Fwd: Quickstart Build instructions
Russell Haley
russ.haley at gmail.com
Wed Mar 28 05:51:26 UTC 2018
---------- Forwarded message ----------
Date: Tue, Mar 27, 2018 at 10:45 PM
Subject: Re: Quickstart Build instructions
To: Sebastian Huber <sebastian.huber at embedded-brains.de>
On Tue, Mar 27, 2018 at 10:36 PM, Sebastian Huber <sebastian.huber at embedded-
brains.de> wrote:
> Please send e-mails to the mailing list.
Sorry, my mistake.
> On 28/03/18 07:34, Russell Haley wrote:
>> Where did the directory 5 come from in these instructions? Are you
>> missing a mkdir?
> The
> --prefix=/usr/home/chris/development/rtems/5
> directory is created by the sb-set-builder. It is the base installation
> directory.
I was getting a directory not writeable error until I created the folder
myself (even after correcting for my username). I'll try again later, but
it builds if I create the 5/ directory.
Thanks,
Russ
> $cd
>> $ mkdir -p development/rtems
>> $cd development/rtems
>> $ git clone git://git.rtems.org/rtems-source-builder.git <
>> http://git.rtems.org/rtems-source-builder.git> rsb
>> $cd rsb
>> $ ./source-builder/sb-check
>> $cd rtems
>> $ ../source-builder/sb-set-builder\
>> --prefix=/usr/home/chris/development/rtems/55/rtems-sparc
>> Thanks,
>> Russ
>> On Tue, Mar 27, 2018 at 10:28 PM, Russell Haley <russ.haley at gmail.com
>> <mailto:russ.haley at gmail.com>> wrote:
>> Thanks!
>> Russ
>> On Tue, Mar 27, 2018 at 10:23 PM, Sebastian Huber
>> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>> On 28/03/18 07:14, Russell Haley wrote:
>> Hi, the quick start indicates using ./bootstrap -p, but
>> using said parameter only results in the error/hep output.
>> Using ./bootstrap without any parameters started the the
>> process for me?
>> https://docs.rtems.org/branches/master/user/start/index.html
>> <https://docs.rtems.org/branches/master/user/start/index.html
>> Sorry for the confusion. I updated the documentation:
>> https://git.rtems.org/rtems-docs/commit/?id=fc9db4c26eb66b1b
>> 94f79617d850d2b0f161c00e
>> <https://git.rtems.org/rtems-docs/commit/?id=fc9db4c26eb66b1
>> b94f79617d850d2b0f161c00e>
>> -- Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim,
>> <https://maps.google.com/?q=dress+:+Dornierstr.+4,+D-82178+P
>> uchheim,&entry=gmail&source=g>
>> Germany
>> Phone : +49 89 189 47 41-16 <tel:%2B49%2089%20189%2047%2041-16>
>> Fax : +49 89 189 47 41-09 <tel:%2B49%2089%20189%2047%2041-09>
>> E-Mail : sebastian.huber at embedded-brains.de
>> PGP : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne
>> des EHUG.
URL: <http://lists.rtems.org/pipermail/users/attachments/20180327/adb36f00/attachment-0001.html>
