Task context information available on crash
Matthew J Fletcher amimjf at gmail.com
Tue Mar 20 10:49:06 UTC 2018
Thank you for the advice.
So i can see that the executing task was "TIME", which is the timer server.
So the problem is almost certainly a bad function pointer passed as the
routine to invoke.
I can place a breakpoint in timerserver.c, but the crash is after several
minutes (and many tens of thousands of timer operations).
I think i will have to modify _Timer_server_Body() to copy the timer id to
a global variable so i can inspect it after an exception.
Unless there is a better way ?
On 20 March 2018 at 06:21, Sebastian Huber <
> On 19/03/18 18:36, Matthew J Fletcher wrote:
>> Hi,
>> When an application crashes and the bsp_fatal_extension() is invoked, is
>> there a way to see (in gdb or otherwise) what the last executing task was ?
>> I guess there is some task context maintained but it would be internal to
>> rtems.
> You can get the executing thread (and some other variables) from the
> global _Per_CPU_Information[], e.g.
> (gdb) p/x _Per_CPU_Information [0].per_cpu.executing->Object.id
> $1 = 0xa010001
regards
Matthew J Fletcher
URL: <http://lists.rtems.org/pipermail/users/attachments/20180320/76dc3425/attachment-0002.html>
