Instalation failed
mfg mfg at ugr.es
Fri Mar 2 08:37:12 UTC 2018
Sorry I didn't see the Chris answer:
I can confirm this is happening. Looking in the downloaded file I see:
  We're sorry -- the Sourceforge site is currently in Disaster
  Recovery mode, and currently requires the use of javascript to
  function.  Please check back later.
The link https://sourceforge.net/blog/ gives you a 404 error. Looks
like there
are others seeing this ...
  http://downdetector.com/status/sourceforge
Hmmm it has been over 23 hours since SF tweeted to @sfnet_ops there is
a problem.
It is tempting to have the RSB point to ftp.rtems.org before a
project's home
sites for branches. For releases the RSB does this because a release is
static
and the net can change over time. The problem with doing this is not
see a
change in a project and we do not know.
El 2018-03-02 09:29, mfg escribió:
> Hello to everybody,
> I tried to install again for a test and it fails. Does it happen to
> someone else?
> I used:
> git clone https://github.com/RTEMS/rtems-source-builder.git
> cd rtems-source-builder
> source-builder/sb-check
> cd rtems
> ../source-builder/sb-set-builder --log=l-arm.txt
> --prefix=$HOME/rtems5 5/rtems-arm
> In the terminal:
> download:
> http://downloads.sourceforge.net/project/expat/expat/2.1.0/expat-2.1.0.tar.gz
> -> sources/expat-2.1.0.tar.gz
> download:
> http://downloads.sourceforge.net/project/expat/expat/2.1.0/expat-2.1.0.tar.gz:
> error: <urlopen error [Errno 1] _ssl.c:510: error:14077410:SSL
> routines:SSL23_GET_SERVER_HELLO:sslv3 alert handshake failure>
> error: downloading
> all paths have failed, giving up
> Build FAILED
>   See error report: rsb-report-expat-2.1.0-x86_64-linux-gnu-1.txt
> error: downloading
> Build Set: Time 0:00:14.850048
> Build FAILED
> Thanks in advance
