Crash deep in heap allocation for rtems_region_get_segment() call
Wed Mar 7 14:47:08 UTC 2018
Hello Matthew,
it is very likely not a bug in the heap code. It is probably a use after
free or heap block overwrite. You can use the --enable-rtems-debug
configuration option to enable a heap protections which helps to catch
these application errors.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
