rsb problem with python
Amaan Cheval amaan.cheval at gmail.com
Mon May 28 23:12:56 UTC 2018
Ah, it seems like my shot in the dark was misguided :)
This seems like it may help, but it's mostly another shot in the dark:
https://stackoverflow.com/questions/26910649/unable-to-install-gdb-with-python-support?utm_medium=organic&utm_source=google_rich_qa&utm_campaign=google_rich_qa
On Tue, May 29, 2018 at 3:53 AM, Siddons, David <siddons at bnl.gov> wrote:
> Hi Amaan,
>    Actually,  /home/peter/miniconda3/bin/python is a soft link to
> /home/peter/miniconda3/bin/python3.6 already! Does rsb not follow links?
> Pete.
> ________________________________
> From: Amaan Cheval [amaan.cheval at gmail.com]
> Sent: Monday, May 28, 2018 6:05 PM
> To: Siddons, David
> Cc: users at rtems.org
> Subject: Re: rsb problem with python
> Hey David!
> It looks to me like Anaconda doesn't install the "alias" binaries specifying
> the version (for eg. both "python" and "python3.6"). I believe the fix in
> your case should be as simple as copying your existing binary with the
> following command:
> cp /home/peter/miniconda3/bin/python /home/peter/miniconda3/bin/python3.6
> On Tue, May 29, 2018, 3:28 AM Siddons, David <siddons at bnl.gov> wrote:
>> While building rsb for arm-rtems I got this problem:
>> checking for python... /home/peter/miniconda3/bin/python
>> checking for python3.6... no
>> configure: error: python is missing or unusable
>> Makefile:9095: recipe for target 'configure-gdb' failed
>> make[1]: *** [configure-gdb] Error 1
>> make[1]: Leaving directory
>> '/home/peter/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems5-gdb-8.0.1-x86_64-linux-gnu-1/build'
>> Makefile:848: recipe for target 'all' failed
>> make: *** [all] Error 2
>> shell cmd failed: /bin/sh -ex
>> /home/peter/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems5-gdb-8.0.1-x86_64-linux-gnu-1/doit
>> error: building
>> arm-rtems5-gdb-8.0.1-x86_64-linux-gnu-1peter at peter-Latitude-E7240:~/development/rtems/src/rtems-source-builder/rtems$
>> I am running Ubuntu:
>> peter at peter-Latitude-E7240:/etc$ lsb_release -a
>> LSB Version:
>> core-9.20160110ubuntu0.2-amd64:core-9.20160110ubuntu0.2-noarch:printing-9.20160110ubuntu0.2-amd64:printing-9.20160110ubuntu0.2-noarch:security-9.20160110ubuntu0.2-amd64:security-9.20160110ubuntu0.2-noarch
>> Distributor ID: Ubuntu
>> Description:    Ubuntu 16.04.4 LTS
>> Release:        16.04
>> Codename:       xenial
>> then:
>> python -V
>> Python 3.6.1 :: Continuum Analytics, Inc.
>> This comes from an Anaconda installation. If I remove the path entry which
>> causes that I get python 2.7, which is the default Ubuntu 16.04 version. Do
>> I need to install Python 3.6?
>> Pete.
>> users mailing list
>> users at rtems.org
