RTEMS Source Builder issue
Ian Caddy ianc at goanna.iinet.net.au
Tue Jun 26 06:36:42 UTC 2018
Hi All,
I am trying to use the source builder to put together an ARM toolchain,
I followed the instructions on:
https://docs.rtems.org/branches/master/rsb/quick-start.html
but got the 4.11.3 tag from GIT, and used the command line:
../source-builder/sb-set/builder -- log=l-arm.txt
--prefix=$HOME/development/rtems/4.11 4.11/rtems-arm
It is failing trying to build newlib, complaining that it can not find
zlib.h:
/usr/bin/g++ -O2 -pipe
-I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include
-c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions
-fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing
-Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic
-Wno-long-long -Wno-variadic-macros -Wno-overlength-strings
-DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/.
-I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include
-I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp
-I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp
-I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr
-I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr
-I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src
-I../../gcc-4.9.3/gcc/../libdecnumber
-I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber
-I../../gcc-4.9.3/gcc/../libbacktrace    -o lto-compress.o -MT
lto-compress.o -MMD -MP -MF ./.deps/lto-compress.TPo
../../gcc-4.9.3/gcc/lto-compress.c
../../gcc-4.9.3/gcc/lto-compress.c:28:18: fatal error: zlib.h: No such
file or directory
compilation terminated.
Makefile:1058: recipe for target 'lto-compress.o' failed
I can provide the complete log file if anyone is interested, but it is
14MBytes, but I have included the newlib build log which is 70K.
Is this a known issue?
regards,
Ian Caddy
RTEMS Tools Project - Source Builder Error Report
 Build: error: building arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1
 Command Line: ../source-builder/sb-set-builder --log=l-arm.txt --prefix=/home/osboxes/development/rtems/4.11 4.11/rtems-arm
 Python: 2.7.12 (default, Dec  4 2017, 14:50:18) [GCC 5.4.0 20160609]
 git://git.rtems.org/rtems-source-builder.git/origin/4671017f41d352ac463282e7e0e41264948b73f1-modified
 Linux osboxes 4.13.0-36-generic #40~16.04.1-Ubuntu SMP Fri Feb 16 23:25:58 UTC 2018 x86_64
Tail of the build log:
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_ASAN_REPORT_LOAD4' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_ASAN_REPORT_LOAD8' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_ASAN_REPORT_LOAD16' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_ASAN_REPORT_LOAD_N' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_ASAN_REPORT_STORE1' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_ASAN_REPORT_STORE2' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_ASAN_REPORT_STORE4' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_ASAN_REPORT_STORE8' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_ASAN_REPORT_STORE16' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_ASAN_REPORT_STORE_N' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_ASAN_LOAD1' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_ASAN_LOAD2' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_ASAN_LOAD4' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_ASAN_LOAD8' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_ASAN_LOAD16' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_ASAN_LOADN' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_ASAN_STORE1' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_ASAN_STORE2' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_ASAN_STORE4' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_ASAN_STORE8' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_ASAN_STORE16' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_ASAN_STOREN' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_ASAN_REGISTER_GLOBALS' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_ASAN_UNREGISTER_GLOBALS' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_ASAN_HANDLE_NO_RETURN' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_ASAN_BEFORE_DYNAMIC_INIT' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_ASAN_AFTER_DYNAMIC_INIT' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_INIT' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_FUNC_ENTRY' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_FUNC_EXIT' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_VPTR_UPDATE' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_READ1' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_READ2' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_READ4' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_READ8' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_READ16' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_WRITE1' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_WRITE2' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_WRITE4' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_WRITE8' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_WRITE16' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC8_LOAD' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC16_LOAD' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC32_LOAD' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC64_LOAD' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC128_LOAD' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC8_STORE' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC16_STORE' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC32_STORE' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC64_STORE' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC128_STORE' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC8_EXCHANGE' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC16_EXCHANGE' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC32_EXCHANGE' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC64_EXCHANGE' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC128_EXCHANGE' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC8_FETCH_ADD' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC16_FETCH_ADD' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC32_FETCH_ADD' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC64_FETCH_ADD' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC128_FETCH_ADD' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC8_FETCH_SUB' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC16_FETCH_SUB' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC32_FETCH_SUB' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC64_FETCH_SUB' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC128_FETCH_SUB' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC8_FETCH_AND' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC16_FETCH_AND' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC32_FETCH_AND' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC64_FETCH_AND' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC128_FETCH_AND' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC8_FETCH_OR' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC16_FETCH_OR' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC32_FETCH_OR' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC64_FETCH_OR' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC128_FETCH_OR' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC8_FETCH_XOR' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC16_FETCH_XOR' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC32_FETCH_XOR' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC64_FETCH_XOR' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC128_FETCH_XOR' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC8_FETCH_NAND' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC16_FETCH_NAND' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC32_FETCH_NAND' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC64_FETCH_NAND' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC128_FETCH_NAND' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC8_COMPARE_EXCHANGE_STRONG' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC16_COMPARE_EXCHANGE_STRONG' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC32_COMPARE_EXCHANGE_STRONG' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC64_COMPARE_EXCHANGE_STRONG' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC128_COMPARE_EXCHANGE_STRONG' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC8_COMPARE_EXCHANGE_WEAK' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC16_COMPARE_EXCHANGE_WEAK' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC32_COMPARE_EXCHANGE_WEAK' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC64_COMPARE_EXCHANGE_WEAK' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC128_COMPARE_EXCHANGE_WEAK' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC_THREAD_FENCE' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_TSAN_ATOMIC_SIGNAL_FENCE' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_UBSAN_HANDLE_DIVREM_OVERFLOW' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_UBSAN_HANDLE_SHIFT_OUT_OF_BOUNDS' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_UBSAN_HANDLE_BUILTIN_UNREACHABLE' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_UBSAN_HANDLE_MISSING_RETURN' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_UBSAN_HANDLE_VLA_BOUND_NOT_POSITIVE' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_UBSAN_HANDLE_TYPE_MISMATCH' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_UBSAN_HANDLE_ADD_OVERFLOW' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_UBSAN_HANDLE_SUB_OVERFLOW' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_UBSAN_HANDLE_MUL_OVERFLOW' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_UBSAN_HANDLE_NEGATE_OVERFLOW' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_UBSAN_HANDLE_LOAD_INVALID_VALUE' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_CILKPLUS_SEC_REDUCE_ADD' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_CILKPLUS_SEC_REDUCE_MUL' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_CILKPLUS_SEC_REDUCE_ALL_ZERO' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_CILKPLUS_SEC_REDUCE_ANY_ZERO' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_CILKPLUS_SEC_REDUCE_MAX' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_CILKPLUS_SEC_REDUCE_MIN' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_CILKPLUS_SEC_REDUCE_MIN_IND' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_CILKPLUS_SEC_REDUCE_MAX_IND' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_CILKPLUS_SEC_REDUCE_ANY_NONZERO' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_CILKPLUS_SEC_REDUCE_ALL_NONZERO' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_CILKPLUS_SEC_REDUCE' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_CILKPLUS_SEC_REDUCE_MUTATING' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_CILKPLUS_SEC_IMPLICIT_INDEX' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_COMPLEX_MUL_MIN' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_COMPLEX_MUL_MAX' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_COMPLEX_DIV_MIN' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'BUILT_IN_COMPLEX_DIV_MAX' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c:432:12: warning: enumeration value 'END_BUILTINS' not handled in switch [-Wswitch]
../../gcc-4.9.3/gcc/ipa-pure-const.c: In function 'void propagate_pure_const()':
../../gcc-4.9.3/gcc/ipa-pure-const.c:1270:15: warning: enumeration value 'IPA_REF_ALIAS' not handled in switch [-Wswitch]
        switch (ref->use)
/usr/bin/g++ -O2 -pipe -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include -c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/. -I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber -I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.9.3/gcc/../libbacktrace    -o ipa-reference.o -MT ipa-reference.o -MMD -MP -MF ./.deps/ipa-reference.TPo ../../gcc-4.9.3/gcc/ipa-reference.c
../../gcc-4.9.3/gcc/ipa-reference.c: In function 'void analyze_function(cgraph_node*)':
../../gcc-4.9.3/gcc/ipa-reference.c:474:14: warning: enumeration value 'IPA_REF_ALIAS' not handled in switch [-Wswitch]
       switch (ref->use)
/usr/bin/g++ -O2 -pipe -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include -c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/. -I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber -I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.9.3/gcc/../libbacktrace    -o ipa-ref.o -MT ipa-ref.o -MMD -MP -MF ./.deps/ipa-ref.TPo ../../gcc-4.9.3/gcc/ipa-ref.c
/usr/bin/g++ -O2 -pipe -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include -c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/. -I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber -I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.9.3/gcc/../libbacktrace    -o ipa-utils.o -MT ipa-utils.o -MMD -MP -MF ./.deps/ipa-utils.TPo ../../gcc-4.9.3/gcc/ipa-utils.c
/usr/bin/g++ -O2 -pipe -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include -c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/. -I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber -I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.9.3/gcc/../libbacktrace    -o ipa.o -MT ipa.o -MMD -MP -MF ./.deps/ipa.TPo ../../gcc-4.9.3/gcc/ipa.c
../../gcc-4.9.3/gcc/ipa.c: In function 'void ipa_discover_readonly_nonaddressable_vars()':
../../gcc-4.9.3/gcc/ipa.c:665:11: warning: enumeration value 'IPA_REF_ALIAS' not handled in switch [-Wswitch]
    switch (ref->use)
/usr/bin/g++ -O2 -pipe -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include -c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/. -I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber -I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.9.3/gcc/../libbacktrace    -o ira.o -MT ira.o -MMD -MP -MF ./.deps/ira.TPo ../../gcc-4.9.3/gcc/ira.c
/usr/bin/g++ -O2 -pipe -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include -c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/. -I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber -I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.9.3/gcc/../libbacktrace    -o ira-build.o -MT ira-build.o -MMD -MP -MF ./.deps/ira-build.TPo ../../gcc-4.9.3/gcc/ira-build.c
/usr/bin/g++ -O2 -pipe -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include -c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/. -I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber -I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.9.3/gcc/../libbacktrace    -o ira-costs.o -MT ira-costs.o -MMD -MP -MF ./.deps/ira-costs.TPo ../../gcc-4.9.3/gcc/ira-costs.c
/usr/bin/g++ -O2 -pipe -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include -c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/. -I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber -I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.9.3/gcc/../libbacktrace    -o ira-conflicts.o -MT ira-conflicts.o -MMD -MP -MF ./.deps/ira-conflicts.TPo ../../gcc-4.9.3/gcc/ira-conflicts.c
/usr/bin/g++ -O2 -pipe -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include -c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/. -I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber -I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.9.3/gcc/../libbacktrace    -o ira-color.o -MT ira-color.o -MMD -MP -MF ./.deps/ira-color.TPo ../../gcc-4.9.3/gcc/ira-color.c
../../gcc-4.9.3/gcc/ira-color.c: In function 'int coalesced_pseudo_reg_slot_compare(const void*, const void*)':
../../gcc-4.9.3/gcc/ira-color.c:3854:31: warning: logical not is only applied to the left hand side of comparison [-Wlogical-not-parentheses]
      || !FRAME_GROWS_DOWNWARD == STACK_GROWS_DOWNWARD ? diff : -diff);
/usr/bin/g++ -O2 -pipe -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include -c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/. -I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber -I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.9.3/gcc/../libbacktrace    -o ira-emit.o -MT ira-emit.o -MMD -MP -MF ./.deps/ira-emit.TPo ../../gcc-4.9.3/gcc/ira-emit.c
/usr/bin/g++ -O2 -pipe -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include -c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/. -I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber -I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.9.3/gcc/../libbacktrace    -o ira-lives.o -MT ira-lives.o -MMD -MP -MF ./.deps/ira-lives.TPo ../../gcc-4.9.3/gcc/ira-lives.c
/usr/bin/g++ -O2 -pipe -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include -c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/. -I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber -I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.9.3/gcc/../libbacktrace    -o jump.o -MT jump.o -MMD -MP -MF ./.deps/jump.TPo ../../gcc-4.9.3/gcc/jump.c
/usr/bin/g++ -O2 -pipe -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include -c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/. -I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber -I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.9.3/gcc/../libbacktrace    -o langhooks.o -MT langhooks.o -MMD -MP -MF ./.deps/langhooks.TPo ../../gcc-4.9.3/gcc/langhooks.c
/usr/bin/g++ -O2 -pipe -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include -c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/. -I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber -I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.9.3/gcc/../libbacktrace    -o lcm.o -MT lcm.o -MMD -MP -MF ./.deps/lcm.TPo ../../gcc-4.9.3/gcc/lcm.c
/usr/bin/g++ -O2 -pipe -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include -c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/. -I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber -I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.9.3/gcc/../libbacktrace    -o lists.o -MT lists.o -MMD -MP -MF ./.deps/lists.TPo ../../gcc-4.9.3/gcc/lists.c
/usr/bin/g++ -O2 -pipe -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include -c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/. -I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber -I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.9.3/gcc/../libbacktrace    -o loop-doloop.o -MT loop-doloop.o -MMD -MP -MF ./.deps/loop-doloop.TPo ../../gcc-4.9.3/gcc/loop-doloop.c
/usr/bin/g++ -O2 -pipe -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include -c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/. -I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber -I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.9.3/gcc/../libbacktrace    -o loop-init.o -MT loop-init.o -MMD -MP -MF ./.deps/loop-init.TPo ../../gcc-4.9.3/gcc/loop-init.c
/usr/bin/g++ -O2 -pipe -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include -c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/. -I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber -I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.9.3/gcc/../libbacktrace    -o loop-invariant.o -MT loop-invariant.o -MMD -MP -MF ./.deps/loop-invariant.TPo ../../gcc-4.9.3/gcc/loop-invariant.c
/usr/bin/g++ -O2 -pipe -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include -c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/. -I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber -I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.9.3/gcc/../libbacktrace    -o loop-iv.o -MT loop-iv.o -MMD -MP -MF ./.deps/loop-iv.TPo ../../gcc-4.9.3/gcc/loop-iv.c
/usr/bin/g++ -O2 -pipe -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include -c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/. -I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber -I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.9.3/gcc/../libbacktrace    -o loop-unroll.o -MT loop-unroll.o -MMD -MP -MF ./.deps/loop-unroll.TPo ../../gcc-4.9.3/gcc/loop-unroll.c
/usr/bin/g++ -O2 -pipe -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include -c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/. -I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber -I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.9.3/gcc/../libbacktrace    -o loop-unswitch.o -MT loop-unswitch.o -MMD -MP -MF ./.deps/loop-unswitch.TPo ../../gcc-4.9.3/gcc/loop-unswitch.c
/usr/bin/g++ -O2 -pipe -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include -c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/. -I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber -I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.9.3/gcc/../libbacktrace    -o lower-subreg.o -MT lower-subreg.o -MMD -MP -MF ./.deps/lower-subreg.TPo ../../gcc-4.9.3/gcc/lower-subreg.c
/usr/bin/g++ -O2 -pipe -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include -c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/. -I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber -I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.9.3/gcc/../libbacktrace    -o lra.o -MT lra.o -MMD -MP -MF ./.deps/lra.TPo ../../gcc-4.9.3/gcc/lra.c
/usr/bin/g++ -O2 -pipe -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include -c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/. -I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber -I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.9.3/gcc/../libbacktrace    -o lra-assigns.o -MT lra-assigns.o -MMD -MP -MF ./.deps/lra-assigns.TPo ../../gcc-4.9.3/gcc/lra-assigns.c
/usr/bin/g++ -O2 -pipe -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include -c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/. -I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber -I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.9.3/gcc/../libbacktrace    -o lra-coalesce.o -MT lra-coalesce.o -MMD -MP -MF ./.deps/lra-coalesce.TPo ../../gcc-4.9.3/gcc/lra-coalesce.c
/usr/bin/g++ -O2 -pipe -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include -c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/. -I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber -I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.9.3/gcc/../libbacktrace    -o lra-constraints.o -MT lra-constraints.o -MMD -MP -MF ./.deps/lra-constraints.TPo ../../gcc-4.9.3/gcc/lra-constraints.c
/usr/bin/g++ -O2 -pipe -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include -c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/. -I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber -I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.9.3/gcc/../libbacktrace    -o lra-eliminations.o -MT lra-eliminations.o -MMD -MP -MF ./.deps/lra-eliminations.TPo ../../gcc-4.9.3/gcc/lra-eliminations.c
/usr/bin/g++ -O2 -pipe -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include -c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/. -I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber -I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.9.3/gcc/../libbacktrace    -o lra-lives.o -MT lra-lives.o -MMD -MP -MF ./.deps/lra-lives.TPo ../../gcc-4.9.3/gcc/lra-lives.c
/usr/bin/g++ -O2 -pipe -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include -c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/. -I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber -I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.9.3/gcc/../libbacktrace    -o lra-spills.o -MT lra-spills.o -MMD -MP -MF ./.deps/lra-spills.TPo ../../gcc-4.9.3/gcc/lra-spills.c
../../gcc-4.9.3/gcc/lra-spills.c: In function 'int pseudo_reg_slot_compare(const void*, const void*)':
../../gcc-4.9.3/gcc/lra-spills.c:240:31: warning: logical not is only applied to the left hand side of comparison [-Wlogical-not-parentheses]
/usr/bin/g++ -O2 -pipe -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include -c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/. -I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber -I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.9.3/gcc/../libbacktrace    -o lto-cgraph.o -MT lto-cgraph.o -MMD -MP -MF ./.deps/lto-cgraph.TPo ../../gcc-4.9.3/gcc/lto-cgraph.c
/usr/bin/g++ -O2 -pipe -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include -c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/. -I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber -I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.9.3/gcc/../libbacktrace    -o lto-streamer.o -MT lto-streamer.o -MMD -MP -MF ./.deps/lto-streamer.TPo ../../gcc-4.9.3/gcc/lto-streamer.c
/usr/bin/g++ -O2 -pipe -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include -c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/. -I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber -I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.9.3/gcc/../libbacktrace    -o lto-streamer-in.o -MT lto-streamer-in.o -MMD -MP -MF ./.deps/lto-streamer-in.TPo ../../gcc-4.9.3/gcc/lto-streamer-in.c
/usr/bin/g++ -O2 -pipe -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include -c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/. -I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber -I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.9.3/gcc/../libbacktrace    -o lto-streamer-out.o -MT lto-streamer-out.o -MMD -MP -MF ./.deps/lto-streamer-out.TPo ../../gcc-4.9.3/gcc/lto-streamer-out.c
../../gcc-4.9.3/gcc/lto-streamer-out.c: In function 'void write_symbol(streamer_tree_cache_d*, lto_output_stream*, tree, pointer_set_t*, bool)':
../../gcc-4.9.3/gcc/lto-streamer-out.c:2238:37: warning: 'visibility' may be used uninitialized in this function [-Wmaybe-uninitialized]
   enum gcc_plugin_symbol_visibility visibility;
/usr/bin/g++ -O2 -pipe -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include -c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/. -I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber -I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.9.3/gcc/../libbacktrace    -o lto-section-in.o -MT lto-section-in.o -MMD -MP -MF ./.deps/lto-section-in.TPo ../../gcc-4.9.3/gcc/lto-section-in.c
/usr/bin/g++ -O2 -pipe -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include -c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/. -I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber -I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.9.3/gcc/../libbacktrace    -o lto-section-out.o -MT lto-section-out.o -MMD -MP -MF ./.deps/lto-section-out.TPo ../../gcc-4.9.3/gcc/lto-section-out.c
/usr/bin/g++ -O2 -pipe -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include -c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/. -I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber -I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.9.3/gcc/../libbacktrace    -o lto-opts.o -MT lto-opts.o -MMD -MP -MF ./.deps/lto-opts.TPo ../../gcc-4.9.3/gcc/lto-opts.c
/usr/bin/g++ -O2 -pipe -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-osboxes/4.11/rtems-arm/home/osboxes/development/rtems/4.11/include -c   -g -O2 -DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -I. -I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/. -I../../gcc-4.9.3/gcc/../include -I../../gcc-4.9.3/gcc/../libcpp/include -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/gmp -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/./mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpfr -I/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber -I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber -I../../gcc-4.9.3/gcc/../libbacktrace    -o lto-compress.o -MT lto-compress.o -MMD -MP -MF ./.deps/lto-compress.TPo ../../gcc-4.9.3/gcc/lto-compress.c
../../gcc-4.9.3/gcc/lto-compress.c:28:18: fatal error: zlib.h: No such file or directory
compilation terminated.
Makefile:1058: recipe for target 'lto-compress.o' failed
make[2]: Leaving directory '/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build/gcc'
make[2]: *** [lto-compress.o] Error 1
make[1]: *** [all-gcc] Error 2
make: *** [all] Error 2
Makefile:3977: recipe for target 'all-gcc' failed
make[1]: Leaving directory '/home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/build'
Makefile:863: recipe for target 'all' failed
shell cmd failed: /bin/sh -ex  /home/osboxes/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1/doit
error: building arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-linux-gnu-1
