zynq picozed board
D Peter Siddons
siddons at bnl.gov
Wed May 30 13:05:01 UTC 2018
Hi Chris,
THanks very much, I'll give it a shot. Just as soon as I solve my
rsb python issue :)
Pete.
On 05/30/2018 05:17 AM, Chris Johns wrote:
> On 29/5/18 5:12 am, Siddons, David wrote:
>> Has anyone implemented RTEMS on an Avnet Picozed board? What needs to be changed
>> in the existing ZynQ support to do that?
> There should not be too much. I have these functions with suitable values ....
> * Provide the peripheral clock freq.
> uint32_t a9mpcore_clock_periphclk(void)
> return XPAR_CPU_CORTEXA9_0_CPU_CLK_FREQ_HZ / 2;
> uint32_t zynq_clock_cpu_1x(void)
> return 100000000U;
> You may want to provide an MMU table that fits your needs so you can access the
> AXI channels to the PL fabric:
> #ifdef ARMV7_CP15_START_DEFAULT_SECTIONS
> BSP_START_DATA_SECTION static const arm_cp15_start_section_config
> zynq_mmu_config_table[] = {
> ARMV7_CP15_START_DEFAULT_SECTIONS,
> .begin = 0xe0000000U,
> .end = 0xe0200000U,
> .flags = ARMV7_MMU_DEVICE
> BSP_START_TEXT_SECTION void zynq_setup_mmu_and_cache(void)
> uint32_t ctrl = arm_cp15_start_setup_mmu_and_cache(
> ARM_CP15_CTRL_A,
> ARM_CP15_CTRL_AFE | ARM_CP15_CTRL_Z
> arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache(
> ctrl,
> (uint32_t *) bsp_translation_table_base,
> ARM_MMU_DEFAULT_CLIENT_DOMAIN,
> &zynq_mmu_config_table[0],
> RTEMS_ARRAY_SIZE(zynq_mmu_config_table)
> #endif
> These functions are weak in RTEMS so providing them in an object file in your
> application overrides the RTEMS defaults for this BSP.
> Chris
D. Peter Siddons
Detector Development Group Leader
Photon Science Division, NSLS-II,
Bldg. 535B
Brookhaven National Laboratory
Upton, NY 11973
email: siddons at bnl.gov
Phone: (631) 344-2738
URL: <http://lists.rtems.org/pipermail/users/attachments/20180530/617646e0/attachment.html>
