Instalation failed
Pierre FICHEUX pierre.ficheux at smile.fr
Fri Mar 2 23:36:47 UTC 2018
Sorry: Sorry:
https://sourceforge.net/projects/expat/files/expat/2.1.0/expat-2.1.0.tar.gz/download
Pierre FICHEUX -/- CTO Smile ECS, France -\- pierre.ficheux at smile.fr
                              http://www.smile.fr
                              https://smile.eu/fr/offres/embarque-iot
I would love to change the world, but they won't give me the source
code
Le 2018-03-03 00:34, Pierre FICHEUX a écrit :
> Hi,
> I just got the archive from
> https://sourceforge.net/projects/expat/files/expat/2.0.1/expat-2.0.1.tar.gz/download
> then save it to rtems-source-builder/rtems/sources.
> regards
>                              http://www.smile.fr
> code
> Le 2018-03-02 09:37, mfg a écrit :
>> Sorry I didn't see the Chris answer:
>> I can confirm this is happening. Looking in the downloaded file I
>> see:
>> We're sorry -- the Sourceforge site is currently in Disaster
>>  Recovery mode, and currently requires the use of javascript to
>>  function.  Please check back later.
>> The link https://sourceforge.net/blog/ gives you a 404 error. Looks
>> like there
>> are others seeing this ...
>> http://downdetector.com/status/sourceforge
>> Hmmm it has been over 23 hours since SF tweeted to @sfnet_ops there
>> is a problem.
>> It is tempting to have the RSB point to ftp.rtems.org before a
>> project's home
>> sites for branches. For releases the RSB does this because a release
>> is static
>> and the net can change over time. The problem with doing this is not
>> see a
>> change in a project and we do not know.
>> El 2018-03-02 09:29, mfg escribió:
>>> Hello to everybody,
>>> I tried to install again for a test and it fails. Does it happen to
>>> someone else?
>>> I used:
>>> git clone https://github.com/RTEMS/rtems-source-builder.git
>>> cd rtems-source-builder
>>> source-builder/sb-check
>>> cd rtems
>>> ../source-builder/sb-set-builder --log=l-arm.txt
>>> --prefix=$HOME/rtems5 5/rtems-arm
>>> In the terminal:
>>> download:
>>> http://downloads.sourceforge.net/project/expat/expat/2.1.0/expat-2.1.0.tar.gz
>>> -> sources/expat-2.1.0.tar.gz
>>> download:
>>> http://downloads.sourceforge.net/project/expat/expat/2.1.0/expat-2.1.0.tar.gz:
>>> error: <urlopen error [Errno 1] _ssl.c:510: error:14077410:SSL
>>> routines:SSL23_GET_SERVER_HELLO:sslv3 alert handshake failure>
>>> error: downloading
>>> all paths have failed, giving up
>>> Build FAILED
>>>   See error report: rsb-report-expat-2.1.0-x86_64-linux-gnu-1.txt
>>> error: downloading
>>> Build Set: Time 0:00:14.850048
>>> Build FAILED
>>> Thanks in advance
>> users mailing list
>> users at rtems.org
