MVME3100 FPU Support on RTEMS 4.10.2
Matt Rippa
mrippa at gemini.edu
Mon Jun 11 21:06:17 UTC 2018
Hi all,
Many of you already know this, but it was new information to me. I did
more research on the MVME2502 (e500v2) and thought some may benefit.
I've learned this does not support subnormal (or denormal) numbers. That
may impact your application, either in performance or worse (as I
understand),
unexpected zero values. Listing [2] section 10.4.2.2 describes the issue.
[1] https://en.wikipedia.org/wiki/Denormal_number
[2] https://www.nxp.com/docs/en/reference-manual/E500CORERM.pdf
[3] https://www.nxp.com/docs/en/reference-manual/e500CORERMAD.pdf
Below is more information on the product line from Artesyn.
-Matt
The traditional IEEE754 Double Precision Floating Point unit can be found
in the following boards:
- MVME55006E-0161R/ MVME55006E-0163R which uses the NXP MCP7457
- MVME61006E-0161R/ MVME61006E-0163R which also uses the NXP MCP7457
- MVME7100-0171-2GF/ MVME7100-0173-2GF which uses the NXP MCP8641D
- MVME8110-01S/ MVME8110-01E which uses the NXP P5020.
The MVME2502 has a double precision floating point but it changed with the
QorIQ processor cores based on the NXP E500V2 processing cores which are
not the IEEE754 format. The MVME2502 may be fine for your application, but
you may want to research the specific NXP pages that cover the processors
to see what is appropriate for you.
On Thu, Jun 7, 2018 at 6:15 PM, Matt Rippa <mrippa at gemini.edu> wrote:
> Hi Andrew,
> Thanks for the info. When I heard RTEMS 5, I was still thinking EPICS
> 3.14.x.
> So thanks for clarifying. I have a better sense of how much work this is.
> It still
> occurs to me that an mvme2500 RTEMS 4.10 option is possible. Sebastian, if
> you see a way forward there, we would be interested.
> I mentioned before that the 2500 is our best path. So now I guess that's
> debatable.
> That's based on price point and a suitable cpu for our applications.
> Browsing the RTEMS BSP list, I see
> the the 5500 as an option. Has anyone used this board on RTEMS with EPICS?
> The 5500 is still offered and manufactured by Artesyn and the price is
> around $4500.
> -Matt
> On Thu, Jun 7, 2018 at 11:52 AM, Andrew Johnson <anj at aps.anl.gov> wrote:
>> Hi Matt,
>> On 06/07/2018 03:20 PM, Matt Rippa wrote:
>> > The 2500 path looks like our best choice. We can still use the
>> > 6100/beatnik and 2700 boards in the mean time.
>> While I agree tentatively about your choosing the 2500, you do need to
>> be aware that Heinz's EPICS support for RTEMS 5 is aimed at EPICS 7 (it
>> hasn't been merged yet), and the switch from RTEMS 4.10 to 5.x is not a
>> minor change from our perspective.
>> The Kernel APIs that our libCom/osi routines call had to be changed from
>> the old RTEMS-native interfaces to the Posix ones of RTEMS-5, so there's
>> quite a difference. We had to make changes to the EPICS build system for
>> it to be possible to have two implementations of the same OS-dependent
>> routines for the two different kernel APIs under the same OS_CLASS
>> (since where possible the RTEMS-5 build should use our standard Posix
>> implementations). We didn't want to introduce a new RTEMS5 OS_CLASS
>> since that would break existing EPICS support modules which should
>> otherwise still work (providing they only call our OSI APIs).
>> It is also not possible to mix RTEMS versions in the same installation
>> of EPICS Base, since EPICS RTEMS builds rely on Makefile configurations
>> and rules from RTEMS' own build system. The RTEMS path and version must
>> be set in the base/configure/os/CONFIG_SITE.Common.RTEMS file and cannot
>> be overridden in a target-specific CONFIG file (because by the time
>> those files get read in we've already read in a lot of RTEMS build
>> configuration data).
>> Sorry, just want you to know...
>> - Andrew
>> Arguing for surveillance because you have nothing to hide is no
>> different than making the claim, "I don't care about freedom of
>> speech because I have nothing to say." -- Edward Snowdon
URL: <http://lists.rtems.org/pipermail/users/attachments/20180611/31340980/attachment.html>
