error: checksum failure file: sources/expat-2.1.0.tar.gz
Fri Mar 2 00:09:43 UTC 2018
On 02/03/2018 01:53, leonardo wrote:
> I am try to download RTEMS source builder and build a tool chain following the
> instruction in this page
> <https://docs.rtems.org/branches/master/user/start/index.html>. The problem that
> I have seems to be a package download automatically through /sourceforge.net/:
> it seems that the chacksum is different. Here the hot part of the log file:
> |source setup: expat-2.1.0-x86_64-linux-gnu-1: source expat -q -n expat-2.1.0
> making dir: /home/leonardo/development/rtems/rsb/rtems/sources download: (full)
> http://downloads.sourceforge.net/project/expat/expat/2.1.0/expat-2.1.0.tar.gz ->
> sources/expat-2.1.0.tar.gz download:
> sources/expat-2.1.0.tar.gz redirect:
> https://downloads.sourceforge.net/#!/project/expat/expat/2.1.0/expat-2.1.0.tar.gz redirect:
> https://downloads.sourceforge.net/#!/project/expat/expat/2.1.0/expat-2.1.0.tar.gz checksums:
> expat-2.1.0.tar.gz:
> 7a07d3f7cca5c0b38ca811984ef8da536da32932d68c1a6cce33ec2462b930bf =>
> 823705472f816df21c8f6aa026dd162b280806838bb55b3432b0fb1fcca7eb86 warning:
> checksum error: expat-2.1.0.tar.gz error: checksum failure file:
> sources/expat-2.1.0.tar.gz |
I can confirm this is happening. Looking in the downloaded file I see:
 We're sorry -- the Sourceforge site is currently in Disaster
 Recovery mode, and currently requires the use of javascript to
 function.  Please check back later.
The link https://sourceforge.net/blog/ gives you a 404 error. Looks like there
are others seeing this ...
 http://downdetector.com/status/sourceforge
Hmmm it has been over 23 hours since SF tweeted to @sfnet_ops there is a problem.
It is tempting to have the RSB point to ftp.rtems.org before a project's home
sites for branches. For releases the RSB does this because a release is static
and the net can change over time. The problem with doing this is not see a
change in a project and we do not know.
