rsb problem with python
Siddons, David
siddons at bnl.gov
Mon May 28 21:57:21 UTC 2018
While building rsb for arm-rtems I got this problem:
checking for python... /home/peter/miniconda3/bin/python
checking for python3.6... no
configure: error: python is missing or unusable
Makefile:9095: recipe for target 'configure-gdb' failed
make[1]: *** [configure-gdb] Error 1
make[1]: Leaving directory '/home/peter/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems5-gdb-8.0.1-x86_64-linux-gnu-1/build'
Makefile:848: recipe for target 'all' failed
make: *** [all] Error 2
shell cmd failed: /bin/sh -ex /home/peter/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems5-gdb-8.0.1-x86_64-linux-gnu-1/doit
error: building arm-rtems5-gdb-8.0.1-x86_64-linux-gnu-1peter at peter-Latitude-E7240:~/development/rtems/src/rtems-source-builder/rtems$
I am running Ubuntu:
peter at peter-Latitude-E7240:/etc$ lsb_release -a
LSB Version: core-9.20160110ubuntu0.2-amd64:core-9.20160110ubuntu0.2-noarch:printing-9.20160110ubuntu0.2-amd64:printing-9.20160110ubuntu0.2-noarch:security-9.20160110ubuntu0.2-amd64:security-9.20160110ubuntu0.2-noarch
Distributor ID: Ubuntu
Description: Ubuntu 16.04.4 LTS
Release: 16.04
Codename: xenial
then:
python -V
Python 3.6.1 :: Continuum Analytics, Inc.
This comes from an Anaconda installation. If I remove the path entry which causes that I get python 2.7, which is the default Ubuntu 16.04 version. Do I need to install Python 3.6?
Pete.
URL: <http://lists.rtems.org/pipermail/users/attachments/20180528/df30313d/attachment.html>
