zynq bspreset function do not work
Fri Jun 29 00:33:15 UTC 2018
On 28/06/2018 17:13, bin.wang at qkmtech.com wrote:
> i want to use the zynq 7000 bspreset function to reset the system.
> but when i call this funtion ,the code run fly .
> what i should do before i call this funtion ?
Are you running in secure mode, ie a secure boot with an AES key in the BBRAM or
eFuse?
There is a bug in the Zynq with the SRST bit when operating in secure mode. You
need an external hardware reset.
