Error building libbsd
Nicolas Tsiogkas
lou.nick at gmail.com
Thu Jun 21 14:19:14 UTC 2018
Hi Joel,
waf-2.0.8 configure --prefix="$sandbox/5"
--rtems-bsps=arm/xilinx_zynq_a9_qemu
has the following output:
Setting top to : /home/niko/sandbox/rtems-libbsd
Setting out to :
/home/niko/sandbox/rtems-libbsd/build
RTEMS Version : 5
Architectures : arm-rtems5
Board Support Package : arm-rtems5-xilinx_zynq_a9_qemu
Show commands : no
Long commands : no
Checking for program 'arm-rtems5-gcc' :
/home/niko/sandbox/5/bin/arm-rtems5-gcc
Checking for program 'arm-rtems5-g++' :
/home/niko/sandbox/5/bin/arm-rtems5-g++
Checking for program 'arm-rtems5-ld' :
/home/niko/sandbox/5/bin/arm-rtems5-ld
Checking for program 'arm-rtems5-ar' :
/home/niko/sandbox/5/bin/arm-rtems5-ar
Checking for program 'arm-rtems5-nm' :
/home/niko/sandbox/5/bin/arm-rtems5-nm
Checking for program 'arm-rtems5-objdump' :
/home/niko/sandbox/5/bin/arm-rtems5-objdump
Checking for program 'arm-rtems5-objcopy' :
/home/niko/sandbox/5/bin/arm-rtems5-objcopy
Checking for program 'arm-rtems5-readelf' :
/home/niko/sandbox/5/bin/arm-rtems5-readelf
Checking for program 'arm-rtems5-strip' :
/home/niko/sandbox/5/bin/arm-rtems5-strip
Checking for program 'rtems-ld' :
/home/niko/sandbox/5/bin/rtems-ld
Checking for program 'rtems-tld' :
/home/niko/sandbox/5/bin/rtems-tld
Checking for program 'rtems-bin2c' :
/home/niko/sandbox/5/bin/rtems-bin2c
Checking for program 'tar' : /bin/tar
Checking for program 'gcc, cc' :
Checking for program 'ar' :
Checking for program 'g++, c++' :
Checking for program 'gas, gcc' :
Compiler version (arm-rtems5-gcc) : 7.3.0 20180125 (RTEMS 5, RSB
8ee4e8cd557c25fca59bb9751751ad4172530958, Newlib 3.0.0)
Checking for RTEMS CPU options header : started
-> processing test results : all ok
Checking for RTEMS_DEBUG : no
Checking for RTEMS_MULTIPROCESSING : no
Checking for RTEMS_NEWLIB : yes
Checking for RTEMS_POSIX_API : yes
Checking for RTEMS_SMP : no
Checking for RTEMS_NETWORKING : no
Checking for RTEMS header : started
Checking for header dlfcn.h : yes
Checking for header rtems/pci.h : yes
Configure variant: :
arm-rtems5-xilinx_zynq_a9_qemu-default
Checking for header rtems/rtems-debugger.h : yes
'configure' finished successfully (0.744s)
Cheers,
Niko
On Thu, Jun 21, 2018 at 4:09 PM Joel Sherrill <joel at rtems.org> wrote:
> On Thu, Jun 21, 2018 at 8:52 AM, Nicolas Tsiogkas <lou.nick at gmail.com>
> wrote:
>> Hi,
>> following the steps described in https://github.com/RTEMS/rtems-libbsd I
>> get an error
>> "Could not create the directory ///h" while trying to build with waf 2.0.8
>> Is it a known problem?
> Not to me.
> What's your configure command and host?
>> I have seen that the installation procedure has changed since 4.11 and
>> now the tools and the bsps are installed in the same prefix, but that
>> shouldn't matter I suppose.
>> Thank you in advance.
>> Regards,
>> Niko
>> users mailing list
>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20180621/b6f84405/attachment.html>
