rtems-libbsd bpf BIOCSRTIMEOUT behaviour
Fri Jun 29 05:01:28 UTC 2018
On 28/06/18 14:09, Nicolas Tsiogkas wrote:
> Hi,
> I have observed a weird behaviour while setting the BIOCSRTIMEOUT for
> a bpf.
> When setting it to low values (less than a second) as it can be seen
> below the bpf is actually blocking instead of waiting and continuing.
> struct timeval timeout;
> timeout.tv_sec =  0;
> timeout.tv_usec = 1;
> if (ioctl(*bpf, BIOCSRTIMEOUT, &timeout) == -1) {
> perror("BIOCSRTIMEOUT");
>   return 0;
> This was working with the libbsd 4.11 branch. Is this a known bug?
No, we use the bpf with libpcap on the master. You have to debug this.
> In addition the bpf is not receiving/reading anything incoming while
> with wireshark I can confirm that there are things on the wire and the
> bpf is in promiscuous mode. Still this was working on the 4.11 branch.
> Any idea on how to debug this?
I would set a break point to the network interface receive function and
then follow the path of the Ethernet frame.
> Thanks in advance.
> Cheers,
> Niko
> users mailing list
> users at rtems.org
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
