Can't configure RTEMS for RISC-V BSP
Christian Mauderer list at c-mauderer.de
Sun May 27 20:34:32 UTC 2018
Am 27.05.2018 um 21:15 schrieb aesee:
> Hi,
> I'm trying to build RTEMS image for RISC-V x64 on Ubuntu, but I stuck on
> configure step.
> After command "$HOME/development/rtems/kernel/rtems/configure
> --prefix=$HOME/development/rtems/5 --target=riscv64-rtems5 --enable
> -rtemsbsp=riscv64_generic --enable-tests=samples" I am getting following
> message:
>>checking whether gmake supports nested variables... yes
>>checking whether to enable maintainer-specific portions of Makefiles... no
>>/home/aesee/development/rtems/kernel/rtems/configure: line 2688:
> ${target_arch$}*: bad substitution
That $ at the end of targe_arch looks suspicious. That might could be a
bug in the following patch:
https://git.rtems.org/rtems/commit/?id=d542af2e4304b663461330a60313fb6c4fdbf4db
Maybe try to remove the $ or revert that patch and try to build again.
> config.log contains this:
>>This file contains any messages produced by compilers while
>>running configure, to aid debugging if configure makes a mistake.
>>It was created by rtems configure 5.0.0, which was
>>generated by GNU Autoconf 2.69.  Invocation command line was
>> $ /home/aesee/development/rtems/kernel/rtems/configure
> --prefix=/home/aesee/development/rtems/5 --target=riscv64-rtems5
> --enable-rtemsbsp=riscv64_generic --enable-tests=samples
>>## Platform. ##
>>hostname = aesee-VirtualBox
>>uname -m = x86_64
>>uname -r = 4.15.0-22-generic
>>uname -s = Linux
>>uname -v = #24-Ubuntu SMP Wed May 16 12:15:17 UTC 2018
>>/usr/bin/uname -p = unknown
>>/bin/uname -X     = unknown
>>/bin/arch              = unknown
>>/usr/bin/arch -k       = unknown
>>/usr/convex/getsysinfo = unknown
>>/usr/bin/hostinfo      = unknown
>>/bin/machine           = unknown
>>/usr/bin/oslevel       = unknown
>>/bin/universe          = unknown
>>PATH: /usr/local/sbin
>>PATH: /usr/local/bin
>>PATH: /usr/sbin
>>PATH: /usr/bin
>>PATH: /sbin
>>PATH: /bin
>>PATH: /usr/games
>>PATH: /usr/local/games
>>PATH: /home/aesee/riscv-toolchain/bin/
>>PATH: /snap/bin
>>## Core tests. ##
>>configure:1871: checking for gmake
>>configure:1887: found /usr/bin/gmake
>>configure:1898: result: gmake
>>configure:1923: checking for RTEMS Version
>>configure:1925: result: 5.0.0
>>configure:1955: checking build system type
>>configure:1969: result: x86_64-pc-linux-gnu
>>configure:1989: checking host system type
>>configure:2002: result: x86_64-pc-linux-gnu
>>configure:2022: checking target system type
>>configure:2035: result: riscv64-unknown-rtems5
>>configure:2077: checking for a BSD-compatible install
>>configure:2145: result: /usr/bin/install -c
>>configure:2156: checking whether build environment is sane
>>configure:2211: result: yes
>>configure:2362: checking for a thread-safe mkdir -p
>>configure:2401: result: /bin/mkdir -p
>>configure:2408: checking for gawk
>>configure:2424: found /usr/bin/gawk
>>configure:2435: result: gawk
>>configure:2446: checking whether gmake sets $(MAKE)
>>configure:2468: result: yes
>>configure:2497: checking whether gmake supports nested variables
>>configure:2514: result: yes
>>configure:2632: checking whether to enable maintainer-specific portions
> of Makefiles
>>configure:2641: result: no
>>## Cache variables. ##
>>ac_cv_build=x86_64-pc-linux-gnu
>>ac_cv_env_build_alias_set=
>>ac_cv_env_build_alias_value=
>>ac_cv_env_host_alias_set=
>>ac_cv_env_host_alias_value=
>>ac_cv_env_target_alias_set=set
>>ac_cv_env_target_alias_value=riscv64-rtems5
>>ac_cv_host=x86_64-pc-linux-gnu
>>ac_cv_path_install='/usr/bin/install -c'
>>ac_cv_path_mkdir=/bin/mkdir
>>ac_cv_prog_AWK=gawk
>>ac_cv_prog_MAKE=gmake
>>ac_cv_prog_make_gmake_set=yes
>>ac_cv_target=riscv64-unknown-rtems5
>>am_cv_make_support_nested_variables=yes
>>## Output variables. ##
>>ACLOCAL='${SHELL} /home/aesee/development/rtems/kernel/rtems/missing
> aclocal-1.15'
>>AMTAR='$${TAR-tar}'
>>AM_BACKSLASH='\'
>>AM_DEFAULT_V='$(AM_DEFAULT_VERBOSITY)'
>>AM_DEFAULT_VERBOSITY='1'
>>AM_V='$(V)'
>>AUTOCONF='${SHELL} /home/aesee/development/rtems/kernel/rtems/missing
> autoconf'
>>AUTOHEADER='${SHELL} /home/aesee/development/rtems/kernel/rtems/missing
> autoheader'
>>AUTOMAKE='${SHELL} /home/aesee/development/rtems/kernel/rtems/missing
> automake-1.15'
>>AWK='gawk'
>>CYGPATH_W='echo'
>>DEFS=''
>>ECHO_C=''
>>ECHO_N='-n'
>>ECHO_T=''
>>INSTALL_DATA='${INSTALL} -m 644'
>>INSTALL_PROGRAM='${INSTALL}'
>>INSTALL_SCRIPT='${INSTALL}'
>>INSTALL_STRIP_PROGRAM='$(install_sh) -c -s'
>>LIBOBJS=''
>>LIBS=''
>>LTLIBOBJS=''
>>MAINT='#'
>>MAINTAINER_MODE_FALSE=''
>>MAINTAINER_MODE_TRUE='#'
>>MAKE='gmake'
>>MAKEINFO='${SHELL} /home/aesee/development/rtems/kernel/rtems/missing
> makeinfo'
>>MKDIR_P='/bin/mkdir -p'
>>PACKAGE='rtems'
>>PACKAGE_BUGREPORT='https://devel.rtems.org/newticket'
>>PACKAGE_NAME='rtems'
>>PACKAGE_STRING='rtems 5.0.0'
>>PACKAGE_TARNAME='rtems'
>>PACKAGE_URL=''
>>PACKAGE_VERSION='5.0.0'
>>PATH_SEPARATOR=':'
>>PROJECT_ROOT='./$(top_builddir)'
>>PROJECT_TOPdir='./$(top_builddir)'
>>RTEMS_BUILD_ROOT=''
>>RTEMS_CC=''
>>RTEMS_HAS_NETWORKING=''
>>RTEMS_HAS_POSIX_API=''
>>RTEMS_SOURCE_ROOT=''
>>RTEMS_TOPdir='.'
>>SET_MAKE=''
>>SHELL='/bin/bash'
>>STRIP=''
>>VERSION='5.0.0'
>>am__isrc=' -I$(srcdir)'
>>am__leading_dot='.'
>>am__tar='$${TAR-tar} chof - "$$tardir"'
>>am__untar='$${TAR-tar} xf -'
>>bindir='${exec_prefix}/bin'
>>build='x86_64-pc-linux-gnu'
>>build_SUBDIRS=''
>>build_alias=''
>>build_configdirs=''
>>build_cpu='x86_64'
>>build_os='linux-gnu'
>>build_subdir=''
>>build_vendor='pc'
>>buildargs=''
>>datadir='${datarootdir}'
>>datarootdir='${prefix}/share'
>>docdir='${datarootdir}/doc/${PACKAGE_TARNAME}'
>>dvidir='${docdir}'
>>exec_prefix='NONE'
>>host='x86_64-pc-linux-gnu'
>>host_SUBDIRS=''
>>host_alias=''
>>host_configdirs=''
>>host_cpu='x86_64'
>>host_os='linux-gnu'
>>host_subdir=''
>>host_vendor='pc'
>>hostargs=''
>>htmldir='${docdir}'
>>includedir='${prefix}/include'
>>infodir='${datarootdir}/info'
>>install_sh='${SHELL} /home/aesee/development/rtems/kernel/rtems/install-sh'
>>libdir='${exec_prefix}/lib'
>>libexecdir='${exec_prefix}/libexec'
>>localedir='${datarootdir}/locale'
>>localstatedir='${prefix}/var'
>>mandir='${datarootdir}/man'
>>mkdir_p='$(MKDIR_P)'
>>oldincludedir='/usr/include'
>>pdfdir='${docdir}'
>>pkgdatadir='${datarootdir}/rtems5'
>>prefix='/home/aesee/development/rtems/5'
>>program_transform_name='s&^&riscv64-rtems5-&'
>>psdir='${docdir}'
>>runstatedir='${localstatedir}/run'
>>sbindir='${exec_prefix}/sbin'
>>sharedstatedir='${prefix}/com'
>>sysconfdir='${prefix}/etc'
>>target='riscv64-unknown-rtems5'
>>target_SUBDIRS=''
>>target_alias='riscv64-rtems5'
>>target_configdirs=''
>>target_cpu='riscv64'
>>target_os='rtems5'
>>target_subdir=''
>>target_vendor='unknown'
>>targetargs=''
>>## confdefs.h. ##
>>/* confdefs.h */
>>#define PACKAGE_NAME "rtems"
>>#define PACKAGE_TARNAME "rtems"
>>#define PACKAGE_VERSION "5.0.0"
>>#define PACKAGE_STRING "rtems 5.0.0"
>>#define PACKAGE_BUGREPORT "https://devel.rtems.org/newticket"
>>#define PACKAGE_URL ""
>>configure: exit 1
> Please, somebody, explain what I do wrong. I researched google but can't
> found any solution for this.
> users mailing list
> users at rtems.org
