GSoC'18-Introduction
Christian Mauderer christian.mauderer at embedded-brains.de
Thu Mar 1 07:08:21 UTC 2018
Am 28.02.2018 um 05:52 schrieb Chris Johns:
> On 28/02/2018 15:37, Christian Mauderer wrote:
>> Yes, seems that I misunderstood it. So OpenOCD will remain on top of the recommendation list.
> For open solutions currently it seems so.
>>>> As a positive report: I have a quite stable setup with the Segger J-Link
>>>> EDU.
>>> I do not run Linux and do not put Macs close to hardware so I cannot run their
>>> closed source GDB server. I will stick with a fully open solution I can control
>>> and fix.
>> Most of the time I prefere open solutions too. I had some problems with OpenOCD on another target and bought the J-Link for that one. I only re-used it for the Beagle and it run quite well.
> Nice. Please add it to the Wiki and some instructions if you feel it is needed.
> It should be up to users to decide based on their needs and budget.
I'll add a section with the scripts that I used for debugging.
>>>> The EDU is a affordable variant with the disadvantage that it must
>>>> only be used for non-commericial purpose.
>>> Ouch, messy. If I am paid to work on open source is that a non-commmercial
>>> purpose or commercial purpose? What if I am paid more for coding and I debug for
>>> free? ;)
>> Same problem as allways with licensing. I would expect that GSoC is more educationall than commercial. But it's an edge case.
> Agreed.
I have been on the embedded world trade show yesterday and talked to one
of the people on the Segger booth. He has seen no problem if GSoC
students use the EDU version of the debugger.
>> For my applications I dont have a problem to distinguish because we have another debugger at work. So I can separate these quite well.
> For a BBB? I think we should list solutions, commercial or open, cheap or expensive.
Currently I don't have a BBB project at work. So I currently don't have
ready made debugger scripts for the debugger we use there most of the time.
Regards
Christian
> Chris
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
