Quickstart Build instructions
Russell Haley
russ.haley at gmail.com
Wed Mar 28 05:21:10 UTC 2018
On Tue, Mar 27, 2018 at 10:14 PM, Russell Haley <russ.haley at gmail.com>
wrote:
> Hi, the quick start indicates using ./bootstrap -p, but using said
> parameter only results in the error/hep output. Using ./bootstrap without
> any parameters started the the process for me?
> https://docs.rtems.org/branches/master/user/start/index.html
> Sorry, I'm tired and forgot half the email:
I'm attempting to build on FreeBSD 11.
pwd
/usr/home/russellh/development/rtems/kernel/rtems
russellh at g1 ~/d/r/k/rtems> uname -a
FreeBSD g1.highfell.home 11.1-RELEASE-p4 FreeBSD 11.1-RELEASE-p4 #0: Tue
Nov 14 06:12:40 UTC 2017
root at amd64-builder.daemonology.net:/usr/obj/usr/src/sys/GENERIC
amd64
russellh at g1 ~/d/r/k/rtems> ./bootstrap -h
usage: bootstrap [-c|-p|-h] [-q][-v]
options:
-c .. clean, remove all aclocal/autoconf/automake generated files
-h .. display this message and exit
-H .. regenerate headers.am files
-q .. quiet, don't display directories
-v .. verbose, pass -v to autotools
russellh at g1 ~/d/r/k/rtems> ./bootstrap -p
unknown option -p
options:
echo $SHELL
/usr/local/bin/fish
Thanks,
> Russ
URL: <http://lists.rtems.org/pipermail/users/attachments/20180327/5cf3cd38/attachment-0002.html>
