RISC-V RTEMS Support
Tue Jun 12 13:25:45 UTC 2018
Hello Molock,
we work currently on the SMP support for RISC-V (32-bit and 64-bit). The
aim is to run the tests on Qemu and a FPGA Board with two BOOMv2 processors.
https://devel.rtems.org/ticket/3433
My current task is a tool chain update to include a bug fix for:
https://sourceware.org/bugzilla/show_bug.cgi?id=23244
This fix is necessary to run 64-bit applications in an address rage
above 0x80000000 (SDRAM address in some standard chips). We need also
specialized GCC multilibs for this.
I would like to merge the riscv32 and riscv64 tool chain into one riscv
tool chain. There was some discussion necessary with the RISC-V
maintainers to achieve this.
The overall work should be finished in two to three months.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
