Instalation failed
Pierre FICHEUX pierre.ficheux at smile.fr
Fri Mar 2 23:34:30 UTC 2018
Hi,
I just got the archive from
https://sourceforge.net/projects/expat/files/expat/2.0.1/expat-2.0.1.tar.gz/download
then save it to rtems-source-builder/rtems/sources.
regards
Pierre FICHEUX -/- CTO Smile ECS, France -\- pierre.ficheux at smile.fr
                              http://www.smile.fr
                              https://smile.eu/fr/offres/embarque-iot
I would love to change the world, but they won't give me the source
code
Le 2018-03-02 09:37, mfg a écrit :
> Sorry I didn't see the Chris answer:
> I can confirm this is happening. Looking in the downloaded file I see:
>  We're sorry -- the Sourceforge site is currently in Disaster
>  Recovery mode, and currently requires the use of javascript to
>  function.  Please check back later.
> The link https://sourceforge.net/blog/ gives you a 404 error. Looks
> like there
> are others seeing this ...
>  http://downdetector.com/status/sourceforge
> Hmmm it has been over 23 hours since SF tweeted to @sfnet_ops there
> is a problem.
> It is tempting to have the RSB point to ftp.rtems.org before a
> project's home
> sites for branches. For releases the RSB does this because a release
> is static
> and the net can change over time. The problem with doing this is not
> see a
> change in a project and we do not know.
> El 2018-03-02 09:29, mfg escribió:
>> Hello to everybody,
>> I tried to install again for a test and it fails. Does it happen to
>> someone else?
>> I used:
>> git clone https://github.com/RTEMS/rtems-source-builder.git
>> cd rtems-source-builder
>> source-builder/sb-check
>> cd rtems
>> ../source-builder/sb-set-builder --log=l-arm.txt
>> --prefix=$HOME/rtems5 5/rtems-arm
>> In the terminal:
>> download:
>> http://downloads.sourceforge.net/project/expat/expat/2.1.0/expat-2.1.0.tar.gz
>> -> sources/expat-2.1.0.tar.gz
>> download:
>> http://downloads.sourceforge.net/project/expat/expat/2.1.0/expat-2.1.0.tar.gz:
>> error: <urlopen error [Errno 1] _ssl.c:510: error:14077410:SSL
>> routines:SSL23_GET_SERVER_HELLO:sslv3 alert handshake failure>
>> error: downloading
>> all paths have failed, giving up
>> Build FAILED
>>   See error report: rsb-report-expat-2.1.0-x86_64-linux-gnu-1.txt
>> error: downloading
>> Build Set: Time 0:00:14.850048
>> Build FAILED
>> Thanks in advance
> users mailing list
> users at rtems.org
