Error building libbsd
Nicolas Tsiogkas
lou.nick at gmail.com
Fri Jun 22 07:44:07 UTC 2018
Hi Christian,
it is a fresh clone. Although I had a previous build with 4.11 I decided
try from scratch given the changes.
Error is during the build. I'm configuring normally and when I try to waf
it then it fails.
Is there any way to increase the verbosity? I will repeat all the process
from scratch keeping logs so I can send them and try to find the issue.
Thanks for your time!
Regards,
Niko
On Thu, Jun 21, 2018 at 6:49 PM Christian Mauderer <list at c-mauderer.de>
wrote:
> Am 21.06.2018 um 16:26 schrieb Nicolas Tsiogkas:
> > And apparently I forgot the host.
> > It is ubuntu 16.04:
> > Linux im-desktop-021 4.13.0-45-generic #50~16.04.1-Ubuntu SMP Wed May 30
> > 11:18:27 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
> > gcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.9)
> > N.
> > On Thu, Jun 21, 2018 at 4:19 PM Nicolas Tsiogkas <lou.nick at gmail.com
> > <mailto:lou.nick at gmail.com>> wrote:
> > Hi Joel,
> > waf-2.0.8 configure --prefix="$sandbox/5"
> > --rtems-bsps=arm/xilinx_zynq_a9_qemu
> > has the following output:
> > Setting top to :
> > /home/niko/sandbox/rtems-libbsd
> > Setting out to :
> > /home/niko/sandbox/rtems-libbsd/build
> > RTEMS Version : 5
> > Architectures : arm-rtems5
> > Board Support Package :
> > arm-rtems5-xilinx_zynq_a9_qemu
> > Show commands : no
> > Long commands : no
> > Checking for program 'arm-rtems5-gcc' :
> > /home/niko/sandbox/5/bin/arm-rtems5-gcc
> > Checking for program 'arm-rtems5-g++' :
> > /home/niko/sandbox/5/bin/arm-rtems5-g++
> > Checking for program 'arm-rtems5-ld' :
> > /home/niko/sandbox/5/bin/arm-rtems5-ld
> > Checking for program 'arm-rtems5-ar' :
> > /home/niko/sandbox/5/bin/arm-rtems5-ar
> > Checking for program 'arm-rtems5-nm' :
> > /home/niko/sandbox/5/bin/arm-rtems5-nm
> > Checking for program 'arm-rtems5-objdump' :
> > /home/niko/sandbox/5/bin/arm-rtems5-objdump
> > Checking for program 'arm-rtems5-objcopy' :
> > /home/niko/sandbox/5/bin/arm-rtems5-objcopy
> > Checking for program 'arm-rtems5-readelf' :
> > /home/niko/sandbox/5/bin/arm-rtems5-readelf
> > Checking for program 'arm-rtems5-strip' :
> > /home/niko/sandbox/5/bin/arm-rtems5-strip
> > Checking for program 'rtems-ld' :
> > /home/niko/sandbox/5/bin/rtems-ld
> > Checking for program 'rtems-tld' :
> > /home/niko/sandbox/5/bin/rtems-tld
> > Checking for program 'rtems-bin2c' :
> > /home/niko/sandbox/5/bin/rtems-bin2c
> > Checking for program 'tar' : /bin/tar
> > Checking for program 'gcc, cc' :
> > Checking for program 'ar' :
> > Checking for program 'g++, c++' :
> > Checking for program 'gas, gcc' :
> > Compiler version (arm-rtems5-gcc) : 7.3.0 20180125 (RTEMS 5,
> > RSB 8ee4e8cd557c25fca59bb9751751ad4172530958, Newlib 3.0.0)
> > Checking for RTEMS CPU options header : started
> > -> processing test results : all ok
> > Checking for RTEMS_DEBUG : no
> > Checking for RTEMS_MULTIPROCESSING : no
> > Checking for RTEMS_NEWLIB : yes
> > Checking for RTEMS_POSIX_API : yes
> > Checking for RTEMS_SMP : no
> > Checking for RTEMS_NETWORKING : no
> > Checking for RTEMS header : started
> > Checking for header dlfcn.h : yes
> > Checking for header rtems/pci.h : yes
> > Configure variant: :
> > arm-rtems5-xilinx_zynq_a9_qemu-default
> > Checking for header rtems/rtems-debugger.h : yes
> > 'configure' finished successfully (0.744s)
> > Cheers,
> > Niko
> > On Thu, Jun 21, 2018 at 4:09 PM Joel Sherrill <joel at rtems.org
> > <mailto:joel at rtems.org>> wrote:
> > On Thu, Jun 21, 2018 at 8:52 AM, Nicolas Tsiogkas
> > <lou.nick at gmail.com <mailto:lou.nick at gmail.com>> wrote:
> > Hi,
> > following the steps described
> > in https://github.com/RTEMS/rtems-libbsd I get an error
> > "Could not create the directory ///h" while trying to build
> > with waf 2.0.8
> > Is it a known problem?
> > Not to me.
> > What's your configure command and host?
> > I have seen that the installation procedure has changed
> > since 4.11 and now the tools and the bsps are installed in
> > the same prefix, but that shouldn't matter I suppose.
> > Thank you in advance.
> > Regards,
> > Niko
> > users mailing list
> > users at rtems.org <mailto:users at rtems.org>
> > http://lists.rtems.org/mailman/listinfo/users
> > users mailing list
> > users at rtems.org
> Hello Nicolas,
> I also don't know that problem. The directory that should be created
> "///h" looks like there are some variables missing between the slashes.
> But I'm not aware of any directory h that should be created somewhere.
> - Did you upgrade from a earlier build or do you build in a fresh
> checkout? There have been some changes to the build system in the last
> months that have lead to incompatible cache files. If it is an old tree,
> try to remove `build` and `.lock-waf_*`.
> - About when does the problem happen? It seems your configure runs fine.
> So I assume that it appears during build or install. Maybe you could
> provide some lines of context to the error message?
> Best regards
> Christian Mauderer
URL: <http://lists.rtems.org/pipermail/users/attachments/20180622/2a16728b/attachment-0001.html>
