RTEMS Source Builder issue
Ian Caddy
ianc at goanna.iinet.net.au
Wed Jun 27 06:12:48 UTC 2018
Hi Chris,
On 27/06/2018 11:03 AM, Chris Johns wrote:
> On 26/06/2018 17:13, Ian Caddy wrote:
>> An update on this, I am not that familiar with Ubuntu and got the correct
>> information about build-dep, it was erroring saying I had no source in my
>> source.list, which I have now fixed, and it is installing a bunch more stuff for
>> that first install line, I will give it another shot and see how it goes.
> If you can see how we can improve the documentation please post a patch.
I am happy to help, but not quite sure how to submit a patch. I needed
extra information in section:
https://docs.rtems.org/branches/master/rsb/hosts.html
3.1.5 Ubuntu
The latest version is Ubuntu 16.04.1 LTS 64bit. This section also
includes Xubuntu. A minimal installation was used and the following
packages installed:
$ sudo apt-get build-dep binutils gcc g++ gdb unzip pax
$ sudo apt-get install python2.7-dev git
Now my extra paragraph:
If the build-dep fails with the following error:
|Reading package lists... Done E: Unable to find a source package for ...
You need to run "software-properties-gtk" then under the "Ubuntu
Software" tab click "Source Code" This has added some deb-src lines
under /etc/apt/sources.list, and now you can do sudo apt-get build-dep
<package> **< Note this information came from:
https://askubuntu.com/questions/496549/error-you-must-put-some-source-uris-in-your-sources-list
>** regards, Ian C. |
URL: <http://lists.rtems.org/pipermail/users/attachments/20180627/c77a24f0/attachment.html>
