MVME3100 FPU Support on RTEMS 4.10.2
Matt Rippa
mrippa at gemini.edu
Fri Jun 8 04:15:54 UTC 2018
Hi Andrew,
Thanks for the info. When I heard RTEMS 5, I was still thinking EPICS
3.14.x.
So thanks for clarifying. I have a better sense of how much work this is.
It still
occurs to me that an mvme2500 RTEMS 4.10 option is possible. Sebastian, if
you see a way forward there, we would be interested.
I mentioned before that the 2500 is our best path. So now I guess that's
debatable.
That's based on price point and a suitable cpu for our applications.
Browsing the RTEMS BSP list, I see
the the 5500 as an option. Has anyone used this board on RTEMS with EPICS?
The 5500 is still offered and manufactured by Artesyn and the price is
around $4500.
-Matt
On Thu, Jun 7, 2018 at 11:52 AM, Andrew Johnson <anj at aps.anl.gov> wrote:
> Hi Matt,
> On 06/07/2018 03:20 PM, Matt Rippa wrote:
> > The 2500 path looks like our best choice. We can still use the
> > 6100/beatnik and 2700 boards in the mean time.
> While I agree tentatively about your choosing the 2500, you do need to
> be aware that Heinz's EPICS support for RTEMS 5 is aimed at EPICS 7 (it
> hasn't been merged yet), and the switch from RTEMS 4.10 to 5.x is not a
> minor change from our perspective.
> The Kernel APIs that our libCom/osi routines call had to be changed from
> the old RTEMS-native interfaces to the Posix ones of RTEMS-5, so there's
> quite a difference. We had to make changes to the EPICS build system for
> it to be possible to have two implementations of the same OS-dependent
> routines for the two different kernel APIs under the same OS_CLASS
> (since where possible the RTEMS-5 build should use our standard Posix
> implementations). We didn't want to introduce a new RTEMS5 OS_CLASS
> since that would break existing EPICS support modules which should
> otherwise still work (providing they only call our OSI APIs).
> It is also not possible to mix RTEMS versions in the same installation
> of EPICS Base, since EPICS RTEMS builds rely on Makefile configurations
> and rules from RTEMS' own build system. The RTEMS path and version must
> be set in the base/configure/os/CONFIG_SITE.Common.RTEMS file and cannot
> be overridden in a target-specific CONFIG file (because by the time
> those files get read in we've already read in a lot of RTEMS build
> configuration data).
> Sorry, just want you to know...
> - Andrew
> Arguing for surveillance because you have nothing to hide is no
> different than making the claim, "I don't care about freedom of
> speech because I have nothing to say." -- Edward Snowdon
URL: <http://lists.rtems.org/pipermail/users/attachments/20180607/38e61ed2/attachment-0002.html>
