RTEMS Source Builder issue
Wed Jun 27 06:21:44 UTC 2018
On 27/06/2018 16:12, Ian Caddy wrote:
> On 27/06/2018 11:03 AM, Chris Johns wrote:
>> On 26/06/2018 17:13, Ian Caddy wrote:
>>> An update on this, I am not that familiar with Ubuntu and got the correct
>>> information about build-dep, it was erroring saying I had no source in my
>>> source.list, which I have now fixed, and it is installing a bunch more stuff for
>>> that first install line, I will give it another shot and see how it goes.
>> If you can see how we can improve the documentation please post a patch.
> I am happy to help, but not quite sure how to submit a patch.
Thanks.
- Clone https://git.rtems.org/rtems-docs/
- Review https://git.rtems.org/rtems-docs/tree/README.txt
- Edit https://git.rtems.org/rtems-docs/tree/rsb/hosts.rst
- Submit a patch following https://devel.rtems.org/wiki/Developer/Git
Setting up Sphinx should be easy. I would not bother with PDF unless you want to
try.
Thanks
