Quickstart Build instructions
Joel Sherrill
joel at rtems.org
Wed Mar 28 13:48:55 UTC 2018
On Wed, Mar 28, 2018 at 12:51 AM, Russell Haley <russ.haley at gmail.com>
wrote:
> ---------- Forwarded message ----------
> From: Russell Haley <russ.haley at gmail.com>
> Date: Tue, Mar 27, 2018 at 10:45 PM
> Subject: Re: Quickstart Build instructions
> To: Sebastian Huber <sebastian.huber at embedded-brains.de>
> On Tue, Mar 27, 2018 at 10:36 PM, Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> Please send e-mails to the mailing list.
> Sorry, my mistake.
>> On 28/03/18 07:34, Russell Haley wrote:
>>> Where did the directory 5 come from in these instructions? Are you
>>> missing a mkdir?
>> The
>> --prefix=/usr/home/chris/development/rtems/5
>> directory is created by the sb-set-builder. It is the base installation
>> directory.
> I was getting a directory not writeable error until I created the folder
> myself (even after correcting for my username). I'll try again later, but
> it builds if I create the 5/ directory.
What is your $HOME? Mine is usually /home/joel. If yours is similar, then
not being able to write into /usr as non-root is expected.
Perhaps the documentation should say ${HOME}/development/rtems/5?
FWIW Around OAR, we tend to use ${HOME}/rtems-work/tools/5 or for
wider deployments /rtems/5
--joel
> Thanks,
> Russ
>> $cd
>>> $ mkdir -p development/rtems
>>> $cd development/rtems
>>> $ git clone git://git.rtems.org/rtems-source-builder.git <
>>> http://git.rtems.org/rtems-source-builder.git> rsb
>>> $cd rsb
>>> $ ./source-builder/sb-check
>>> $cd rtems
>>> $ ../source-builder/sb-set-builder\
>>> --prefix=/usr/home/chris/development/rtems/55/rtems-sparc
>>> Thanks,
>>> Russ
>>> On Tue, Mar 27, 2018 at 10:28 PM, Russell Haley <russ.haley at gmail.com
>>> <mailto:russ.haley at gmail.com>> wrote:
>>> Thanks!
>>> Russ
>>> On Tue, Mar 27, 2018 at 10:23 PM, Sebastian Huber
>>> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>>> On 28/03/18 07:14, Russell Haley wrote:
>>> Hi, the quick start indicates using ./bootstrap -p, but
>>> using said parameter only results in the error/hep output.
>>> Using ./bootstrap without any parameters started the the
>>> process for me?
>>> https://docs.rtems.org/branches/master/user/start/index.html
>>> <https://docs.rtems.org/branches/master/user/start/index.htm
>>> l>
>>> Sorry for the confusion. I updated the documentation:
>>> https://git.rtems.org/rtems-docs/commit/?id=fc9db4c26eb66b1b
>>> 94f79617d850d2b0f161c00e
>>> <https://git.rtems.org/rtems-docs/commit/?id=fc9db4c26eb66b1
>>> b94f79617d850d2b0f161c00e>
>>> -- Sebastian Huber, embedded brains GmbH
>>> Address : Dornierstr. 4, D-82178 Puchheim,
>>> <https://maps.google.com/?q=dress+:+Dornierstr.+4,+D-82178+P
>>> uchheim,&entry=gmail&source=g>
>>> Germany
>>> Phone : +49 89 189 47 41-16 <tel:%2B49%2089%20189%2047%204
>>> 1-16>
>>> Fax : +49 89 189 47 41-09 <tel:%2B49%2089%20189%2047%204
>>> 1-09>
>>> E-Mail : sebastian.huber at embedded-brains.de
>>> PGP : Public key available on request.
>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne
>>> des EHUG.
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20180328/87d532f8/attachment.html>
