Fwd: GSOC'18 project description
Vidushi Vashishth
reachvidu at gmail.com
Tue May 1 03:05:47 UTC 2018
---------- Forwarded message ----------
Date: Mon, Apr 30, 2018 at 11:42 PM
Subject: Re: GSOC'18 project description
To: Gedare Bloom <gedare at rtems.org>
>Vidushi can add a task of creating a babeltrace formula for conversion
from your custom format to CTF to facilitate unified analysis. Just
need a good description and examples of the custom format I guess.
Sure I can do that. I will get started with the babeltrace formula and a
sample custom format to CTF conversion example.
>Yes, it would be good to have tickets at the start of each phase as a
way to track progress and issues. Vidushi, maybe you can begin by
pulling out of your proposal the few tasks in Phase 1 and create a new
ticket for each one?
Yes that makes sense. For the first phase of my project I can think of
making three tickets:
1) Making improvements to barectf: adding struct and array support
2) Creating a rtems-tld generator which binds the barectf calls to the
generated C code
3) Integrating barectf output support with capture engine.
If this seems fine I will make the required tickets and link them to my
wiki project page.
>This is a good and important question. I think there should be a
section in this User Manual under Host Tools for the Babeltrace/Debug
tools that use the CTF output. There will also likely need to be
additions to the Classic API guide for "Configuring a System" and
improvements to description of the Capture Engine, which I'm currently
having trouble finding.
I can make the required documentation in this manner. However, I think a
single place that can summarize the tracing setup with a 'quickstart' would
be easier for the users.
Also while reading up documentation I found this page:
https://docs.rtems.org/branches/master/user/tools/linker.html
The description on the page says "not complete". Is someone working on this
currently? Since rtems linker is a part of the tracing system I could use
this for my understanding.
Best,
Vidushi
On Mon, Apr 30, 2018 at 9:39 PM, Gedare Bloom <gedare at rtems.org> wrote:
> On Mon, Apr 30, 2018 at 6:05 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
> > Hello Vidushi,
> > On 30/04/18 09:15, Vidushi Vashishth wrote:
> >> Hello!
> >> I am Vidushi Vashishth, and I have been selected for the Google Summer
> of
> >> Code'18 program. I look forward to a productive and enriching summer
> with
> >> the RTEMS community.
> > I am looking forward to get some new insights into a network stack
> > performance issue with 10Gbit/s Ethernet on a QorIQ T4240 with your
> tracing
> > support.
> >> I will be working on enhancement of the tracing system of RTEMS, under
> the
> >> guidance of mentors: Gedare Bloom, Chris Johns and Sebastian Huber. The
> main
> >> objectives of my project are threefold:
> >> 1) Combine the Common Trace Format with the functionality of the Trace
> >> Linker. I will be working with barectf and rtems-tld in this regard.
> >> 2) Coming up with a synchronisation and transport mechanism to send
> trace
> >> records to the host machine.
> >> 3) Investigate the importance of live tracing functionality and addition
> >> of kernel level tracing. I will design both possibilities and decide
> which
> >> one to work on by the end of phase 1 of my evaluation.
> > I work currently on a new low level infrastructure to support gathering
> of
> > thread (create, delete, terminate, switch) and interrupt (entry, exit)
> > events. Similar to the capture engine, but with less overhead. I would
> like
> > to be able to gather at least 200000 events per second per processor (24
> on
> > the QorIQ T4240). This results in about 80MiB/s of data so that I can
> > transfer it easily via a 1Gbit/s Ethernet interface.
> > I don't know how to setup the CTF infrastructure to display this data. I
> > hope that you can help me here.
> >> The wiki page for my project is:
> >> https://devel.rtems.org/wiki/GSoC/2018/EnhancementRuntimeTracing
> >> I will be documenting the progress of my project on my blog:
> >> https://vidushivashishth.github.io/
> >> Both of these sources are empty right now but will be modified with
> >> relevant information over the course of this summer.
> > I would prefer to use the ticket system as much as possible for this
> > project.
> > The main audience for the runtime tracing are the RTEMS users. A key
> issue
> > is to provide adequate documentation so that it is easy to use. If you
> need
> > this tracing then you probably have a nasty application issue and no
> time to
> > struggle with setting up things with a project deadline looming. Where
> > should this documentation go? A new chapter in the User Manual
> > https://docs.rtems.org/branches/master/user/index.html
> Gedare
> > Sebastian Huber, embedded brains GmbH
> > Address : Dornierstr. 4, D-82178 Puchheim, Germany
> > Phone : +49 89 189 47 41-16
> > Fax : +49 89 189 47 41-09
> > E-Mail : sebastian.huber at embedded-brains.de
> > PGP : Public key available on request.
> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> > users mailing list
> > users at rtems.org
> > http://lists.rtems.org/mailman/listinfo/users
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20180501/b3ae56aa/attachment-0001.html>
