Error building libbsd
Nicolas Tsiogkas
lou.nick at gmail.com
Mon Jun 25 08:20:19 UTC 2018
Hi Christian,
I will go with python3 indeed as I have to finally close a patch for
Ethercat SOEM working with RTEMS 5. In parallel I will try to investigate
with the waf examples and report back.
Thanks for the prompt reply and effort. :)
Regards,
Niko
On Mon, Jun 25, 2018 at 10:15 AM Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> Hello Niko,
> if the patch didn't do anything to your output, the error has to happen
> quite early. The first one should have been printed when the build()
> function of the wscript has been reached. So I would assume that it
> already happens before that.
> If you have time and desire to find the bug, you might could try to
> build some other tools that use waf as a build system (for example the
> waf examples from the waf website). Otherwise I would suggest to go with
> python3 for now.
> Note that it shouldn't really be a problem with python2 in general: My
> OpenSUSE machine is using python2 too and has no problems with the
> current libbsd. As far as I know most distributions still use python2 as
> the default case. I only know Arch Linux that does use python3.
> Best regards
> Christian Mauderer
> Am 25.06.2018 um 10:08 schrieb Nicolas Tsiogkas:
> > Hi,
> > sorry for the late reply.
> > So, the patch didn't do a thing. Got the same print.
> > But I tried to run waf with python3
> > python3 /home/niko/.local/bin/waf-2.0.8
> > and
> > python3 /home/niko/.local/bin/waf-2.0.8 install
> > That was successful. From that I can assume that there is some issue
> > with the python2 shipped with ubuntu? I can try at home as well in case
> > there is something specific with the python configuration on my current
> > pc and report back.
> > Thanks for the help.
> > Regards,
> > Niko
> > On Fri, Jun 22, 2018 at 9:56 PM Christian Mauderer <list at c-mauderer.de
> > <mailto:list at c-mauderer.de>> wrote:
> > Hello Niko,
> > Am 22.06.2018 um 13:23 schrieb Nicolas Tsiogkas:
> > > Hi,
> > > waf was downloaded by the website (waf.io <http://waf.io>
> > <http://waf.io>)
> > > niko at im-desktop-021:~/sandbox/rtems-libbsd$ which waf-2.0.8
> > Should be OK.
> > > running also with waf-2.0.4 which used to work gives the same error
> > > ~/sandbox/rtems-libbsd$ waf-2.0.8 -v
> > > Could not create the directory ///h
> > > ~/sandbox/rtems-libbsd$ waf-2.0.4 -v
> > > that's pretty weird.
> > Yes it is. The build scripts do a lot of stuff in preparation for the
> > real build. But as far as I know nothing of it should create a
> > directory. The first operation that creates a directory should print
> the
> > following line:
> > [ 1/99] Compiling
> > testsuite/include/rtems/bsd/test/network-config.h.in
> > <http://network-config.h.in>
> > Anyway: To find out how far you get into the build scripts, I added a
> > few debug messages. Could you try to apply the attached patch and see
> > whether it prints some messages. Note that the messages are not
> really
> > clean and it seems that there is a bug that prints them two times.
> But
> > they should give a hint when the build process breaks.
> > Best Regards
> > Christian Mauderer
> > > Regards,
> > > Niko
> > > On Fri, Jun 22, 2018 at 12:23 PM Christian Mauderer
> > > <christian.mauderer at embedded-brains.de
> > <mailto:christian.mauderer at embedded-brains.de>
> > <mailto:christian.mauderer at embedded-brains.de>>> wrote:
> > > Hello Niko,
> > > from a quick glance, everything till the waf call looks good.
> > What is
> > > really odd is the output of the last waf-2.0.8 call. There
> > should be a
> > > lot more output starting with something like
> > > Waf: Entering directory
> `/home/EB/christian_m/Projekte/some-project/rtems-libbsd/build/arm-rtems5-atsamv-everything'
> > > [ 1/122] Creating
> > build/arm-rtems5-atsamv-everything/build-include/rtems/bsd/modules.h
> > > [ 2/122] Compiling rtemsbsd/rtems/generate_kvm_symbols
> > > [ 3/122] Compiling
> > > [ 4/122] Compiling freebsd/sys/crypto/blowfish/bf_locl.h
> > > [ 5/122] Compiling freebsd/sys/crypto/blowfish/bf_pi.h
> > > You are even missing the "Waf: Entering directory". So that
> > seems like a
> > > quite early bug.
> > > You can try whether a `waf -v` provides more output. Beneath
> > that: Where
> > > does your waf come from? You call it with a version number.
> > > Best regards
> > > Christian Mauderer
> > > Am 22.06.2018 um 11:21 schrieb Nicolas Tsiogkas:
> > > > Hi,
> > > > I did the process again with no luck. I am attaching a zip
> with
> > > command
> > > > outputs/logs.
> > > > Regards,
> > > > Niko
> > > > On Fri, Jun 22, 2018 at 9:44 AM Nicolas Tsiogkas
> > > <lou.nick at gmail.com <mailto:lou.nick at gmail.com>
> > <mailto:lou.nick at gmail.com <mailto:lou.nick at gmail.com>>
> > <mailto:lou.nick at gmail.com <mailto:lou.nick at gmail.com>>>> wrote:
> > > > Hi Christian,
> > > > it is a fresh clone. Although I had a previous build
> > with 4.11 I
> > > > decided try from scratch given the changes.
> > > > Error is during the build. I'm configuring normally and
> > when I try
> > > > to waf it then it fails.
> > > > Is there any way to increase the verbosity? I will
> > repeat all the
> > > > process from scratch keeping logs so I can send them and
> try
> > > to find
> > > > the issue.
> > > > Thanks for your time!
> > > > Regards,
> > > > Niko
> > > > On Thu, Jun 21, 2018 at 6:49 PM Christian Mauderer
> > > > <list at c-mauderer.de <mailto:list at c-mauderer.de>
> > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>
> > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>> wrote:
> > > > Am 21.06.2018 um 16:26 schrieb Nicolas Tsiogkas:
> > > > > And apparently I forgot the host.
> > > > > It is ubuntu 16.04:
> > > > > Linux im-desktop-021 4.13.0-45-generic
> > > #50~16.04.1-Ubuntu SMP
> > > > Wed May 30
> > > > > 11:18:27 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
> > > > > gcc version 5.4.0 20160609 (Ubuntu
> > 5.4.0-6ubuntu1~16.04.9)
> > > > > N.
> > > > > On Thu, Jun 21, 2018 at 4:19 PM Nicolas Tsiogkas
> > <mailto:lou.nick at gmail.com> <mailto:lou.nick at gmail.com
> > <mailto:lou.nick at gmail.com <mailto:lou.nick at gmail.com>>>>> wrote:
> > > > > Hi Joel,
> > > > > waf-2.0.8 configure --prefix="$sandbox/5"
> > > > > --rtems-bsps=arm/xilinx_zynq_a9_qemu
> > > > > has the following output:
> > > > > Setting top to :
> > > > > /home/niko/sandbox/rtems-libbsd
> > > > > Setting out to :
> > > > > /home/niko/sandbox/rtems-libbsd/build
> > > > > RTEMS Version : 5
> > > > > Architectures :
> > arm-rtems5
> > > > > Board Support Package :
> > > > > arm-rtems5-xilinx_zynq_a9_qemu
> > > > > Show commands : no
> > > > > Long commands : no
> > > > > Checking for program 'arm-rtems5-gcc' :
> > > > > /home/niko/sandbox/5/bin/arm-rtems5-gcc
> > > > > Checking for program 'arm-rtems5-g++' :
> > > > > /home/niko/sandbox/5/bin/arm-rtems5-g++
> > > > > Checking for program 'arm-rtems5-ld' :
> > > > > /home/niko/sandbox/5/bin/arm-rtems5-ld
> > > > > Checking for program 'arm-rtems5-ar' :
> > > > > /home/niko/sandbox/5/bin/arm-rtems5-ar
> > > > > Checking for program 'arm-rtems5-nm' :
> > > > > /home/niko/sandbox/5/bin/arm-rtems5-nm
> > > > > Checking for program 'arm-rtems5-objdump' :
> > > > > /home/niko/sandbox/5/bin/arm-rtems5-objdump
> > > > > Checking for program 'arm-rtems5-objcopy' :
> > > > > /home/niko/sandbox/5/bin/arm-rtems5-objcopy
> > > > > Checking for program 'arm-rtems5-readelf' :
> > > > > /home/niko/sandbox/5/bin/arm-rtems5-readelf
> > > > > Checking for program 'arm-rtems5-strip' :
> > > > > /home/niko/sandbox/5/bin/arm-rtems5-strip
> > > > > Checking for program 'rtems-ld' :
> > > > > /home/niko/sandbox/5/bin/rtems-ld
> > > > > Checking for program 'rtems-tld' :
> > > > > /home/niko/sandbox/5/bin/rtems-tld
> > > > > Checking for program 'rtems-bin2c' :
> > > > > /home/niko/sandbox/5/bin/rtems-bin2c
> > > > > Checking for program 'tar' :
> > /bin/tar
> > > > > Checking for program 'gcc, cc' :
> > > > > Checking for program 'ar' :
> > > > > Checking for program 'g++, c++' :
> > > > > Checking for program 'gas, gcc' :
> > > > > Compiler version (arm-rtems5-gcc) :
> 7.3.0
> > > 20180125
> > > > (RTEMS 5,
> > > > > RSB 8ee4e8cd557c25fca59bb9751751ad4172530958,
> > Newlib
> > > 3.0.0)
> > > > > Checking for RTEMS CPU options header :
> > started
> > > > > -> processing test results :
> > all ok
> > > > > Checking for RTEMS_DEBUG : no
> > > > > Checking for RTEMS_MULTIPROCESSING : no
> > > > > Checking for RTEMS_NEWLIB :
> yes
> > > > > Checking for RTEMS_POSIX_API :
> yes
> > > > > Checking for RTEMS_SMP : no
> > > > > Checking for RTEMS_NETWORKING : no
> > > > > Checking for RTEMS header :
> > started
> > all ok
> > > > > Checking for header dlfcn.h :
> yes
> > > > > Checking for header rtems/pci.h :
> yes
> > > > > Configure variant: :
> > > > > arm-rtems5-xilinx_zynq_a9_qemu-default
> > > > > Checking for header rtems/rtems-debugger.h :
> yes
> > > > > 'configure' finished successfully (0.744s)
> > > > > Cheers,
> > > > > Niko
> > > > > On Thu, Jun 21, 2018 at 4:09 PM Joel Sherrill
> > > > <joel at rtems.org <mailto:joel at rtems.org>
> > <mailto:joel at rtems.org <mailto:joel at rtems.org>>
> > <mailto:joel at rtems.org <mailto:joel at rtems.org>>>
> > <mailto:joel at rtems.org <mailto:joel at rtems.org>>>>> wrote:
> > > > > On Thu, Jun 21, 2018 at 8:52 AM, Nicolas
> > Tsiogkas
> > > > > Hi,
> > > > > following the steps described
> > > > > in
> https://github.com/RTEMS/rtems-libbsd I
> > > get an
> > > > error
> > > > > "Could not create the directory ///h"
> > while
> > > trying
> > > > to build
> > > > > with waf 2.0.8
> > > > > Is it a known problem?
> > > > > Not to me.
> > > > > What's your configure command and host?
> > > > > I have seen that the installation
> > procedure has
> > > > changed
> > > > > since 4.11 and now the tools and the
> > bsps are
> > > > installed in
> > > > > the same prefix, but that shouldn't
> > matter I
> > > suppose.
> > > > > Thank you in advance.
> > > > > Regards,
> > > > > Niko
> > > > > users mailing list
> > > > > users at rtems.org
> > <mailto:users at rtems.org> <mailto:users at rtems.org
> > <mailto:users at rtems.org>>
> > > <mailto:users at rtems.org <mailto:users at rtems.org>
> > <mailto:users at rtems.org <mailto:users at rtems.org>>>
> > <mailto:users at rtems.org <mailto:users at rtems.org>>>>
> > http://lists.rtems.org/mailman/listinfo/users
> > > > > users mailing list
> > > > Hello Nicolas,
> > > > I also don't know that problem. The directory that
> > should
> > > be created
> > > > "///h" looks like there are some variables missing
> > between the
> > > > slashes.
> > > > But I'm not aware of any directory h that should be
> > created
> > > > somewhere.
> > > > - Did you upgrade from a earlier build or do you
> > build in
> > > a fresh
> > > > checkout? There have been some changes to the build
> > system in
> > > > the last
> > > > months that have lead to incompatible cache files.
> > If it is an
> > > > old tree,
> > > > try to remove `build` and `.lock-waf_*`.
> > > > - About when does the problem happen? It seems your
> > configure
> > > > runs fine.
> > > > So I assume that it appears during build or install.
> > Maybe
> > > you could
> > > > provide some lines of context to the error message?
> > > > Best regards
> > > > Christian Mauderer
> > > embedded brains GmbH
> > > Herr Christian Mauderer
> > > Dornierstr. 4
> > > D-82178 Puchheim
> > > Germany
> > > email: christian.mauderer at embedded-brains.de
> > > Phone: +49-89-18 94 741 - 18
> > > Fax: +49-89-18 94 741 - 08
> > > PGP: Public key available on request.
> > > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne
> > des EHUG.
> Dornierstr. 4
> D-82178 Puchheim
> Germany
URL: <http://lists.rtems.org/pipermail/users/attachments/20180625/b83376c0/attachment-0001.html>
