Error building libbsd
Nicolas Tsiogkas
lou.nick at gmail.com
Fri Jun 22 09:21:07 UTC 2018
Hi,
I did the process again with no luck. I am attaching a zip with command
outputs/logs.
Regards,
Niko
On Fri, Jun 22, 2018 at 9:44 AM Nicolas Tsiogkas <lou.nick at gmail.com> wrote:
> Hi Christian,
> it is a fresh clone. Although I had a previous build with 4.11 I decided
> try from scratch given the changes.
> Error is during the build. I'm configuring normally and when I try to waf
> it then it fails.
> Is there any way to increase the verbosity? I will repeat all the process
> from scratch keeping logs so I can send them and try to find the issue.
> Thanks for your time!
> Regards,
> Niko
> On Thu, Jun 21, 2018 at 6:49 PM Christian Mauderer <list at c-mauderer.de>
> wrote:
>> Am 21.06.2018 um 16:26 schrieb Nicolas Tsiogkas:
>> > And apparently I forgot the host.
>> > It is ubuntu 16.04:
>> > Linux im-desktop-021 4.13.0-45-generic #50~16.04.1-Ubuntu SMP Wed May 30
>> > 11:18:27 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
>> > gcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.9)
>> > N.
>> > On Thu, Jun 21, 2018 at 4:19 PM Nicolas Tsiogkas <lou.nick at gmail.com
>> > <mailto:lou.nick at gmail.com>> wrote:
>> > Hi Joel,
>> > waf-2.0.8 configure --prefix="$sandbox/5"
>> > --rtems-bsps=arm/xilinx_zynq_a9_qemu
>> > has the following output:
>> > Setting top to :
>> > /home/niko/sandbox/rtems-libbsd
>> > Setting out to :
>> > /home/niko/sandbox/rtems-libbsd/build
>> > RTEMS Version : 5
>> > Architectures : arm-rtems5
>> > Board Support Package :
>> > arm-rtems5-xilinx_zynq_a9_qemu
>> > Show commands : no
>> > Long commands : no
>> > Checking for program 'arm-rtems5-gcc' :
>> > /home/niko/sandbox/5/bin/arm-rtems5-gcc
>> > Checking for program 'arm-rtems5-g++' :
>> > /home/niko/sandbox/5/bin/arm-rtems5-g++
>> > Checking for program 'arm-rtems5-ld' :
>> > /home/niko/sandbox/5/bin/arm-rtems5-ld
>> > Checking for program 'arm-rtems5-ar' :
>> > /home/niko/sandbox/5/bin/arm-rtems5-ar
>> > Checking for program 'arm-rtems5-nm' :
>> > /home/niko/sandbox/5/bin/arm-rtems5-nm
>> > Checking for program 'arm-rtems5-objdump' :
>> > /home/niko/sandbox/5/bin/arm-rtems5-objdump
>> > Checking for program 'arm-rtems5-objcopy' :
>> > /home/niko/sandbox/5/bin/arm-rtems5-objcopy
>> > Checking for program 'arm-rtems5-readelf' :
>> > /home/niko/sandbox/5/bin/arm-rtems5-readelf
>> > Checking for program 'arm-rtems5-strip' :
>> > /home/niko/sandbox/5/bin/arm-rtems5-strip
>> > Checking for program 'rtems-ld' :
>> > /home/niko/sandbox/5/bin/rtems-ld
>> > Checking for program 'rtems-tld' :
>> > /home/niko/sandbox/5/bin/rtems-tld
>> > Checking for program 'rtems-bin2c' :
>> > /home/niko/sandbox/5/bin/rtems-bin2c
>> > Checking for program 'tar' : /bin/tar
>> > Checking for program 'gcc, cc' :
>> > Checking for program 'ar' :
>> > Checking for program 'g++, c++' :
>> > Checking for program 'gas, gcc' :
>> > Compiler version (arm-rtems5-gcc) : 7.3.0 20180125 (RTEMS 5,
>> > RSB 8ee4e8cd557c25fca59bb9751751ad4172530958, Newlib 3.0.0)
>> > Checking for RTEMS CPU options header : started
>> > -> processing test results : all ok
>> > Checking for RTEMS_DEBUG : no
>> > Checking for RTEMS_MULTIPROCESSING : no
>> > Checking for RTEMS_NEWLIB : yes
>> > Checking for RTEMS_POSIX_API : yes
>> > Checking for RTEMS_SMP : no
>> > Checking for RTEMS_NETWORKING : no
>> > Checking for RTEMS header : started
>> > Checking for header dlfcn.h : yes
>> > Checking for header rtems/pci.h : yes
>> > Configure variant: :
>> > arm-rtems5-xilinx_zynq_a9_qemu-default
>> > Checking for header rtems/rtems-debugger.h : yes
>> > 'configure' finished successfully (0.744s)
>> > Cheers,
>> > Niko
>> > On Thu, Jun 21, 2018 at 4:09 PM Joel Sherrill <joel at rtems.org
>> > <mailto:joel at rtems.org>> wrote:
>> > On Thu, Jun 21, 2018 at 8:52 AM, Nicolas Tsiogkas
>> > <lou.nick at gmail.com <mailto:lou.nick at gmail.com>> wrote:
>> > Hi,
>> > following the steps described
>> > in https://github.com/RTEMS/rtems-libbsd I get an error
>> > "Could not create the directory ///h" while trying to build
>> > with waf 2.0.8
>> > Is it a known problem?
>> > Not to me.
>> > What's your configure command and host?
>> > I have seen that the installation procedure has changed
>> > since 4.11 and now the tools and the bsps are installed in
>> > the same prefix, but that shouldn't matter I suppose.
>> > Thank you in advance.
>> > Regards,
>> > Niko
>> > _______________________________________________
>> > users mailing list
>> > users at rtems.org <mailto:users at rtems.org>
>> > http://lists.rtems.org/mailman/listinfo/users
>> > users mailing list
>> > users at rtems.org
>> Hello Nicolas,
>> I also don't know that problem. The directory that should be created
>> "///h" looks like there are some variables missing between the slashes.
>> But I'm not aware of any directory h that should be created somewhere.
>> - Did you upgrade from a earlier build or do you build in a fresh
>> checkout? There have been some changes to the build system in the last
>> months that have lead to incompatible cache files. If it is an old tree,
>> try to remove `build` and `.lock-waf_*`.
>> - About when does the problem happen? It seems your configure runs fine.
>> So I assume that it appears during build or install. Maybe you could
>> provide some lines of context to the error message?
>> Best regards
>> Christian Mauderer
URL: <http://lists.rtems.org/pipermail/users/attachments/20180622/ba6084e4/attachment-0001.html>
Type: application/zip
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20180622/ba6084e4/attachment-0001.zip>
