Instalation failed
mfg
mfg at ugr.es
Fri Mar 2 08:29:07 UTC 2018
Hello to everybody,
I tried to install again for a test and it fails. Does it happen to
someone else?
I used:
git clone https://github.com/RTEMS/rtems-source-builder.git
cd rtems-source-builder
source-builder/sb-check
cd rtems
../source-builder/sb-set-builder --log=l-arm.txt --prefix=$HOME/rtems5
5/rtems-arm
In the terminal:
download:
http://downloads.sourceforge.net/project/expat/expat/2.1.0/expat-2.1.0.tar.gz
-> sources/expat-2.1.0.tar.gz
download:
http://downloads.sourceforge.net/project/expat/expat/2.1.0/expat-2.1.0.tar.gz:
error: <urlopen error [Errno 1] _ssl.c:510: error:14077410:SSL
routines:SSL23_GET_SERVER_HELLO:sslv3 alert handshake failure>
error: downloading
all paths have failed, giving up
Build FAILED
See error report: rsb-report-expat-2.1.0-x86_64-linux-gnu-1.txt
error: downloading
Build Set: Time 0:00:14.850048
Build FAILED
Thanks in advance
