Beaglebone Black LIBBSD Compiling Error
Christian Mauderer christian.mauderer at embedded-brains.de
Mon May 7 06:57:49 UTC 2018
Am 06.05.2018 um 01:45 schrieb Emre Cetin:
> Hi everyone,
> I just tried building libbsd for beagleboneblack, I had this error;
> [1718/1995] Compiling rtemsbsd/local/pcib_if.c
> [1757/1995] Compiling freebsd/sys/crypto/rijndael/rijndael-api.c
> [1764/1995] Compiling rtemsbsd/ftpd/ftpd-service.c
> [1765/1995] Compiling freebsd/sys/net/if_spppsubr.c
> [1766/1995] Compiling freebsd/sys/net/if_disc.c
> In file included from ../../rtemsbsd/ftpd/ftpd-service.c:52:0:
> /home/hasanemre/development/rtems/compiler/5/arm-rtems5/beagleboneblack/lib/include/rtems/ftpd.h:20:20:
> error: 'RTEMS_MINIMUM_STACK_SIZE' undeclared here (not in a function);
> did you mean 'RTEMS_MINIMUM_PRIORITY'?
>    FTPD_STACKSIZE = RTEMS_MINIMUM_STACK_SIZE + FTPD_DATASIZE /* Tasks
> stack size */
> Waf: Leaving directory
> `/home/hasanemre/development/rtems-libbsd-beagle/build/arm-rtems5-beagleboneblack-default'
> Build failed
> Regards,
> Emre
Hello Emre,
are you sure that your installed BSP and rtems-libbsd are both on the
latest master? Just recently, some of the services moved from libbsd to
RTEMS. With that, you have to rebuild your BSP to use the latest libbsd.
With kind regards
Christian Mauderer
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
