rsb problem with python
Slide slide.o.mix at gmail.com
Fri Jun 1 19:29:58 UTC 2018
Hi Pete,
Is there any additional information in the logs for the git command failure?
Build: error: git command failed (/usr/bin/git): 1
Alex
On Fri, Jun 1, 2018 at 12:28 PM D Peter Siddons <siddons at bnl.gov> wrote:
> Hi Alex,
>   THis didn't change anything. Looking at the report I see:
> RTEMS Tools Project - Source Builder Error Report
>  Command Line: ../source-builder/sb-set-builder --log=l-arm.txt --prefix=/home/peter/development/rtems/5 --with-rtems 5/rtems-arm
>  Python: 2.7.12 (default, Dec  4 2017, 14:50:18) [GCC 5.4.0 20160609]
> I thought rsb needed Python3.6? That's why I went through installing it
> earlier. Could this be the problem? 2.7.12 is the default python for Ubuntu
> 16.04. The error seems to be a result of me using "--with-rtems" flag.
> Pete.
> On 05/31/2018 01:42 PM, Slide wrote:
> Hi Pete,
> This is the command I used
> git config url.https://git.rtems.org/.insteadOf git://git.rtems.org/
> If you want to make the configuration global (not per repo) you can use
> the following
> git config --global url.https://git.rtems.org/.insteadOf git://
> git.rtems.org/
> Thanks,
> Alex
> On Wed, May 30, 2018 at 6:35 PM Siddons, David <siddons at bnl.gov> wrote:
>> Hi Alex,
>>    I'm pretty git-ignorant. How do I use your command git config url
>> https://git.rtems.org/ <https://git.rtems.org/rtems.insteadOf> ? If I
>> just execute that it says "error: key does not contain a section: url".
>> Pete.
>> *From:* Slide [slide.o.mix at gmail.com]
>> *Sent:* Wednesday, May 30, 2018 5:32 PM
>> *To:* Siddons, David
>> *Cc:* users at rtems.org
>> *Subject:* Re: rsb problem with python
>> Hi Pete,
>> That's something I would like to know as well. When something fails after
>> building GCC, it would be nice to not have to rebuild GCC the next time. I
>> don't know enough about the RTEMS build process at this point to be able to
>> help you on that part.
>> Regards,
>> Alex
>> On Wed, May 30, 2018 at 2:19 PM D Peter Siddons <siddons at bnl.gov> wrote:
>>> Hi Alex,
>>>  OK, thanks. I'll try that tonight. Maybe it will work as-is from my
>>> home network.
>>> Is there a way to skip parts of the build? The first part is very slow.
>>> Pete.
>>> On 05/30/2018 04:59 PM, Slide wrote:
>>> Hi Pete,
>>> I also ran into a similar failure :-) I had to use:
>>> git config url https://git.rtems.org/.insteadOf
>>> <https://git.rtems.org/rtems.insteadOf> git://git.rtems.org
>>> My IT blocks the git protocol port on our company firewall. You can make
>>> this global by adding --global after config in the command above
>>> Alex
>>> On Wed, May 30, 2018 at 12:58 PM D Peter Siddons <siddons at bnl.gov>
>>> wrote:
>>>> Hi Gedare,
>>>>     That worked, i.e. commenting out the miniconda path and installing
>>>> python3.6-dev. So on to the next stop :)
>>>> Processing stopped when building the kernel. At the end of the log file
>>>> I see:
>>>> script: 72: export PATH
>>>> script: 73: # Default environment set up.
>>>> script: 74: LANG=C
>>>> script: 75: export LANG
>>>> script: 76: unset DISPLAY || :
>>>> script: 77: umask 022
>>>> script: 78: cd "/home/peter/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems5-kernel-5-1"
>>>> script: 79: echo "=> arm-rtems5-kernel-5-1:"
>>>> script: 80: echo "==> %prep:"
>>>> script: 81: source_dir_rtems="rtems-5"
>>>> source setup: arm-rtems5-kernel-5-1: source rtems -q -c -n arm-rtems5-kernel-5-1-5
>>>> making dir: /home/peter/development/rtems/src/rtems-source-builder/rtems/sources/git
>>>> git: reset: git://git.rtems.org/rtems.git
>>>> git: checkout: git://git.rtems.org/rtems.git => 5
>>>> I have attached the entire report, FYI. Does this mean that git could
>>>> not supply the source?
>>>> Pete.
>>>> On 05/30/2018 01:01 PM, Gedare Bloom wrote:
>>>> Pete,
>>>> On Wed, May 30, 2018 at 12:19 PM, D Peter Siddons <siddons at bnl.gov> <siddons at bnl.gov> wrote:
>>>> Hi Gedare,
>>>>    I didn't get your earlier email (?), but the answer is:
>>>> /home/peter/miniconda3/bin/python3.6
>>>> so the only way I have 3.6 is through miniconda. Maybe it expects
>>>> /usr/bin/python3.6?
>>>> Odd that my email didn't come through to you. Anyway, since 'which'
>>>> finds it, the paths seem correct. Alex' suggestion to install the
>>>> development library is a good one however. I have had problems in the
>>>> past with mixed Anaconda python installations and Ubuntu distro ones.
>>>> I (like you) had the conda in a subdir of my home directory though, so
>>>> I found it was easiest for me to just disable the conda paths e.g. by
>>>> commenting out
>>>> #export PATH="/home/gedare/anaconda3/bin:$PATH"
>>>> in my .bashrc was sufficient for me
>>>> Then, I could install/use the Ubuntu distributions Python2/3 packages
>>>> without conflicts.
>>>> Gedare
>>>> Pete.
>>>> On 05/30/2018 12:12 PM, Gedare Bloom wrote:
>>>> Alex,
>>>> Yes that also makes sense, thank you. Usually, I've seen that problem
>>>> manifest as missing Python.h, but error messages can be vague and
>>>> inconsistent. :)
>>>> On Wed, May 30, 2018 at 11:49 AM, Slide <slide.o.mix at gmail.com> <slide.o.mix at gmail.com> wrote:
>>>> I ran into a similar issue and the way I solved it was by installing the
>>>> -dev package for Python. For me this was libpython3-dev on Ubuntu. I'm not
>>>> sure how to do that with the Anaconda installation, but this may help point
>>>> you in the right direction.
>>>> Regards,
>>>> Alex
>>>> On Wed, May 30, 2018 at 6:57 AM Gedare Bloom <gedare at rtems.org> <gedare at rtems.org> wrote:
>>>> Pete,
>>>> Do you get anything with:
>>>> $ which python3.6
>>>> Probably, it is looking for that invocation command. I ought to try
>>>> this, because my Ubuntu does not ship with python3.6 I know, so maybe
>>>> it breaks too... hm
>>>> On Mon, May 28, 2018 at 6:23 PM, Siddons, David <siddons at bnl.gov> <siddons at bnl.gov> wrote:
>>>> Hi Amaan,
>>>>    Actually,  /home/peter/miniconda3/bin/python is a soft link to
>>>> /home/peter/miniconda3/bin/python3.6 already! Does rsb not follow links?
>>>> Pete.
>>>> ________________________________
>>>> From: Amaan Cheval [amaan.cheval at gmail.com]
>>>> Sent: Monday, May 28, 2018 6:05 PM
>>>> To: Siddons, David
>>>> Cc: users at rtems.org
>>>> Subject: Re: rsb problem with python
>>>> Hey David!
>>>> It looks to me like Anaconda doesn't install the "alias" binaries
>>>> specifying
>>>> the version (for eg. both "python" and "python3.6"). I believe the fix
>>>> in
>>>> your case should be as simple as copying your existing binary with the
>>>> following command:
>>>> cp /home/peter/miniconda3/bin/python
>>>> On Tue, May 29, 2018, 3:28 AM Siddons, David <siddons at bnl.gov> <siddons at bnl.gov> wrote:
>>>> While building rsb for arm-rtems I got this problem:
>>>> checking for python... /home/peter/miniconda3/bin/python
>>>> checking for python3.6... no
>>>> configure: error: python is missing or unusable
>>>> Makefile:9095: recipe for target 'configure-gdb' failed
>>>> make[1]: *** [configure-gdb] Error 1
>>>> make[1]: Leaving directory
>>>> '/home/peter/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems5-gdb-8.0.1-x86_64-linux-gnu-1/build'
>>>> Makefile:848: recipe for target 'all' failed
>>>> make: *** [all] Error 2
>>>> shell cmd failed: /bin/sh -ex
>>>> /home/peter/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems5-gdb-8.0.1-x86_64-linux-gnu-1/doit
>>>> error: building
>>>> arm-rtems5-gdb-8.0.1-x86_64-linux-gnu-1peter at peter-Latitude-E7240:~/development/rtems/src/rtems-source-builder/rtems$
>>>> I am running Ubuntu:
>>>> peter at peter-Latitude-E7240:/etc$ lsb_release -a
>>>> LSB Version:
>>>> core-9.20160110ubuntu0.2-amd64:core-9.20160110ubuntu0.2-noarch:printing-9.20160110ubuntu0.2-amd64:printing-9.20160110ubuntu0.2-noarch:security-9.20160110ubuntu0.2-amd64:security-9.20160110ubuntu0.2-noarch
>>>> Distributor ID: Ubuntu
>>>> Description:    Ubuntu 16.04.4 LTS
>>>> Release:        16.04
>>>> Codename:       xenial
>>>> then:
>>>> python -V
>>>> Python 3.6.1 :: Continuum Analytics, Inc.
>>>> This comes from an Anaconda installation. If I remove the path entry
>>>> which
>>>> causes that I get python 2.7, which is the default Ubuntu 16.04
>>>> version. Do
>>>> I need to install Python 3.6?
>>>> Pete.
>>>> _______________________________________________
>>>> users mailing listusers at rtems.orghttp://lists.rtems.org/mailman/listinfo/users
>>>> D. Peter Siddons
>>>> Detector Development Group Leader
>>>> Photon Science Division, NSLS-II,
>>>> Bldg. 535B
>>>> Brookhaven National Laboratory
>>>> Upton, NY 11973
>>>> email: siddons at bnl.gov
>>>> Phone: (631) 344-2738
>>>> D. Peter Siddons
>>>> Bldg. 535B
>>>> Upton, NY 11973
>>> D. Peter Siddons
>>> Bldg. 535B
>>> Upton, NY 11973
> D. Peter Siddons
> Bldg. 535B
> Upton, NY 11973
URL: <http://lists.rtems.org/pipermail/users/attachments/20180601/74d807b7/attachment-0002.html>
