Error building libbsd
Nicolas Tsiogkas lou.nick at gmail.com
Fri Jun 22 11:23:20 UTC 2018
Hi,
waf was downloaded by the website (waf.io)
niko at im-desktop-021:~/sandbox/rtems-libbsd$ which waf-2.0.8
/home/niko/.local/bin/waf-2.0.8
running also with waf-2.0.4 which used to work gives the same error
~/sandbox/rtems-libbsd$ waf-2.0.8 -v
Could not create the directory ///h
~/sandbox/rtems-libbsd$ waf-2.0.4 -v
that's pretty weird.
Regards,
Niko
On Fri, Jun 22, 2018 at 12:23 PM Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> Hello Niko,
> from a quick glance, everything till the waf call looks good. What is
> really odd is the output of the last waf-2.0.8 call. There should be a
> lot more output starting with something like
> Waf: Entering directory
> `/home/EB/christian_m/Projekte/some-project/rtems-libbsd/build/arm-rtems5-atsamv-everything'
> [  1/122] Creating
> build/arm-rtems5-atsamv-everything/build-include/rtems/bsd/modules.h
> [  2/122] Compiling rtemsbsd/rtems/generate_kvm_symbols
> [  3/122] Compiling testsuite/include/rtems/bsd/test/network-config.h.in
> [  4/122] Compiling freebsd/sys/crypto/blowfish/bf_locl.h
> [  5/122] Compiling freebsd/sys/crypto/blowfish/bf_pi.h
> You are even missing the "Waf: Entering directory". So that seems like a
> quite early bug.
> You can try whether a `waf -v` provides more output. Beneath that: Where
> does your waf come from? You call it with a version number.
> Best regards
> Christian Mauderer
> Am 22.06.2018 um 11:21 schrieb Nicolas Tsiogkas:
> > Hi,
> > I did the process again with no luck. I am attaching a zip with command
> > outputs/logs.
> > Regards,
> > Niko
> > On Fri, Jun 22, 2018 at 9:44 AM Nicolas Tsiogkas <lou.nick at gmail.com
> > <mailto:lou.nick at gmail.com>> wrote:
> >     Hi Christian,
> >     it is a fresh clone. Although I had a previous build with 4.11 I
> >     decided try from scratch given the changes.
> >     Error is during the build. I'm configuring normally and when I try
> >     to waf it then it fails.
> >     Is there any way to increase the verbosity? I will repeat all the
> >     process from scratch keeping logs so I can send them and try to find
> >     the issue.
> >     Thanks for your time!
> >     Regards,
> >     Niko
> >     On Thu, Jun 21, 2018 at 6:49 PM Christian Mauderer
> >     <list at c-mauderer.de <mailto:list at c-mauderer.de>> wrote:
> >         Am 21.06.2018 um 16:26 schrieb Nicolas Tsiogkas:
> >         > And apparently I forgot the host.
> >         > It is ubuntu 16.04:
> >         > Linux im-desktop-021 4.13.0-45-generic #50~16.04.1-Ubuntu SMP
> >         Wed May 30
> >         > 11:18:27 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
> >         > gcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.9)
> >         > N.
> >         > On Thu, Jun 21, 2018 at 4:19 PM Nicolas Tsiogkas
> >         <lou.nick at gmail.com <mailto:lou.nick at gmail.com>
> >         > <mailto:lou.nick at gmail.com <mailto:lou.nick at gmail.com>>>
> wrote:
> >         >     Hi Joel,
> >         >      waf-2.0.8 configure --prefix="$sandbox/5"
> >         >     --rtems-bsps=arm/xilinx_zynq_a9_qemu
> >         >     has the following output:
> >         >     Setting top to                           :
> >         >     /home/niko/sandbox/rtems-libbsd
> >         >     Setting out to                           :
> >         >     /home/niko/sandbox/rtems-libbsd/build
> >         >     RTEMS Version                            : 5
> >         >     Architectures                            : arm-rtems5
> >         >     Board Support Package                    :
> >         >     arm-rtems5-xilinx_zynq_a9_qemu
> >         >     Show commands                            : no
> >         >     Long commands                            : no
> >         >     Checking for program 'arm-rtems5-gcc'    :
> >         >     /home/niko/sandbox/5/bin/arm-rtems5-gcc
> >         >     Checking for program 'arm-rtems5-g++'    :
> >         >     /home/niko/sandbox/5/bin/arm-rtems5-g++
> >         >     Checking for program 'arm-rtems5-ld'     :
> >         >     /home/niko/sandbox/5/bin/arm-rtems5-ld
> >         >     Checking for program 'arm-rtems5-ar'     :
> >         >     /home/niko/sandbox/5/bin/arm-rtems5-ar
> >         >     Checking for program 'arm-rtems5-nm'     :
> >         >     /home/niko/sandbox/5/bin/arm-rtems5-nm
> >         >     Checking for program 'arm-rtems5-objdump' :
> >         >     /home/niko/sandbox/5/bin/arm-rtems5-objdump
> >         >     Checking for program 'arm-rtems5-objcopy' :
> >         >     /home/niko/sandbox/5/bin/arm-rtems5-objcopy
> >         >     Checking for program 'arm-rtems5-readelf' :
> >         >     /home/niko/sandbox/5/bin/arm-rtems5-readelf
> >         >     Checking for program 'arm-rtems5-strip'   :
> >         >     /home/niko/sandbox/5/bin/arm-rtems5-strip
> >         >     Checking for program 'rtems-ld'           :
> >         >     /home/niko/sandbox/5/bin/rtems-ld
> >         >     Checking for program 'rtems-tld'          :
> >         >     /home/niko/sandbox/5/bin/rtems-tld
> >         >     Checking for program 'rtems-bin2c'        :
> >         >     /home/niko/sandbox/5/bin/rtems-bin2c
> >         >     Checking for program 'tar'                : /bin/tar
> >         >     Checking for program 'gcc, cc'            :
> >         >     Checking for program 'ar'                 :
> >         >     Checking for program 'g++, c++'           :
> >         >     Checking for program 'gas, gcc'           :
> >         >     Compiler version (arm-rtems5-gcc)         : 7.3.0 20180125
> >         (RTEMS 5,
> >         >     RSB 8ee4e8cd557c25fca59bb9751751ad4172530958, Newlib
> 3.0.0)
> >         >     Checking for RTEMS CPU options header     : started
> >         >     -> processing test results                : all ok
> >         >     Checking for RTEMS_DEBUG                  : no
> >         >     Checking for RTEMS_MULTIPROCESSING        : no
> >         >     Checking for RTEMS_NEWLIB                 : yes
> >         >     Checking for RTEMS_POSIX_API              : yes
> >         >     Checking for RTEMS_SMP                    : no
> >         >     Checking for RTEMS_NETWORKING             : no
> >         >     Checking for RTEMS header                 : started
> >         >     Checking for header dlfcn.h               : yes
> >         >     Checking for header rtems/pci.h           : yes
> >         >     Configure variant:                        :
> >         >     arm-rtems5-xilinx_zynq_a9_qemu-default
> >         >     Checking for header rtems/rtems-debugger.h : yes
> >         >     'configure' finished successfully (0.744s)
> >         >     Cheers,
> >         >     Niko
> >         >     On Thu, Jun 21, 2018 at 4:09 PM Joel Sherrill
> >         <joel at rtems.org <mailto:joel at rtems.org>
> >         >     <mailto:joel at rtems.org <mailto:joel at rtems.org>>> wrote:
> >         >         On Thu, Jun 21, 2018 at 8:52 AM, Nicolas Tsiogkas
> >         <mailto:lou.nick at gmail.com <mailto:lou.nick at gmail.com>>> wrote:
> >         >             Hi,
> >         >             following the steps described
> >         >             in https://github.com/RTEMS/rtems-libbsd I get an
> >         error
> >         >             "Could not create the directory ///h" while trying
> >         to build
> >         >             with waf 2.0.8
> >         >             Is it a known problem?
> >         >         Not to me.
> >         >         What's your configure command and host?
> >         >             I have seen that the installation procedure has
> >         changed
> >         >             since 4.11 and now the tools and the bsps are
> >         installed in
> >         >             the same prefix, but that shouldn't matter I
> suppose.
> >         >             Thank you in advance.
> >         >             Regards,
> >         >             Niko
> >         >             _______________________________________________
> >         >             users mailing list
> >         >             users at rtems.org <mailto:users at rtems.org>
> >         <mailto:users at rtems.org <mailto:users at rtems.org>>
> >         >             http://lists.rtems.org/mailman/listinfo/users
> >         > users mailing list
> >         Hello Nicolas,
> >         I also don't know that problem. The directory that should be
> created
> >         "///h" looks like there are some variables missing between the
> >         slashes.
> >         But I'm not aware of any directory h that should be created
> >         somewhere.
> >         - Did you upgrade from a earlier build or do you build in a fresh
> >         checkout? There have been some changes to the build system in
> >         the last
> >         months that have lead to incompatible cache files. If it is an
> >         old tree,
> >         try to remove `build` and `.lock-waf_*`.
> >         - About when does the problem happen? It seems your configure
> >         runs fine.
> >         So I assume that it appears during build or install. Maybe you
> could
> >         provide some lines of context to the error message?
> >         Best regards
> >         Christian Mauderer
> embedded brains GmbH
> Herr Christian Mauderer
> Dornierstr. 4
> D-82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> Phone: +49-89-18 94 741 - 18
> Fax:   +49-89-18 94 741 - 08
> PGP: Public key available on request.
URL: <http://lists.rtems.org/pipermail/users/attachments/20180622/303ceee2/attachment-0002.html>
