Raspberry Pi Rtems-Graphical-Toolkit
Kirspel, Kevin
Kevin-Kirspel at idexx.com
Wed May 9 16:49:42 UTC 2018
I am interested in your work as well. I ported Qt 5.9 to a NXP LPC3250 last year. I updated RTEMS LIBBSD to support EVDEV and added to the RTEMS MMAP interface to support MMAP handlers in frame buffer drivers. I was successful in getting the QT Quick clock demo application to run on RTEMS using the LinuxFB plugin. I would be interested to see how you created your RTEMS plugin.
Kevin Kirspel
Electrical Engineer - Sr. Staff
Idexx Roswell
235 Hembree Park Drive
Roswell GA 30076
Tel: (770)-510-4444 ext. 81642
Direct: (770)-688-1642
Fax: (770)-510-4445
From: users [mailto:users-bounces at rtems.org] On Behalf Of Joel Sherrill
Sent: Wednesday, May 09, 2018 12:07 PM
To: Mikhail Svetkin <mikhail.svetkin at gmail.com>
Cc: users at rtems.org; Emre Cetin <hsnemrecetin at gmail.com>
Subject: Re: Raspberry Pi Rtems-Graphical-Toolkit
Very nice blog Mikhail! And it looks to be great work!
Thank you for the complimentary things you said about RTEMS features.
I have a few questions.
+ Is this going to show up in the Qt free edition?
+ Any ideas on what RTEMS could do to improve our side of the
hosting Qt equation? Graphics has always been a challenge.
FWIW I took a stab at estimating porting Qt a few years ago. It is a large
body of software and a lot is just not appropriate for most embedded devices.
I got a reasonable subset to build but never got funding to do the actual work.
I am quite thrilled your effort was more successful.
Thanks.
--joel
On Fri, May 4, 2018 at 1:23 PM, Mikhail Svetkin <mikhail.svetkin at gmail.com<mailto:mikhail.svetkin at gmail.com>> wrote:
Hi all,
We started some researches (including Qt on RTEMS), take a look if you are interested.
http://blog.qt.io/blog/2018/05/03/qt-microncontrollers-mcu/<https://urldefense.proofpoint.com/v2/url?u=http-3A__blog.qt.io_blog_2018_05_03_qt-2Dmicroncontrollers-2Dmcu_&d=DwMFaQ&c=2do6VJGs3LvEOe4OFFM1bA&r=dbavT-WIJ4nBfQFKYnKdAD52Vyq3ZXSzrL9TAm21lZI&m=3l9d5ztgZL8IrTHvJLI4-LwXD6K3_k4zrzE8gCCTKBg&s=VsNfyIS5DVnaDqkssy4rCWAdJUrP8apiqX-Yw8YA7-k&e=>
Mikhail Svetkin
Software Engineer
The Qt Company
Sandakerveien 116
0484, Oslo, Norway
mikhail.svetkin at qt.io<mailto:mikhail.svetkin at qt.io>
+47 488 62 204
http://qt.io<https://urldefense.proofpoint.com/v2/url?u=http-3A__qt.io_&d=DwMFaQ&c=2do6VJGs3LvEOe4OFFM1bA&r=dbavT-WIJ4nBfQFKYnKdAD52Vyq3ZXSzrL9TAm21lZI&m=3l9d5ztgZL8IrTHvJLI4-LwXD6K3_k4zrzE8gCCTKBg&s=3WFQKF32z-8mZnp8v3cPM65-YC6hYDFxelQD2aXuSRU&e=>
[Image removed by sender.]<https://urldefense.proofpoint.com/v2/url?u=http-3A__qt.io_&d=DwMFaQ&c=2do6VJGs3LvEOe4OFFM1bA&r=dbavT-WIJ4nBfQFKYnKdAD52Vyq3ZXSzrL9TAm21lZI&m=3l9d5ztgZL8IrTHvJLI4-LwXD6K3_k4zrzE8gCCTKBg&s=3WFQKF32z-8mZnp8v3cPM65-YC6hYDFxelQD2aXuSRU&e=>
[Image removed by sender.]<https://urldefense.proofpoint.com/v2/url?u=http-3A__www.facebook.com_Qt&d=DwMFaQ&c=2do6VJGs3LvEOe4OFFM1bA&r=dbavT-WIJ4nBfQFKYnKdAD52Vyq3ZXSzrL9TAm21lZI&m=3l9d5ztgZL8IrTHvJLI4-LwXD6K3_k4zrzE8gCCTKBg&s=cddGdGn6jiAflCXK8SIQCt7r47vINFgyPfysbgDhRlw&e=>
[Image removed by sender.]<https://urldefense.proofpoint.com/v2/url?u=http-3A__www.twitter.com_qtproject&d=DwMFaQ&c=2do6VJGs3LvEOe4OFFM1bA&r=dbavT-WIJ4nBfQFKYnKdAD52Vyq3ZXSzrL9TAm21lZI&m=3l9d5ztgZL8IrTHvJLI4-LwXD6K3_k4zrzE8gCCTKBg&s=LWR01ky9SX_wPV7NLmjf_9any42WG1RC1YESYhdtyMk&e=>
[Image removed by sender.]<https://urldefense.proofpoint.com/v2/url?u=https-3A__www.linkedin.com_company_the-2Dqt-2Dcompany_&d=DwMFaQ&c=2do6VJGs3LvEOe4OFFM1bA&r=dbavT-WIJ4nBfQFKYnKdAD52Vyq3ZXSzrL9TAm21lZI&m=3l9d5ztgZL8IrTHvJLI4-LwXD6K3_k4zrzE8gCCTKBg&s=SR7KPT7KOJ9ONluL6iPamxvv44YSWfhc3h6p_Bw6EO4&e=>
[Image removed by sender.]<https://urldefense.proofpoint.com/v2/url?u=https-3A__plus.google.com_104580575722059274792&d=DwMFaQ&c=2do6VJGs3LvEOe4OFFM1bA&r=dbavT-WIJ4nBfQFKYnKdAD52Vyq3ZXSzrL9TAm21lZI&m=3l9d5ztgZL8IrTHvJLI4-LwXD6K3_k4zrzE8gCCTKBg&s=GBc5V8aXaSKeuEDp5cqY5sePJNBdHDl-Ld21U__n-1E&e=>
[Image removed by sender.]<https://urldefense.proofpoint.com/v2/url?u=https-3A__www.youtube.com_QtStudios&d=DwMFaQ&c=2do6VJGs3LvEOe4OFFM1bA&r=dbavT-WIJ4nBfQFKYnKdAD52Vyq3ZXSzrL9TAm21lZI&m=3l9d5ztgZL8IrTHvJLI4-LwXD6K3_k4zrzE8gCCTKBg&s=2-IP13syCEs_A_VmscBvlDxnNNV5hXN8yZFvjAKY0MQ&e=>
Best regards,
Mikhail
On 1 May 2018 at 19:01, Kirspel, Kevin <Kevin-Kirspel at idexx.com<mailto:Kevin-Kirspel at idexx.com>> wrote:
Another option is to not use X11 and draw directly to the frame buffer device (i.e. /dev/fb0). Qt supports this.
Kevin Kirspel
Idexx Roswell
Roswell GA 30076
Fax: (770)-510-4445
From: users [mailto:users-bounces at rtems.org<mailto:users-bounces at rtems.org>] On Behalf Of Emre Cetin
Sent: Tuesday, May 01, 2018 12:15 PM
To: users at rtems.org<mailto:users at rtems.org>
Subject: Fwd: Raspberry Pi Rtems-Graphical-Toolkit
---------- Forwarded message ----------
From: Emre Cetin <hsnemrecetin at gmail.com<mailto:hsnemrecetin at gmail.com>>
Date: 2018-05-01 19:13 GMT+03:00
To: Chris Johns <chrisj at rtems.org<mailto:chrisj at rtems.org>>
Thank you for your help Chris, I did what you said and it worked. However, I learned that Qt Applications works with X11 libraries in systems like Rtems. And I have to compile the nxlib library for raspberrypi BSP in the rtems-graphical-toolkit for X11. 'graphics\nxlib.bset' in rsb can not be build as mentioned in "https://lists.rtems.org/pipermail/devel/2015-August/012358.html<https://urldefense.proofpoint.com/v2/url?u=https-3A__lists.rtems.org_pipermail_devel_2015-2DAugust_012358.html&d=DwMFaQ&c=2do6VJGs3LvEOe4OFFM1bA&r=dbavT-WIJ4nBfQFKYnKdAD52Vyq3ZXSzrL9TAm21lZI&m=2qOzfS7qOLo1pWDBn2daTfb11BT4SII6DAGj7Nybgz0&s=FP3leA0B8WdfvIUwiGG0f2VRmehMyQCINAcYMEOWL8k&e=>". I understand that the nxlib is included in microwindows library anymore, but when I build 'graphics/microwindows.bset', will I also build nxlib?. BSP 's X11 header files and so on. How do I add X11 header files to BSP and other necessary files? What should I do at this point?
Best wishes,
Emre
2018-05-01 3:22 GMT+03:00 Chris Johns <chrisj at rtems.org<mailto:chrisj at rtems.org>>:
On 01/05/2018 02:49, Emre Cetin wrote:
> Hello everyone,
Hi and welcome.
> I have a Rtems project with Raspberry pi, I need to compile a simple QT program.
> I tried to run this project on Beaglebone Black, but it may not be as fast as it
> should be, it seems easier on Rpi. And I work on the Rpi 1 model B. In the last
> few days I am trying to establish the necessary libraries for QT, but I have not
> been successful.
This sounds like an interesting project.
> I've been working on Rtems-Graphical-Toolbase, but I have not
> been successful in compilation. I tried a lot of ways but I do not know how to
> load libraries manually yet, I am new to embedded systems.
Welcome to embedded and embedded real-time software.
> I finally used these instructions, it seemed the easiest way to me;
> (in right directory)
> ../source-builder/sb-set-builder \
> --prefix=$HOME/development/rtems/compiler/5 \
> --rtems-bsp=arm/raspberrypi \
> --log=graphic-build-log.txt \
> --with-rtems-bsp=raspberrypi \
> --pkg-tar-files \
> graphics/freetype2.bset \
> graphics/libjpeg.bset \
> graphics/libpng.bset \
> graphics/libtiff.bset \
> graphics/t1lib.bset \
> RTEMS Source Builder - Set Builder, 5 (f3b1700dfd4d)
> Build Set: graphics/microwindows.bset
> Build Set: graphics/freetype2.bset
> config: graphics/freetype-2.4.10-1.cfg
> package: freetype-v2.4.10-arm-rtems5-1
> error: hash: freetype-2.4.10.tar.gz: insecure: md5
> Build FAILED
> It seems that new packages are causing problems, and I do not know how to update
> the codes. Can you give me some advice?
A change went into the RSB in October last year to stop using the MD5 and SHA1
checksums as they are insecure. The ticket that covered this issue is:
https://devel.rtems.org/ticket/2536<https://urldefense.proofpoint.com/v2/url?u=https-3A__devel.rtems.org_ticket_2536&d=DwMFaQ&c=2do6VJGs3LvEOe4OFFM1bA&r=dbavT-WIJ4nBfQFKYnKdAD52Vyq3ZXSzrL9TAm21lZI&m=2qOzfS7qOLo1pWDBn2daTfb11BT4SII6DAGj7Nybgz0&s=W5nqzhQZQ8MD2Qny_KmidQ3uYRpLeCKJeVIEUl3iORE&e=>
It would seem some packages were missed and they need a better checksum. Could
you please reopen the ticket and indicate the issue you have by pasting in the
above output?
FYI the fix is easy, run a sha512 command on your host on the file or patch
which should be in the `sources` or `patches` directory and then update the line
in the related file. The freetype config file is:
rtems/config/graphics/freetype-2.4.10-1.cfg
On the line starting with `%hash` change `md5` to `sha512` and paste in the
SHA512 checksum.
I see ...
libjpeg-9a-1.cfg
libpng-1.5.24-1.cfg
libpng-1.6.21-1.cfg
libtiff-4.0.2-1.cfg
libtiff-4.0.6-1.cfg
microwindows-0.93-dev-1.cfg
t1lib-5.1.2-1.cfg
... are still using MD5 and will need updating.
We welcome patches, it is often the fastest way to get something like this fixed. :)
Thanks
users mailing list
http://lists.rtems.org/mailman/listinfo/users<https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rtems.org_mailman_listinfo_users&d=DwMFaQ&c=2do6VJGs3LvEOe4OFFM1bA&r=dbavT-WIJ4nBfQFKYnKdAD52Vyq3ZXSzrL9TAm21lZI&m=3l9d5ztgZL8IrTHvJLI4-LwXD6K3_k4zrzE8gCCTKBg&s=GvLnp4QsFLEnTgp-tcu5NsRIPM5VycdbAjJQFCY4cJ0&e=>
users mailing list
URL: <http://lists.rtems.org/pipermail/users/attachments/20180509/b5ad5fd0/attachment-0001.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.rtems.org/pipermail/users/attachments/20180509/b5ad5fd0/attachment-0002.jpg>
Type: image/jpeg
Desc: image002.jpg
URL: <http://lists.rtems.org/pipermail/users/attachments/20180509/b5ad5fd0/attachment-0003.jpg>
