Error building libbsd
Nicolas Tsiogkas
lou.nick at gmail.com
Mon Jun 25 08:08:09 UTC 2018
Hi,
sorry for the late reply.
So, the patch didn't do a thing. Got the same print.
But I tried to run waf with python3
python3 /home/niko/.local/bin/waf-2.0.8
and
python3 /home/niko/.local/bin/waf-2.0.8 install
That was successful. From that I can assume that there is some issue with
the python2 shipped with ubuntu? I can try at home as well in case there is
something specific with the python configuration on my current pc and
report back.
Thanks for the help.
Regards,
Niko
On Fri, Jun 22, 2018 at 9:56 PM Christian Mauderer <list at c-mauderer.de>
wrote:
> Hello Niko,
> Am 22.06.2018 um 13:23 schrieb Nicolas Tsiogkas:
> > Hi,
> > waf was downloaded by the website (waf.io <http://waf.io>)
> > niko at im-desktop-021:~/sandbox/rtems-libbsd$ which waf-2.0.8
> Should be OK.
> > running also with waf-2.0.4 which used to work gives the same error
> > ~/sandbox/rtems-libbsd$ waf-2.0.8 -v
> > Could not create the directory ///h
> > ~/sandbox/rtems-libbsd$ waf-2.0.4 -v
> > that's pretty weird.
> Yes it is. The build scripts do a lot of stuff in preparation for the
> real build. But as far as I know nothing of it should create a
> directory. The first operation that creates a directory should print the
> following line:
> [ 1/99] Compiling testsuite/include/rtems/bsd/test/network-config.h.in
> Anyway: To find out how far you get into the build scripts, I added a
> few debug messages. Could you try to apply the attached patch and see
> whether it prints some messages. Note that the messages are not really
> clean and it seems that there is a bug that prints them two times. But
> they should give a hint when the build process breaks.
> Best Regards
> Christian Mauderer
> > Regards,
> > Niko
> > On Fri, Jun 22, 2018 at 12:23 PM Christian Mauderer
> > <christian.mauderer at embedded-brains.de
> > <mailto:christian.mauderer at embedded-brains.de>> wrote:
> > Hello Niko,
> > from a quick glance, everything till the waf call looks good. What is
> > really odd is the output of the last waf-2.0.8 call. There should be
> a
> > lot more output starting with something like
> > Waf: Entering directory
> `/home/EB/christian_m/Projekte/some-project/rtems-libbsd/build/arm-rtems5-atsamv-everything'
> > [ 1/122] Creating
> > build/arm-rtems5-atsamv-everything/build-include/rtems/bsd/modules.h
> > [ 2/122] Compiling rtemsbsd/rtems/generate_kvm_symbols
> > [ 3/122] Compiling
> > <http://network-config.h.in>
> > [ 4/122] Compiling freebsd/sys/crypto/blowfish/bf_locl.h
> > [ 5/122] Compiling freebsd/sys/crypto/blowfish/bf_pi.h
> > You are even missing the "Waf: Entering directory". So that seems
> like a
> > quite early bug.
> > You can try whether a `waf -v` provides more output. Beneath that:
> Where
> > does your waf come from? You call it with a version number.
> > Best regards
> > Christian Mauderer
> > Am 22.06.2018 um 11:21 schrieb Nicolas Tsiogkas:
> > > Hi,
> > > I did the process again with no luck. I am attaching a zip with
> > command
> > > outputs/logs.
> > > Regards,
> > > Niko
> > > On Fri, Jun 22, 2018 at 9:44 AM Nicolas Tsiogkas
> > <lou.nick at gmail.com <mailto:lou.nick at gmail.com>
> > > <mailto:lou.nick at gmail.com <mailto:lou.nick at gmail.com>>> wrote:
> > > Hi Christian,
> > > it is a fresh clone. Although I had a previous build with 4.11
> I
> > > decided try from scratch given the changes.
> > > Error is during the build. I'm configuring normally and when I
> try
> > > to waf it then it fails.
> > > Is there any way to increase the verbosity? I will repeat all
> the
> > > process from scratch keeping logs so I can send them and try
> > to find
> > > the issue.
> > > Thanks for your time!
> > > Regards,
> > > Niko
> > > On Thu, Jun 21, 2018 at 6:49 PM Christian Mauderer
> > > <list at c-mauderer.de <mailto:list at c-mauderer.de>
> > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
> > > Am 21.06.2018 um 16:26 schrieb Nicolas Tsiogkas:
> > > > And apparently I forgot the host.
> > > > It is ubuntu 16.04:
> > > > Linux im-desktop-021 4.13.0-45-generic
> > #50~16.04.1-Ubuntu SMP
> > > Wed May 30
> > > > 11:18:27 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
> > > > gcc version 5.4.0 20160609 (Ubuntu
> 5.4.0-6ubuntu1~16.04.9)
> > > > N.
> > > > On Thu, Jun 21, 2018 at 4:19 PM Nicolas Tsiogkas
> > <mailto:lou.nick at gmail.com <mailto:lou.nick at gmail.com>>>> wrote:
> > > > Hi Joel,
> > > > waf-2.0.8 configure --prefix="$sandbox/5"
> > > > --rtems-bsps=arm/xilinx_zynq_a9_qemu
> > > > has the following output:
> > > > Setting top to :
> > > > /home/niko/sandbox/rtems-libbsd
> > > > Setting out to :
> > > > /home/niko/sandbox/rtems-libbsd/build
> > > > RTEMS Version : 5
> > > > Architectures :
> arm-rtems5
> > > > Board Support Package :
> > > > arm-rtems5-xilinx_zynq_a9_qemu
> > > > Show commands : no
> > > > Long commands : no
> > > > Checking for program 'arm-rtems5-gcc' :
> > > > /home/niko/sandbox/5/bin/arm-rtems5-gcc
> > > > Checking for program 'arm-rtems5-g++' :
> > > > /home/niko/sandbox/5/bin/arm-rtems5-g++
> > > > Checking for program 'arm-rtems5-ld' :
> > > > /home/niko/sandbox/5/bin/arm-rtems5-ld
> > > > Checking for program 'arm-rtems5-ar' :
> > > > /home/niko/sandbox/5/bin/arm-rtems5-ar
> > > > Checking for program 'arm-rtems5-nm' :
> > > > /home/niko/sandbox/5/bin/arm-rtems5-nm
> > > > Checking for program 'arm-rtems5-objdump' :
> > > > /home/niko/sandbox/5/bin/arm-rtems5-objdump
> > > > Checking for program 'arm-rtems5-objcopy' :
> > > > /home/niko/sandbox/5/bin/arm-rtems5-objcopy
> > > > Checking for program 'arm-rtems5-readelf' :
> > > > /home/niko/sandbox/5/bin/arm-rtems5-readelf
> > > > Checking for program 'arm-rtems5-strip' :
> > > > /home/niko/sandbox/5/bin/arm-rtems5-strip
> > > > Checking for program 'rtems-ld' :
> > > > /home/niko/sandbox/5/bin/rtems-ld
> > > > Checking for program 'rtems-tld' :
> > > > /home/niko/sandbox/5/bin/rtems-tld
> > > > Checking for program 'rtems-bin2c' :
> > > > /home/niko/sandbox/5/bin/rtems-bin2c
> > > > Checking for program 'tar' : /bin/tar
> > > > Checking for program 'gcc, cc' :
> > > > Checking for program 'ar' :
> > > > Checking for program 'g++, c++' :
> > > > Checking for program 'gas, gcc' :
> > > > Compiler version (arm-rtems5-gcc) : 7.3.0
> > 20180125
> > > (RTEMS 5,
> > > > RSB 8ee4e8cd557c25fca59bb9751751ad4172530958, Newlib
> > 3.0.0)
> > > > Checking for RTEMS CPU options header : started
> > > > -> processing test results : all ok
> > > > Checking for RTEMS_DEBUG : no
> > > > Checking for RTEMS_MULTIPROCESSING : no
> > > > Checking for RTEMS_NEWLIB : yes
> > > > Checking for RTEMS_POSIX_API : yes
> > > > Checking for RTEMS_SMP : no
> > > > Checking for RTEMS_NETWORKING : no
> > > > Checking for RTEMS header : started
> > > > Checking for header dlfcn.h : yes
> > > > Checking for header rtems/pci.h : yes
> > > > Configure variant: :
> > > > arm-rtems5-xilinx_zynq_a9_qemu-default
> > > > Checking for header rtems/rtems-debugger.h : yes
> > > > 'configure' finished successfully (0.744s)
> > > > Cheers,
> > > > Niko
> > > > On Thu, Jun 21, 2018 at 4:09 PM Joel Sherrill
> > > <joel at rtems.org <mailto:joel at rtems.org>
> > <mailto:joel at rtems.org <mailto:joel at rtems.org>>
> > <mailto:joel at rtems.org <mailto:joel at rtems.org>>>> wrote:
> > > > On Thu, Jun 21, 2018 at 8:52 AM, Nicolas Tsiogkas
> > > > Hi,
> > > > following the steps described
> > > > in https://github.com/RTEMS/rtems-libbsd I
> > get an
> > > error
> > > > "Could not create the directory ///h" while
> > trying
> > > to build
> > > > with waf 2.0.8
> > > > Is it a known problem?
> > > > Not to me.
> > > > What's your configure command and host?
> > > > I have seen that the installation procedure
> has
> > > changed
> > > > since 4.11 and now the tools and the bsps are
> > > installed in
> > > > the same prefix, but that shouldn't matter I
> > suppose.
> > > > Thank you in advance.
> > > > Regards,
> > > > Niko
> > > > users mailing list
> > > > users at rtems.org <mailto:users at rtems.org>
> > <mailto:users at rtems.org <mailto:users at rtems.org>>
> > <mailto:users at rtems.org <mailto:users at rtems.org>>>
> > > > users mailing list
> > > Hello Nicolas,
> > > I also don't know that problem. The directory that should
> > be created
> > > "///h" looks like there are some variables missing between
> the
> > > slashes.
> > > But I'm not aware of any directory h that should be created
> > > somewhere.
> > > - Did you upgrade from a earlier build or do you build in
> > a fresh
> > > checkout? There have been some changes to the build system
> in
> > > the last
> > > months that have lead to incompatible cache files. If it
> is an
> > > old tree,
> > > try to remove `build` and `.lock-waf_*`.
> > > - About when does the problem happen? It seems your
> configure
> > > runs fine.
> > > So I assume that it appears during build or install. Maybe
> > you could
> > > provide some lines of context to the error message?
> > > Best regards
> > > Christian Mauderer
> > embedded brains GmbH
> > Herr Christian Mauderer
> > Dornierstr. 4
> > D-82178 Puchheim
> > Germany
> > email: christian.mauderer at embedded-brains.de
> > Phone: +49-89-18 94 741 - 18
> > Fax: +49-89-18 94 741 - 08
> > PGP: Public key available on request.
> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
URL: <http://lists.rtems.org/pipermail/users/attachments/20180625/87674750/attachment-0001.html>
