Error building libbsd
Christian Mauderer list at c-mauderer.de
Thu Jun 21 16:49:08 UTC 2018
Am 21.06.2018 um 16:26 schrieb Nicolas Tsiogkas:
> And apparently I forgot the host.
> It is ubuntu 16.04:
> Linux im-desktop-021 4.13.0-45-generic #50~16.04.1-Ubuntu SMP Wed May 30
> 11:18:27 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
> gcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.9)
> N.
> On Thu, Jun 21, 2018 at 4:19 PM Nicolas Tsiogkas <lou.nick at gmail.com
> <mailto:lou.nick at gmail.com>> wrote:
>     Hi Joel,
>      waf-2.0.8 configure --prefix="$sandbox/5"
>     --rtems-bsps=arm/xilinx_zynq_a9_qemu
>     has the following output:
>     Setting top to                           :
>     /home/niko/sandbox/rtems-libbsd
>     Setting out to                           :
>     /home/niko/sandbox/rtems-libbsd/build
>     RTEMS Version                            : 5
>     Architectures                            : arm-rtems5
>     Board Support Package                    :
>     arm-rtems5-xilinx_zynq_a9_qemu
>     Show commands                            : no
>     Long commands                            : no
>     Checking for program 'arm-rtems5-gcc'    :
>     /home/niko/sandbox/5/bin/arm-rtems5-gcc
>     Checking for program 'arm-rtems5-g++'    :
>     /home/niko/sandbox/5/bin/arm-rtems5-g++
>     Checking for program 'arm-rtems5-ld'     :
>     /home/niko/sandbox/5/bin/arm-rtems5-ld
>     Checking for program 'arm-rtems5-ar'     :
>     /home/niko/sandbox/5/bin/arm-rtems5-ar
>     Checking for program 'arm-rtems5-nm'     :
>     /home/niko/sandbox/5/bin/arm-rtems5-nm
>     Checking for program 'arm-rtems5-objdump' :
>     /home/niko/sandbox/5/bin/arm-rtems5-objdump
>     Checking for program 'arm-rtems5-objcopy' :
>     /home/niko/sandbox/5/bin/arm-rtems5-objcopy
>     Checking for program 'arm-rtems5-readelf' :
>     /home/niko/sandbox/5/bin/arm-rtems5-readelf
>     Checking for program 'arm-rtems5-strip'   :
>     /home/niko/sandbox/5/bin/arm-rtems5-strip
>     Checking for program 'rtems-ld'           :
>     /home/niko/sandbox/5/bin/rtems-ld
>     Checking for program 'rtems-tld'          :
>     /home/niko/sandbox/5/bin/rtems-tld
>     Checking for program 'rtems-bin2c'        :
>     /home/niko/sandbox/5/bin/rtems-bin2c
>     Checking for program 'tar'                : /bin/tar
>     Checking for program 'gcc, cc'            :
>     Checking for program 'ar'                 :
>     Checking for program 'g++, c++'           :
>     Checking for program 'gas, gcc'           :
>     Compiler version (arm-rtems5-gcc)         : 7.3.0 20180125 (RTEMS 5,
>     RSB 8ee4e8cd557c25fca59bb9751751ad4172530958, Newlib 3.0.0)
>     Checking for RTEMS CPU options header     : started
>     -> processing test results                : all ok
>     Checking for RTEMS_DEBUG                  : no
>     Checking for RTEMS_MULTIPROCESSING        : no
>     Checking for RTEMS_NEWLIB                 : yes
>     Checking for RTEMS_POSIX_API              : yes
>     Checking for RTEMS_SMP                    : no
>     Checking for RTEMS_NETWORKING             : no
>     Checking for RTEMS header                 : started
>     Checking for header dlfcn.h               : yes
>     Checking for header rtems/pci.h           : yes
>     Configure variant:                        :
>     arm-rtems5-xilinx_zynq_a9_qemu-default
>     Checking for header rtems/rtems-debugger.h : yes
>     'configure' finished successfully (0.744s)
>     Cheers,
>     Niko
>     On Thu, Jun 21, 2018 at 4:09 PM Joel Sherrill <joel at rtems.org
>     <mailto:joel at rtems.org>> wrote:
>         On Thu, Jun 21, 2018 at 8:52 AM, Nicolas Tsiogkas
>         <lou.nick at gmail.com <mailto:lou.nick at gmail.com>> wrote:
>             Hi,
>             following the steps described
>             in https://github.com/RTEMS/rtems-libbsd I get an error
>             "Could not create the directory ///h" while trying to build
>             with waf 2.0.8
>             Is it a known problem?
>         Not to me.
>         What's your configure command and host?
>             I have seen that the installation procedure has changed
>             since 4.11 and now the tools and the bsps are installed in
>             the same prefix, but that shouldn't matter I suppose.
>             Thank you in advance.
>             Regards,
>             Niko
>             _______________________________________________
>             users mailing list
>             users at rtems.org <mailto:users at rtems.org>
>             http://lists.rtems.org/mailman/listinfo/users
> users mailing list
> users at rtems.org
Hello Nicolas,
I also don't know that problem. The directory that should be created
"///h" looks like there are some variables missing between the slashes.
But I'm not aware of any directory h that should be created somewhere.
- Did you upgrade from a earlier build or do you build in a fresh
checkout? There have been some changes to the build system in the last
months that have lead to incompatible cache files. If it is an old tree,
try to remove `build` and `.lock-waf_*`.
- About when does the problem happen? It seems your configure runs fine.
So I assume that it appears during build or install. Maybe you could
provide some lines of context to the error message?
Best regards
Christian Mauderer
