rtems_region_create() returning error code
Francesco Nuzzolo francesco.nuzzolo at spaceapplications.com
Wed May 30 14:20:50 UTC 2018
Thanks for the answer.
Do you know if there is a clean way to force allocation of an array to
an 8-byte boundary in LEON?
Maybe defining the array as double, since sizeof(double) is 8 on LEON ?
Or should I stop using the region manager altogether?
Best regards,
Francesco
On 5/30/2018 10:48 AM, Sebastian Huber wrote:
> On 30/05/18 10:19, Francesco Nuzzolo wrote:
>> - starting address is not on a four byte boundary.
> This is a bug in the documentation and in the 4.10 region
> implementation. The starting address must be aligned to the
> CPU_ALIGNMENT which is 8 on SPARC.
Francesco Nuzzolo
Systems Engineer
Avionics & Embedded Systems
Space Applications Services NV/SA
Leuvensesteenweg 325, 1932 Zaventem, Belgium
Direct: +32-(0)2-416.05.15
Main: +32-(0)2-721.54.84  Fax: +32-(0)2-721.54.44
www.spaceapplications.com
