Lua was Re: Quickstart Build instructions
Russell Haley
russ.haley at gmail.com
Fri Mar 30 19:48:48 UTC 2018
On Fri, Mar 30, 2018 at 7:54 AM, Joel Sherrill <joel at rtems.org> wrote:
> On Fri, Mar 30, 2018 at 1:05 AM, Russell Haley <russ.haley at gmail.com>
> wrote:
>> Thanks Joel. I haven't looped back to test if it was my mistake or
>> something else so I'll assume my mistake for now.
>> Either way, I'm able to build and run the examples_v2 repository against
>> erc32, so... YAY!
>> I'd like to build Lua 5.3, do I just build the static lib "a" file and
>> include it in a test application? Would that happen in RTEMS proper or in
>> waf? I need sleep now but any suggestions would be grand.
> Porting Lua was an early GSoC project. Some information is here.:
> https://devel.rtems.org/wiki/Packages/LUA
> That effort predates the RSB but the proper solution would be to have
> an RSB recipe for it. My understanding is that it was quite easy to build
> for RTEMS.
> https://github.com/lparam/rtems-liblua appears to be enough to help you
> build it.
> Needs an RSB recipe though. :)
That would be great. I've managed to get lua 5.3 built and installed from
the github repo by lparam. I've run out of time but will clean it up
tonight. The SGOC link seems to be pointing to a modified/extended lua
build and the link to the source code is dead.
I'll try modifying the hello world example tonight as well and see what I
get.
Thanks everyone!
Russ
> --joel
>> Thanks!
>> Russ
>> On Wed, Mar 28, 2018 at 6:48 AM, Joel Sherrill <joel at rtems.org> wrote:
>>> On Wed, Mar 28, 2018 at 12:51 AM, Russell Haley <russ.haley at gmail.com>
>>> wrote:
>>>> ---------- Forwarded message ----------
>>>> From: Russell Haley <russ.haley at gmail.com>
>>>> Date: Tue, Mar 27, 2018 at 10:45 PM
>>>> Subject: Re: Quickstart Build instructions
>>>> To: Sebastian Huber <sebastian.huber at embedded-brains.de>
>>>> On Tue, Mar 27, 2018 at 10:36 PM, Sebastian Huber <
>>>> sebastian.huber at embedded-brains.de> wrote:
>>>>> Please send e-mails to the mailing list.
>>>> Sorry, my mistake.
>>>>> On 28/03/18 07:34, Russell Haley wrote:
>>>>>> Where did the directory 5 come from in these instructions? Are you
>>>>>> missing a mkdir?
>>>>> The
>>>>> --prefix=/usr/home/chris/development/rtems/5
>>>>> directory is created by the sb-set-builder. It is the base
>>>>> installation directory.
>>>> I was getting a directory not writeable error until I created the
>>>> folder myself (even after correcting for my username). I'll try again
>>>> later, but it builds if I create the 5/ directory.
>>> What is your $HOME? Mine is usually /home/joel. If yours is similar, then
>>> not being able to write into /usr as non-root is expected.
>>> Perhaps the documentation should say ${HOME}/development/rtems/5?
>>> FWIW Around OAR, we tend to use ${HOME}/rtems-work/tools/5 or for
>>> wider deployments /rtems/5
>>> --joel
>>>> Thanks,
>>>> Russ
>>>>> $cd
>>>>>> $ mkdir -p development/rtems
>>>>>> $cd development/rtems
>>>>>> $ git clone git://git.rtems.org/rtems-source-builder.git <
>>>>>> http://git.rtems.org/rtems-source-builder.git> rsb
>>>>>> $cd rsb
>>>>>> $ ./source-builder/sb-check
>>>>>> $cd rtems
>>>>>> $ ../source-builder/sb-set-builder\
>>>>>> --prefix=/usr/home/chris/development/rtems/55/rtems-sparc
>>>>>> Thanks,
>>>>>> Russ
>>>>>> On Tue, Mar 27, 2018 at 10:28 PM, Russell Haley <russ.haley at gmail.com
>>>>>> <mailto:russ.haley at gmail.com>> wrote:
>>>>>> Thanks!
>>>>>> Russ
>>>>>> On Tue, Mar 27, 2018 at 10:23 PM, Sebastian Huber
>>>>>> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>>>>>> On 28/03/18 07:14, Russell Haley wrote:
>>>>>> Hi, the quick start indicates using ./bootstrap -p, but
>>>>>> using said parameter only results in the error/hep output.
>>>>>> Using ./bootstrap without any parameters started the the
>>>>>> process for me?
>>>>>> https://docs.rtems.org/branche
>>>>>> s/master/user/start/index.html
>>>>>> <https://docs.rtems.org/branch
>>>>>> es/master/user/start/index.html>
>>>>>> Sorry for the confusion. I updated the documentation:
>>>>>> https://git.rtems.org/rtems-docs/commit/?id=fc9db4c26eb66b1b
>>>>>> 94f79617d850d2b0f161c00e
>>>>>> <https://git.rtems.org/rtems-docs/commit/?id=fc9db4c26eb66b1
>>>>>> b94f79617d850d2b0f161c00e>
>>>>>> -- Sebastian Huber, embedded brains GmbH
>>>>>> Address : Dornierstr. 4, D-82178 Puchheim
>>>>>> <https://maps.google.com/?q=Dornierstr.+4,+D-82178+Puchheim&entry=gmail&source=g>
>>>>>> <https://maps.google.com/?q=dress+:+Dornierstr.+4,+D-82178+P
>>>>>> uchheim,&entry=gmail&source=g>
>>>>>> Germany
>>>>>> Phone : +49 89 189 47 41-16 <tel:%2B49%2089%20189%2047%204
>>>>>> 1-16>
>>>>>> Fax : +49 89 189 47 41-09 <tel:%2B49%2089%20189%2047%204
>>>>>> 1-09>
>>>>>> E-Mail : sebastian.huber at embedded-brains.de
>>>>>> PGP : Public key available on request.
>>>>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne
>>>>>> des EHUG.
>>>>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>>>> <https://maps.google.com/?q=Dornierstr.+4,+D-82178+Puchheim,+Germany&entry=gmail&source=g>
>>>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>>>> _______________________________________________
>>>> users mailing list
>>>> users at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20180330/e75cbddc/attachment-0002.html>
