MVME3100 FPU Support on RTEMS 4.10.2
Heinz Junkes
junkes at fhi-berlin.mpg.de
Thu Jun 7 02:35:20 UTC 2018
There is RTEMS 5 support for the MVME2500 made by Sebastian Huber.
Unfortunately, I have not been able to test it properly with EPICS7.
I will try it after the Epics meeting and will report.
Heinz
> On 6. Jun 2018, at 23:24, Matt Rippa <mrippa at gemini.edu> wrote:
> Thanks for the fast reply. Of all the mvme boards you listed,
> the 3100 hits a nice price point and we're attempting to find
> suitable replacement stock (quantity 30+) for the 2700 which are no longer
> manufactured.
> Are the 6100 boards on beatnik bsp the only remaining option for RTEMS?
> They cost nearly twice as much and have shown thermal regulation issues.
> -Matt
> On Wed, Jun 6, 2018 at 11:10 AM, Michael Davidsaver <mdavidsaver at ospreydcs.com> wrote:
> Hi Matt,
> The MVME3100 is based on the MPC8540 processor. This chip doesn't have an FPU.
> Other boards do (eg. mvme270x, mvme6100, or mvme2500) and RTEMS supports this.
> I can certainly confirm that lack of an FPU really hurts performance, even
> something as (apparently) simple as integer to float.
> Michael
> On 06/06/2018 02:03 PM, Matt Rippa wrote:
> > It appears we've compiled our mvme3100 bsp without FPU support.
> > We're on the mvme3100 running EPICS 3.14.12.7 and RTEMS 4.10.2.
> > We're attempting to commission our astrometric kernel control system
> > and we've run into trouble meeting some of our thread deadlines. What
> > we've found is a transform routine that takes our mvme2700 ~200 us,
> > takes the mvme3100 ~8 ms. So not a surprise to see this with only "-msoft-float"?
> > 2018-05-31-tcs.log:May 31 11:41:15 E) PORT: tcs_vme, MSG: Welcome to rtems-4.10.2(PowerPC/Generic (*no FPU*)/mvme3100)
> > Is FPU support possible with RTEMS 4.10.2? If so, what would we need to do?
> > It looks like there's a multilib on 4.11.2 https://docs.rtems.org/releases/rtems-docs-4.11.2/cpu-supplement/powerpc.html#multilibs(*Eg., see #13* )
> > Here's our bsp specs:
> > beatnik:
> > -specs bsp_specs -qrtems -fasm -c -mcpu=7400 -D__ppc_generic -DUNIX -O2 -g -g -Wall
> > (mvme2700) mvme-2307:
> > -specs bsp_specs -qrtems -fasm -c -mcpu=604 -mmultiple -mstring -mstrict-align -meabi -DUNIX -O2 -g -g -Wall
> > mvme-3100
> > -specs bsp_specs -qrtems -fasm -c -mcpu=powerpc *-msoft-float* -D__ppc_generic -DUNIX -O2 -g -g -Wall
> > Thank you!
> > -Matt
> Das FHI verarbeitet, speichert und loescht Daten im Rahmen seiner
> Geschaeftstaetigkeit gemaess der Datenschutz-Grundverordnung (DSGVO)
> [General Data Protection Regulation (GDPR)] der Europaeischen Union.
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20180607/215a9080/attachment.bin>
