to be RTEMS
> board
> support
I would expect the mvme2500 to just one of the many variants supported by
the motorola_powerpc BSP family. Some of the board variants, you could just
use another variant name. I don't know if this would require tweaks or not.
What about the mvme5500? It wasn't mentioned by anyone. Is that a price
issue?
I suppose spinning off Motorola Computing Group and the processor group has
resulted in few upgrade options.
> > Are the 6100 boards on beatnik bsp the only remaining option for RTEMS?
> > They cost nearly twice as much and have
> > shown
> > thermal regulation issues.
> > -Matt
> > On Wed, Jun 6, 2018 at 11:10 AM, Michael Davidsaver <
> mdavidsaver at ospreydcs.com <mailto:mdavidsaver at ospreydcs.com>> wrote:
> > Hi Matt,
> > The MVME3100 is based on the MPC8540 processor. This chip doesn't
> have an FPU.
> > Other boards do (eg. mvme270x, mvme6100, or mvme2500) and RTEMS
> supports this.
> > I can certainly confirm that lack of an FPU really hurts
> performance, even
> > something as (apparently) simple as integer to float.
> > Michael
> > On 06/06/2018 02:03 PM, Matt Rippa wrote:
> > > It appears we've compiled our mvme3100 bsp without FPU support.
> > > We're on the mvme3100 running EPICS 3.14.12.7 and RTEMS 4.10.2.
> > > We're attempting to commission our astrometric kernel control
> system
> > > and we've run into trouble meeting some of our thread deadlines.
> What
> > > we've found is a transform routine that takes our mvme2700 ~200 us,
> > > takes the mvme3100 ~8 ms. So not a surprise to see this with only
> "-msoft-float"?
> > > 2018-05-31-tcs.log:May 31 11:41:15 E) PORT: tcs_vme, MSG: Welcome
> to rtems-4.10.2(PowerPC/Generic (*no FPU*)/mvme3100)
> > > Is FPU support possible with RTEMS 4.10.2? If so, what would we
> need to do?
> > > It looks like there's a multilib on 4.11.2
> https://docs.rtems.org/releases/rtems-docs-4.11.2/cpu-supplement/powerpc.html#multilibs(*Eg
> https://docs.rtems.org/releases/rtems-docs-4.11.2/cpu-supplement/powerpc.html#multilibs(*Eg>.,
> see #13* )
> > > Here's our bsp specs:
> > > beatnik:
> > > -specs bsp_specs -qrtems -fasm -c -mcpu=7400 -D__ppc_generic
> -DUNIX -O2 -g -g -Wall
> > > (mvme2700) mvme-2307:
> > > -specs bsp_specs -qrtems -fasm -c -mcpu=604 -mmultiple -mstring
> -mstrict-align -meabi -DUNIX -O2 -g -g -Wall
> > > mvme-3100
> > > -specs bsp_specs -qrtems -fasm -c -mcpu=powerpc *-msoft-float*
> -D__ppc_generic -DUNIX -O2 -g -g -Wall
> > > Thank you!
> > > -Matt
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20180606/737cc1f6/attachment-0001.html>
