rsb problem with python
D Peter Siddons siddons at bnl.gov
Fri Jun 1 20:47:34 UTC 2018
OK, the report I sent is old so please ignore it. Tonight I will remove
all of the report files and re-build. I may even clean out everything
and start again. I don't know how well rsb behaves under repeated
executions.
Pete.
On 06/01/2018 04:32 PM, D Peter Siddons wrote:
> I have attached the report file.
> I tried a build without the "--with-rtems" flag and it completed
> successfully. So I have all the tools, now I just need RTEMS! I guess
> I go back to the old method of downloading a release and doing the
> bootstrap dance.
> THanks,
> Pete.
> On 06/01/2018 03:29 PM, Slide wrote:
>> Hi Pete,
>> Is there any additional information in the logs for the git command
>> failure?
>> Build: error: git command failed (/usr/bin/git): 1
>> Alex
>> On Fri, Jun 1, 2018 at 12:28 PM D Peter Siddons <siddons at bnl.gov
>> <mailto:siddons at bnl.gov>> wrote:
>>     Hi Alex,
>>       THis didn't change anything. Looking at the report I see:
>>     RTEMS Tools Project - Source Builder Error Report
>>       Command Line: ../source-builder/sb-set-builder --log=l-arm.txt --prefix=/home/peter/development/rtems/5 --with-rtems 5/rtems-arm
>>       Python: 2.7.12 (default, Dec  4 2017, 14:50:18) [GCC 5.4.0 20160609]
>>     I thought rsb needed Python3.6? That's why I went through
>>     installing it earlier. Could this be the problem? 2.7.12 is the
>>     default python for Ubuntu 16.04. The error seems to be a result
>>     of me using "--with-rtems" flag.
>>     Pete.
>>     On 05/31/2018 01:42 PM, Slide wrote:
>>>     Hi Pete,
>>>     This is the command I used
>>>     git config
>>>     url.https://git.rtems.org/.insteadOf git://git.rtems.org/
>>>     <http://git.rtems.org/>
>>>     If you want to make the configuration global (not per repo) you
>>>     can use the following
>>>     git config --global
>>>     Thanks,
>>>     Alex
>>>     On Wed, May 30, 2018 at 6:35 PM Siddons, David <siddons at bnl.gov
>>>         Hi Alex,
>>>            I'm pretty git-ignorant. How do I use your command git
>>>         config url https://git.rtems.org/
>>>         <https://git.rtems.org/rtems.insteadOf> ? If I just execute
>>>         that it says "error: key does not contain a section: url".
>>>         Pete.
>>>         *From:* Slide [slide.o.mix at gmail.com
>>>         <mailto:slide.o.mix at gmail.com>]
>>>         *Sent:* Wednesday, May 30, 2018 5:32 PM
>>>         *To:* Siddons, David
>>>         *Cc:* users at rtems.org <mailto:users at rtems.org>
>>>         *Subject:* Re: rsb problem with python
>>>         Hi Pete,
>>>         That's something I would like to know as well. When
>>>         something fails after building GCC, it would be nice to not
>>>         have to rebuild GCC the next time. I don't know enough about
>>>         the RTEMS build process at this point to be able to help you
>>>         on that part.
>>>         Regards,
>>>         Alex
>>>         On Wed, May 30, 2018 at 2:19 PM D Peter Siddons
>>>         <siddons at bnl.gov <mailto:siddons at bnl.gov>> wrote:
>>>             Hi Alex,
>>>              OK, thanks. I'll try that tonight. Maybe it will work
>>>             as-is from my home network.
>>>             Is there a way to skip parts of the build? The first
>>>             part is very slow.
>>>             Pete.
>>>             On 05/30/2018 04:59 PM, Slide wrote:
>>>>             Hi Pete,
>>>>             I also ran into a similar failure :-) I had to use:
>>>>             git config url https://git.rtems.org/.insteadOf
>>>>             <https://git.rtems.org/rtems.insteadOf> git://git.rtems.org
>>>>             <http://git.rtems.org>
>>>>             My IT blocks the git protocol port on our company
>>>>             firewall. You can make this global by adding --global
>>>>             after config in the command above
>>>>             Alex
>>>>             On Wed, May 30, 2018 at 12:58 PM D Peter Siddons
>>>>                 Hi Gedare,
>>>>                     That worked, i.e. commenting out the miniconda
>>>>                 path and installing python3.6-dev. So on to the
>>>>                 next stop :)
>>>>                 Processing stopped when building the kernel. At the
>>>>                 end of the log file I see:
>>>>                 script: 72: export PATH
>>>>                 script: 73: # Default environment set up.
>>>>                 script: 74: LANG=C
>>>>                 script: 75: export LANG
>>>>                 script: 76: unset DISPLAY || :
>>>>                 script: 77: umask 022
>>>>                 script: 78: cd "/home/peter/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems5-kernel-5-1"
>>>>                 script: 79: echo "=> arm-rtems5-kernel-5-1:"
>>>>                 script: 80: echo "==> %prep:"
>>>>                 script: 81: source_dir_rtems="rtems-5"
>>>>                 source setup: arm-rtems5-kernel-5-1: source rtems -q -c -n arm-rtems5-kernel-5-1-5
>>>>                 making dir: /home/peter/development/rtems/src/rtems-source-builder/rtems/sources/git
>>>>                 git: reset: git://git.rtems.org/rtems.git
>>>>                 <http://git.rtems.org/rtems.git>
>>>>                 git: checkout: git://git.rtems.org/rtems.git
>>>>                 <http://git.rtems.org/rtems.git>  => 5
>>>>                 I have attached the entire report, FYI. Does this
>>>>                 mean that git could not supply the source?
>>>>                 Pete.
>>>>                 On 05/30/2018 01:01 PM, Gedare Bloom wrote:
>>>>>                 Pete,
>>>>>                 On Wed, May 30, 2018 at 12:19 PM, D Peter Siddons<siddons at bnl.gov> <mailto:siddons at bnl.gov>  wrote:
>>>>>>                 Hi Gedare,
>>>>>>                     I didn't get your earlier email (?), but the answer is:
>>>>>>                 /home/peter/miniconda3/bin/python3.6
>>>>>>                 so the only way I have 3.6 is through miniconda. Maybe it expects
>>>>>>                 /usr/bin/python3.6?
>>>>>                 Odd that my email didn't come through to you. Anyway, since 'which'
>>>>>                 finds it, the paths seem correct. Alex' suggestion to install the
>>>>>                 development library is a good one however. I have had problems in the
>>>>>                 past with mixed Anaconda python installations and Ubuntu distro ones.
>>>>>                 I (like you) had the conda in a subdir of my home directory though, so
>>>>>                 I found it was easiest for me to just disable the conda paths e.g. by
>>>>>                 commenting out
>>>>>                 #export PATH="/home/gedare/anaconda3/bin:$PATH"
>>>>>                 in my .bashrc was sufficient for me
>>>>>                 Then, I could install/use the Ubuntu distributions Python2/3 packages
>>>>>                 without conflicts.
>>>>>                 Gedare
>>>>>>                 Pete.
>>>>>>                 On 05/30/2018 12:12 PM, Gedare Bloom wrote:
>>>>>>                 Alex,
>>>>>>                 Yes that also makes sense, thank you. Usually, I've seen that problem
>>>>>>                 manifest as missing Python.h, but error messages can be vague and
>>>>>>                 inconsistent. :)
>>>>>>                 On Wed, May 30, 2018 at 11:49 AM, Slide<slide.o.mix at gmail.com>
>>>>>>                 <mailto:slide.o.mix at gmail.com>  wrote:
>>>>>>                 I ran into a similar issue and the way I solved it was by installing the
>>>>>>                 -dev package for Python. For me this was libpython3-dev on Ubuntu. I'm not
>>>>>>                 sure how to do that with the Anaconda installation, but this may help point
>>>>>>                 you in the right direction.
>>>>>>                 Regards,
>>>>>>                 Alex
>>>>>>                 On Wed, May 30, 2018 at 6:57 AM Gedare Bloom<gedare at rtems.org> <mailto:gedare at rtems.org>  wrote:
>>>>>>                 Pete,
>>>>>>                 Do you get anything with:
>>>>>>                 $ which python3.6
>>>>>>                 Probably, it is looking for that invocation command. I ought to try
>>>>>>                 this, because my Ubuntu does not ship with python3.6 I know, so maybe
>>>>>>                 it breaks too... hm
>>>>>>                 On Mon, May 28, 2018 at 6:23 PM, Siddons, David<siddons at bnl.gov> <mailto:siddons at bnl.gov>  wrote:
>>>>>>                 Hi Amaan,
>>>>>>                     Actually,  /home/peter/miniconda3/bin/python is a soft link to
>>>>>>                 /home/peter/miniconda3/bin/python3.6 already! Does rsb not follow links?
>>>>>>                 Pete.
>>>>>>                 ________________________________
>>>>>>                 From: Amaan Cheval [amaan.cheval at gmail.com
>>>>>>                 <mailto:amaan.cheval at gmail.com>]
>>>>>>                 Sent: Monday, May 28, 2018 6:05 PM
>>>>>>                 To: Siddons, David
>>>>>>                 Cc:users at rtems.org <mailto:users at rtems.org>
>>>>>>                 Subject: Re: rsb problem with python
>>>>>>                 Hey David!
>>>>>>                 It looks to me like Anaconda doesn't install the "alias" binaries
>>>>>>                 specifying
>>>>>>                 the version (for eg. both "python" and "python3.6"). I believe the fix
>>>>>>                 in
>>>>>>                 your case should be as simple as copying your existing binary with the
>>>>>>                 following command:
>>>>>>                 cp /home/peter/miniconda3/bin/python
>>>>>>                 On Tue, May 29, 2018, 3:28 AM Siddons, David<siddons at bnl.gov> <mailto:siddons at bnl.gov>  wrote:
>>>>>>                 While building rsb for arm-rtems I got this problem:
>>>>>>                 checking for python... /home/peter/miniconda3/bin/python
>>>>>>                 checking for python3.6... no
>>>>>>                 configure: error: python is missing or unusable
>>>>>>                 Makefile:9095: recipe for target 'configure-gdb' failed
>>>>>>                 make[1]: *** [configure-gdb] Error 1
>>>>>>                 make[1]: Leaving directory
>>>>>>                 '/home/peter/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems5-gdb-8.0.1-x86_64-linux-gnu-1/build'
>>>>>>                 Makefile:848: recipe for target 'all' failed
>>>>>>                 make: *** [all] Error 2
>>>>>>                 shell cmd failed: /bin/sh -ex
>>>>>>                 /home/peter/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems5-gdb-8.0.1-x86_64-linux-gnu-1/doit
>>>>>>                 error: building
>>>>>>                 arm-rtems5-gdb-8.0.1-x86_64-linux-gnu-1peter at peter-Latitude-E7240:~/development/rtems/src/rtems-source-builder/rtems$
>>>>>>                 I am running Ubuntu:
>>>>>>                 peter at peter-Latitude-E7240:/etc$ lsb_release -a
>>>>>>                 LSB Version:
>>>>>>                 core-9.20160110ubuntu0.2-amd64:core-9.20160110ubuntu0.2-noarch:printing-9.20160110ubuntu0.2-amd64:printing-9.20160110ubuntu0.2-noarch:security-9.20160110ubuntu0.2-amd64:security-9.20160110ubuntu0.2-noarch
>>>>>>                 Distributor ID: Ubuntu
>>>>>>                 Description:    Ubuntu 16.04.4 LTS
>>>>>>                 Release:        16.04
>>>>>>                 Codename:       xenial
>>>>>>                 then:
>>>>>>                 python -V
>>>>>>                 Python 3.6.1 :: Continuum Analytics, Inc.
>>>>>>                 This comes from an Anaconda installation. If I remove the path entry
>>>>>>                 which
>>>>>>                 causes that I get python 2.7, which is the default Ubuntu 16.04
>>>>>>                 version. Do
>>>>>>                 I need to install Python 3.6?
>>>>>>                 Pete.
>>>>>>                 _______________________________________________
>>>>>>                 users mailing list
>>>>>>                 http://lists.rtems.org/mailman/listinfo/users
>>>>>>                 users mailing list
>>>>>>                 users mailing list
>>>>>>                 D. Peter Siddons
>>>>>>                 Detector Development Group Leader
>>>>>>                 Photon Science Division, NSLS-II,
>>>>>>                 Bldg. 535B
>>>>>>                 Brookhaven National Laboratory
>>>>>>                 Upton, NY 11973
>>>>>>                 email:siddons at bnl.gov <mailto:siddons at bnl.gov>
>>>>>>                 Phone:(631) 344-2738 <tel:%28631%29%20344-2738>
>>>>                 D. Peter Siddons
>>>>                 Bldg. 535B
>>>>                 Upton, NY 11973
>>>             D. Peter Siddons
>>>             Bldg. 535B
>>>             Upton, NY 11973
>>     D. Peter Siddons
>>     Bldg. 535B
>>     Upton, NY 11973
> D. Peter Siddons
> Bldg. 535B
> Upton, NY 11973
> Phone: (631) 344-2738
> users mailing list
> users at rtems.org
D. Peter Siddons
Bldg. 535B
Upton, NY 11973
email: siddons at bnl.gov
URL: <http://lists.rtems.org/pipermail/users/attachments/20180601/d1b722e8/attachment-0002.html>
