rsb problem with python
D Peter Siddons
siddons at bnl.gov
Wed May 30 19:58:08 UTC 2018
Hi Gedare,
That worked, i.e. commenting out the miniconda path and installing
python3.6-dev. So on to the next stop :)
Processing stopped when building the kernel. At the end of the log file
I see:
script: 72: export PATH
script: 73: # Default environment set up.
script: 74: LANG=C
script: 75: export LANG
script: 76: unset DISPLAY || :
script: 77: umask 022
script: 78: cd "/home/peter/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems5-kernel-5-1"
script: 79: echo "=> arm-rtems5-kernel-5-1:"
script: 80: echo "==> %prep:"
script: 81: source_dir_rtems="rtems-5"
source setup: arm-rtems5-kernel-5-1: source rtems -q -c -n arm-rtems5-kernel-5-1-5
making dir: /home/peter/development/rtems/src/rtems-source-builder/rtems/sources/git
git: reset: git://git.rtems.org/rtems.git
git: checkout: git://git.rtems.org/rtems.git => 5
error: git command failed (/usr/bin/git): 1
I have attached the entire report, FYI. Does this mean that git could
not supply the source?
Pete.
On 05/30/2018 01:01 PM, Gedare Bloom wrote:
> Pete,
> On Wed, May 30, 2018 at 12:19 PM, D Peter Siddons <siddons at bnl.gov> wrote:
>> Hi Gedare,
>> I didn't get your earlier email (?), but the answer is:
>> /home/peter/miniconda3/bin/python3.6
>> so the only way I have 3.6 is through miniconda. Maybe it expects
>> /usr/bin/python3.6?
> Odd that my email didn't come through to you. Anyway, since 'which'
> finds it, the paths seem correct. Alex' suggestion to install the
> development library is a good one however. I have had problems in the
> past with mixed Anaconda python installations and Ubuntu distro ones.
> I (like you) had the conda in a subdir of my home directory though, so
> I found it was easiest for me to just disable the conda paths e.g. by
> commenting out
> #export PATH="/home/gedare/anaconda3/bin:$PATH"
> in my .bashrc was sufficient for me
> Then, I could install/use the Ubuntu distributions Python2/3 packages
> without conflicts.
> Gedare
>> Pete.
>> On 05/30/2018 12:12 PM, Gedare Bloom wrote:
>> Alex,
>> Yes that also makes sense, thank you. Usually, I've seen that problem
>> manifest as missing Python.h, but error messages can be vague and
>> inconsistent. :)
>> On Wed, May 30, 2018 at 11:49 AM, Slide <slide.o.mix at gmail.com> wrote:
>> I ran into a similar issue and the way I solved it was by installing the
>> -dev package for Python. For me this was libpython3-dev on Ubuntu. I'm not
>> sure how to do that with the Anaconda installation, but this may help point
>> you in the right direction.
>> Regards,
>> Alex
>> On Wed, May 30, 2018 at 6:57 AM Gedare Bloom <gedare at rtems.org> wrote:
>> Pete,
>> Do you get anything with:
>> $ which python3.6
>> Probably, it is looking for that invocation command. I ought to try
>> this, because my Ubuntu does not ship with python3.6 I know, so maybe
>> it breaks too... hm
>> On Mon, May 28, 2018 at 6:23 PM, Siddons, David <siddons at bnl.gov> wrote:
>> Hi Amaan,
>> Actually, /home/peter/miniconda3/bin/python is a soft link to
>> /home/peter/miniconda3/bin/python3.6 already! Does rsb not follow links?
>> Pete.
>> ________________________________
>> From: Amaan Cheval [amaan.cheval at gmail.com]
>> Sent: Monday, May 28, 2018 6:05 PM
>> To: Siddons, David
>> Cc: users at rtems.org
>> Subject: Re: rsb problem with python
>> Hey David!
>> It looks to me like Anaconda doesn't install the "alias" binaries
>> specifying
>> the version (for eg. both "python" and "python3.6"). I believe the fix
>> in
>> your case should be as simple as copying your existing binary with the
>> following command:
>> cp /home/peter/miniconda3/bin/python
>> On Tue, May 29, 2018, 3:28 AM Siddons, David <siddons at bnl.gov> wrote:
>> While building rsb for arm-rtems I got this problem:
>> checking for python... /home/peter/miniconda3/bin/python
>> checking for python3.6... no
>> configure: error: python is missing or unusable
>> Makefile:9095: recipe for target 'configure-gdb' failed
>> make[1]: *** [configure-gdb] Error 1
>> make[1]: Leaving directory
>> '/home/peter/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems5-gdb-8.0.1-x86_64-linux-gnu-1/build'
>> Makefile:848: recipe for target 'all' failed
>> make: *** [all] Error 2
>> shell cmd failed: /bin/sh -ex
>> /home/peter/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems5-gdb-8.0.1-x86_64-linux-gnu-1/doit
>> error: building
>> arm-rtems5-gdb-8.0.1-x86_64-linux-gnu-1peter at peter-Latitude-E7240:~/development/rtems/src/rtems-source-builder/rtems$
>> I am running Ubuntu:
>> peter at peter-Latitude-E7240:/etc$ lsb_release -a
>> LSB Version:
>> core-9.20160110ubuntu0.2-amd64:core-9.20160110ubuntu0.2-noarch:printing-9.20160110ubuntu0.2-amd64:printing-9.20160110ubuntu0.2-noarch:security-9.20160110ubuntu0.2-amd64:security-9.20160110ubuntu0.2-noarch
>> Distributor ID: Ubuntu
>> Description: Ubuntu 16.04.4 LTS
>> Release: 16.04
>> Codename: xenial
>> then:
>> python -V
>> Python 3.6.1 :: Continuum Analytics, Inc.
>> This comes from an Anaconda installation. If I remove the path entry
>> which
>> causes that I get python 2.7, which is the default Ubuntu 16.04
>> version. Do
>> I need to install Python 3.6?
>> Pete.
>> users mailing list
>> users at rtems.org
>> users mailing list
>> users at rtems.org
>> users mailing list
>> users at rtems.org
>> D. Peter Siddons
>> Detector Development Group Leader
>> Photon Science Division, NSLS-II,
>> Bldg. 535B
>> Brookhaven National Laboratory
>> Upton, NY 11973
>> email: siddons at bnl.gov
>> Phone: (631) 344-2738
D. Peter Siddons
Bldg. 535B
Upton, NY 11973
URL: <http://lists.rtems.org/pipermail/users/attachments/20180530/afc7a9f0/attachment-0001.html>
RTEMS Tools Project - Source Builder Error Report
Build: error: git command failed (/usr/bin/git): 1
Command Line: ../source-builder/sb-set-builder --log=l-arm.txt --prefix=/home/peter/development/rtems/5 --with-rtems 5/rtems-arm
Python: 2.7.12 (default, Dec 4 2017, 14:50:18) [GCC 5.4.0 20160609]
git://git.rtems.org/rtems-source-builder.git/origin/a3a6c34c150a357e57769a26a460c475e188438f
Linux peter-Latitude-E7240 4.4.0-127-generic #153-Ubuntu SMP Sat May 19 10:58:46 UTC 2018 x86_64
Tail of the build log:
[ 68/150] Compiling rtemstoolkit/libiberty/stpcpy.c
[ 69/150] Compiling rtemstoolkit/libiberty/pex-common.c
[ 70/150] Compiling rtemstoolkit/libiberty/pex-one.c
[ 71/150] Compiling rtemstoolkit/libiberty/xmalloc.c
[ 72/150] Compiling rtemstoolkit/libiberty/xmemdup.c
[ 73/150] Compiling rtemstoolkit/libiberty/xstrdup.c
[ 74/150] Compiling rtemstoolkit/libiberty/xstrerror.c
[ 75/150] Compiling rtemstoolkit/libiberty/pex-unix.c
[ 76/150] Compiling rtemstoolkit/ConvertUTF.c
[ 77/150] Compiling rtemstoolkit/pkgconfig.cpp
[ 78/150] Compiling rtemstoolkit/rld-buffer.cpp
[ 79/150] Compiling rtemstoolkit/rld-cc.cpp
[ 80/150] Compiling rtemstoolkit/rld-compression.cpp
[ 81/150] Compiling rtemstoolkit/rld-config.cpp
[ 82/150] Compiling rtemstoolkit/rld-elf.cpp
[ 83/150] Compiling rtemstoolkit/rld-files.cpp
[ 84/150] Compiling rtemstoolkit/rld-outputter.cpp
[ 85/150] Compiling rtemstoolkit/rld-path.cpp
[ 86/150] Compiling rtemstoolkit/rld-process.cpp
[ 87/150] Compiling rtemstoolkit/rld-rap.cpp
[ 88/150] Compiling rtemstoolkit/rld-resolver.cpp
[ 89/150] Compiling rtemstoolkit/rld-rtems.cpp
[ 90/150] Compiling rtemstoolkit/rld-symbols.cpp
[ 91/150] Compiling rtemstoolkit/rld.cpp
[ 92/150] Compiling rtemstoolkit/rtems-utils.cpp
[ 93/150] Compiling rtemstoolkit/fastlz.c
[ 94/150] Compiling linkers/rtems-ld.cpp
[ 95/150] Compiling linkers/rtems-ra.cpp
[ 96/150] Compiling linkers/rtems-tld.cpp
[ 97/150] Compiling linkers/rtems-syms.cpp
[ 98/150] Compiling linkers/rtems-rapper.cpp
[ 99/150] Compiling linkers/rtems-exeinfo.cpp
[100/150] Compiling tester/covoar/app_common.cc
[101/150] Compiling tester/covoar/CoverageFactory.cc
[102/150] Compiling tester/covoar/CoverageMap.cc
[103/150] Compiling tester/covoar/CoverageMapBase.cc
[104/150] Compiling tester/covoar/CoverageRanges.cc
[105/150] Compiling tester/covoar/CoverageReaderBase.cc
[106/150] Compiling tester/covoar/CoverageReaderQEMU.cc
[107/150] Compiling tester/covoar/CoverageReaderRTEMS.cc
[108/150] Compiling tester/covoar/CoverageReaderSkyeye.cc
[109/150] Compiling tester/covoar/CoverageReaderTSIM.cc
[110/150] Compiling tester/covoar/CoverageWriterBase.cc
[111/150] Compiling tester/covoar/CoverageWriterRTEMS.cc
[112/150] Compiling tester/covoar/CoverageWriterSkyeye.cc
[113/150] Compiling tester/covoar/CoverageWriterTSIM.cc
[114/150] Compiling tester/covoar/DesiredSymbols.cc
[115/150] Compiling tester/covoar/ExecutableInfo.cc
[116/150] Compiling tester/covoar/Explanations.cc
[117/150] Compiling tester/covoar/GcovData.cc
[118/150] Compiling tester/covoar/GcovFunctionData.cc
../tester/covoar/GcovData.cc: In member function 'void Gcov::GcovData::writeGcovFile()':
../tester/covoar/GcovData.cc:489:22: warning: ignoring return value of 'int system(const char*)', declared with attribute warn_unused_result [-Wunused-result]
system( command );
[119/150] Compiling tester/covoar/ObjdumpProcessor.cc
../tester/covoar/DesiredSymbols.cc: In member function 'void Coverage::DesiredSymbols::determineSourceLines(Coverage::CoverageRanges*, Coverage::ExecutableInfo*)':
../tester/covoar/DesiredSymbols.cc:521:37: warning: ignoring return value of 'char* realpath(const char*, char*)', declared with attribute warn_unused_result [-Wunused-result]
realpath( inputBuffer, rpath );
[120/150] Compiling tester/covoar/ReportsBase.cc
../tester/covoar/DesiredSymbols.cc:538:37: warning: ignoring return value of 'char* realpath(const char*, char*)', declared with attribute warn_unused_result [-Wunused-result]
[121/150] Compiling tester/covoar/ReportsText.cc
[122/150] Compiling tester/covoar/ReportsHtml.cc
[123/150] Compiling tester/covoar/SymbolTable.cc
[124/150] Compiling tester/covoar/Target_arm.cc
[125/150] Compiling tester/covoar/TargetBase.cc
[126/150] Compiling tester/covoar/TargetFactory.cc
[127/150] Compiling tester/covoar/Target_i386.cc
[128/150] Compiling tester/covoar/Target_lm32.cc
[129/150] Compiling tester/covoar/Target_m68k.cc
[130/150] Compiling tester/covoar/Target_powerpc.cc
[131/150] Compiling tester/covoar/Target_sparc.cc
[132/150] Compiling tester/covoar/TraceConverter.cc
[133/150] Compiling tester/covoar/TraceList.cc
[134/150] Compiling tester/covoar/TraceReaderBase.cc
[135/150] Compiling tester/covoar/TraceReaderLogQEMU.cc
[136/150] Compiling tester/covoar/TraceWriterBase.cc
[137/150] Compiling tester/covoar/TraceWriterQEMU.cc
[138/150] Compiling tester/covoar/covoar.cc
[139/150] Linking build/rtemstoolkit/libiberty.a
[140/150] Linking build/rtemstoolkit/libelf.a
[141/150] Linking build/rtemstoolkit/librld.a
[142/150] Linking build/linkers/rtems-ra
[143/150] Linking build/linkers/rtems-tld
[144/150] Linking build/linkers/rtems-ld
[145/150] Linking build/linkers/rtems-syms
[146/150] Linking build/tester/covoar/libccovoar.a
[147/150] Linking build/linkers/rtems-rap
[148/150] Linking build/linkers/rtems-exeinfo
[149/150] Linking build/tester/covoar/covoar
[150/150] Linking build/tester/covoar/trace-converter
Waf: Leaving directory `/home/peter/development/rtems/src/rtems-source-builder/rtems/build/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1/rtems-tools-25863503edb513e7501481ff2074c02bf219f519/build'
'build' finished successfully (25.178s)
+ cd /home/peter/development/rtems/src/rtems-source-builder/rtems/build/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1
+ echo ==> %install:
+ pwd
+ build_top=/home/peter/development/rtems/src/rtems-source-builder/rtems/build/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1
+ /bin/rm -rf /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter
==> %install:
+ SB_BUILD_ROOT_WAF=/home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter
+ cd rtems-tools-25863503edb513e7501481ff2074c02bf219f519
+ ./waf --destdir=/home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter install
Waf: Entering directory `/home/peter/development/rtems/src/rtems-source-builder/rtems/build/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1/rtems-tools-25863503edb513e7501481ff2074c02bf219f519/build'
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/rtemstoolkit/configuration.py (from rtemstoolkit/configuration.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/rtemstoolkit/config.py (from rtemstoolkit/config.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/rtemstoolkit/__init__.py (from rtemstoolkit/__init__.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/rtemstoolkit/check.py (from rtemstoolkit/check.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/rtemstoolkit/darwin.py (from rtemstoolkit/darwin.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/rtemstoolkit/error.py (from rtemstoolkit/error.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/rtemstoolkit/execute.py (from rtemstoolkit/execute.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/rtemstoolkit/freebsd.py (from rtemstoolkit/freebsd.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/rtemstoolkit/git.py (from rtemstoolkit/git.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/rtemstoolkit/host.py (from rtemstoolkit/host.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/rtemstoolkit/linux.py (from rtemstoolkit/linux.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/rtemstoolkit/log.py (from rtemstoolkit/log.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/rtemstoolkit/macros.py (from rtemstoolkit/macros.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/rtemstoolkit/mailer.py (from rtemstoolkit/mailer.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/rtemstoolkit/options.py (from rtemstoolkit/options.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/rtemstoolkit/path.py (from rtemstoolkit/path.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/rtemstoolkit/stacktraces.py (from rtemstoolkit/stacktraces.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/rtemstoolkit/reraise.py (from rtemstoolkit/reraise.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/rtemstoolkit/version.py (from rtemstoolkit/version.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/rtemstoolkit/textbox.py (from rtemstoolkit/textbox.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/rtemstoolkit/windows.py (from rtemstoolkit/windows.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/bin/rtems-ld (from build/linkers/rtems-ld)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/bin/rtems-ra (from build/linkers/rtems-ra)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/bin/rtems-tld (from build/linkers/rtems-tld)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/trace-linker/libc.ini (from linkers/libc.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/trace-linker/libc-heap.ini (from linkers/libc-heap.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/trace-linker/rtems.ini (from linkers/rtems.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/trace-linker/rtems-api.ini (from linkers/rtems-api.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/trace-linker/rtems-posix.ini (from linkers/rtems-posix.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/trace-linker/rtems-score.ini (from linkers/rtems-score.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/trace-linker/rtems-score-object.ini (from linkers/rtems-score-object.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/trace-linker/rtems-score-thread.ini (from linkers/rtems-score-thread.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/trace-linker/rtems-score-threadq.ini (from linkers/rtems-score-threadq.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/trace-linker/rtems-score-heap.ini (from linkers/rtems-score-heap.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/trace-linker/rtld-base.ini (from linkers/rtld-base.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/bin/rtems-syms (from build/linkers/rtems-syms)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/trace-linker/rtld-trace-buffer.ini (from linkers/rtld-trace-buffer.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/trace-linker/rtld-print.ini (from linkers/rtld-print.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/bin/rtems-rap (from build/linkers/rtems-rap)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/bin/rtems-exeinfo (from build/linkers/rtems-exeinfo)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/bin/trace-converter (from build/tester/covoar/trace-converter)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/bin/covoar (from build/tester/covoar/covoar)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rt/check.py (from tester/rt/check.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rt/bsps.py (from tester/rt/bsps.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rt/__init__.py (from tester/rt/__init__.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rt/config.py (from tester/rt/config.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rt/console.py (from tester/rt/console.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rt/gdb.py (from tester/rt/gdb.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rt/options.py (from tester/rt/options.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rt/report.py (from tester/rt/report.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rt/stty.py (from tester/rt/stty.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rt/run.py (from tester/rt/run.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rt/telnet.py (from tester/rt/telnet.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rt/test.py (from tester/rt/test.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rt/tftp.py (from tester/rt/tftp.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rt/pygdb/__init__.py (from tester/rt/pygdb/__init__.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rt/pygdb/mi_parser.py (from tester/rt/pygdb/mi_parser.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rt/pygdb/spark.py (from tester/rt/pygdb/spark.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rt/tftpy/__init__.py (from tester/rt/tftpy/__init__.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rt/tftpy/TftpClient.py (from tester/rt/tftpy/TftpClient.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rt/tftpy/TftpContexts.py (from tester/rt/tftpy/TftpContexts.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rt/tftpy/TftpPacketFactory.py (from tester/rt/tftpy/TftpPacketFactory.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rt/tftpy/TftpPacketTypes.py (from tester/rt/tftpy/TftpPacketTypes.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rt/tftpy/TftpServer.py (from tester/rt/tftpy/TftpServer.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rt/tftpy/TftpShared.py (from tester/rt/tftpy/TftpShared.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rt/tftpy/TftpStates.py (from tester/rt/tftpy/TftpStates.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/bin/rtems-run (from tester/rtems-run)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/config/base.cfg (from tester/config/base.cfg)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/config/checks.cfg (from tester/config/checks.cfg)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/bin/rtems-test (from tester/rtems-test)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/bin/rtems-bsp-builder (from tester/rtems-bsp-builder)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/gdb/python/rtems/__init__.py (from tools/gdb/python/__init__.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/gdb/python/rtems/chains.py (from tools/gdb/python/chains.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/gdb/python/rtems/classic.py (from tools/gdb/python/classic.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/gdb/python/rtems/classic_printer.py (from tools/gdb/python/classic_printer.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/gdb/python/rtems/configuration.py (from tools/gdb/python/configuration.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/gdb/python/rtems/heaps.py (from tools/gdb/python/heaps.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/gdb/python/rtems/helper.py (from tools/gdb/python/helper.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/gdb/python/rtems/main.py (from tools/gdb/python/main.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/rtems-bsps-arm.ini (from tester/rtems/rtems-bsps-arm.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/gdb/python/rtems/objects.py (from tools/gdb/python/objects.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/rtems-bsps-bfin.ini (from tester/rtems/rtems-bsps-bfin.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/gdb/python/rtems/percpu.py (from tools/gdb/python/percpu.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/rtems-bsps-epiphany.ini (from tester/rtems/rtems-bsps-epiphany.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/gdb/python/rtems/pretty.py (from tools/gdb/python/pretty.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/gdb/python/rtems/rtems.py (from tools/gdb/python/rtems.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/rtems-bsps-i386.ini (from tester/rtems/rtems-bsps-i386.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/rtems-bsps-lm32.ini (from tester/rtems/rtems-bsps-lm32.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/rtems-bsps-m32c.ini (from tester/rtems/rtems-bsps-m32c.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/gdb/python/rtems/sparc.py (from tools/gdb/python/sparc.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/rtems-bsps-m68k.ini (from tester/rtems/rtems-bsps-m68k.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/gdb/python/rtems/supercore_printer.py (from tools/gdb/python/supercore_printer.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/gdb/python/rtems/supercore.py (from tools/gdb/python/supercore.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/rtems-bsps-mips.ini (from tester/rtems/rtems-bsps-mips.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/gdb/python/rtems/threads.py (from tools/gdb/python/threads.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/rtems-bsps-moxie.ini (from tester/rtems/rtems-bsps-moxie.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/gdb/python/rtems/watchdog.py (from tools/gdb/python/watchdog.py)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/rtems-bsps-nios2.ini (from tester/rtems/rtems-bsps-nios2.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/rtems-bsps-or1k.ini (from tester/rtems/rtems-bsps-or1k.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/rtems-bsps-powerpc.ini (from tester/rtems/rtems-bsps-powerpc.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/rtems-bsps-riscv32.ini (from tester/rtems/rtems-bsps-riscv32.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/rtems-bsps-riscv64.ini (from tester/rtems/rtems-bsps-riscv64.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/rtems-bsps-sh.ini (from tester/rtems/rtems-bsps-sh.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/rtems-bsps-sparc.ini (from tester/rtems/rtems-bsps-sparc.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/rtems-bsps-sparc64.ini (from tester/rtems/rtems-bsps-sparc64.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/rtems-bsps-tiers.ini (from tester/rtems/rtems-bsps-tiers.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/rtems-bsps-v850.ini (from tester/rtems/rtems-bsps-v850.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/rtems-bsps.ini (from tester/rtems/rtems-bsps.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/arm1136jfs-run.ini (from tester/rtems/testing/bsps/arm1136jfs-run.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/arm1136jfs.ini (from tester/rtems/testing/bsps/arm1136jfs.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/arm1136js-run.ini (from tester/rtems/testing/bsps/arm1136js-run.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/arm1136js.ini (from tester/rtems/testing/bsps/arm1136js.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/arm7tdmi-run.ini (from tester/rtems/testing/bsps/arm7tdmi-run.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/arm7tdmi.ini (from tester/rtems/testing/bsps/arm7tdmi.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/arm920-run.ini (from tester/rtems/testing/bsps/arm920-run.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/arm920.ini (from tester/rtems/testing/bsps/arm920.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/armcortexa9-run.ini (from tester/rtems/testing/bsps/armcortexa9-run.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/armcortexa9.ini (from tester/rtems/testing/bsps/armcortexa9.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/beagleboardxm.ini (from tester/rtems/testing/bsps/beagleboardxm.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/beagleboneblack.ini (from tester/rtems/testing/bsps/beagleboneblack.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/bf537Stamp-run.ini (from tester/rtems/testing/bsps/bf537Stamp-run.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/bf537Stamp.ini (from tester/rtems/testing/bsps/bf537Stamp.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/erc32-run.ini (from tester/rtems/testing/bsps/erc32-run.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/erc32-sis.ini (from tester/rtems/testing/bsps/erc32-sis.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/erc32.ini (from tester/rtems/testing/bsps/erc32.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/generic_or1k.ini (from tester/rtems/testing/bsps/generic_or1k.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/h8sxsim-run.ini (from tester/rtems/testing/bsps/h8sxsim-run.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/h8sxsim.ini (from tester/rtems/testing/bsps/h8sxsim.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/imx7.ini (from tester/rtems/testing/bsps/imx7.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/jmr3904-run.ini (from tester/rtems/testing/bsps/jmr3904-run.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/jmr3904.ini (from tester/rtems/testing/bsps/jmr3904.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/leon2-run.ini (from tester/rtems/testing/bsps/leon2-run.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/leon2-sis.ini (from tester/rtems/testing/bsps/leon2-sis.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/leon2.ini (from tester/rtems/testing/bsps/leon2.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/leon3-run.ini (from tester/rtems/testing/bsps/leon3-run.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/leon3-sis.ini (from tester/rtems/testing/bsps/leon3-sis.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/leon3-tsim-cmds (from tester/rtems/testing/bsps/leon3-tsim-cmds)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/leon3.ini (from tester/rtems/testing/bsps/leon3.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/leon3_tsim-run.ini (from tester/rtems/testing/bsps/leon3_tsim-run.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/leon3_tsim.ini (from tester/rtems/testing/bsps/leon3_tsim.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/lm32_evr_gdbsim-device-tree (from tester/rtems/testing/bsps/lm32_evr_gdbsim-device-tree)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/lm32_evr_gdbsim-run.ini (from tester/rtems/testing/bsps/lm32_evr_gdbsim-run.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/lm32_evr_gdbsim.ini (from tester/rtems/testing/bsps/lm32_evr_gdbsim.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/m32csim-run.ini (from tester/rtems/testing/bsps/m32csim-run.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/m32csim.ini (from tester/rtems/testing/bsps/m32csim.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/mcf5235.ini (from tester/rtems/testing/bsps/mcf5235.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/pc.ini (from tester/rtems/testing/bsps/pc.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/psim-device-tree (from tester/rtems/testing/bsps/psim-device-tree)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/psim-run.ini (from tester/rtems/testing/bsps/psim-run.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/psim.ini (from tester/rtems/testing/bsps/psim.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/qoriq_e500.ini (from tester/rtems/testing/bsps/qoriq_e500.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/qoriq_e6500_32.ini (from tester/rtems/testing/bsps/qoriq_e6500_32.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/qoriq_e6500_64.ini (from tester/rtems/testing/bsps/qoriq_e6500_64.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/realview_pbx_a9_qemu.ini (from tester/rtems/testing/bsps/realview_pbx_a9_qemu.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/riscv64_generic.ini (from tester/rtems/testing/bsps/riscv64_generic.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/riscv64_generic.mc (from tester/rtems/testing/bsps/riscv64_generic.mc)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/riscv_generic.ini (from tester/rtems/testing/bsps/riscv_generic.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/riscv_generic.mc (from tester/rtems/testing/bsps/riscv_generic.mc)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/simsh1-run.ini (from tester/rtems/testing/bsps/simsh1-run.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/simsh1.ini (from tester/rtems/testing/bsps/simsh1.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/simsh2-run.ini (from tester/rtems/testing/bsps/simsh2-run.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/simsh2.ini (from tester/rtems/testing/bsps/simsh2.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/simsh2e-run.ini (from tester/rtems/testing/bsps/simsh2e-run.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/simsh2e.ini (from tester/rtems/testing/bsps/simsh2e.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/simsh4-run.ini (from tester/rtems/testing/bsps/simsh4-run.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/simsh4.ini (from tester/rtems/testing/bsps/simsh4.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/sis-run.ini (from tester/rtems/testing/bsps/sis-run.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/sis.ini (from tester/rtems/testing/bsps/sis.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/v850e1sim-run.ini (from tester/rtems/testing/bsps/v850e1sim-run.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/v850e1sim.ini (from tester/rtems/testing/bsps/v850e1sim.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/v850e2sim-run.ini (from tester/rtems/testing/bsps/v850e2sim-run.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/v850e2sim.ini (from tester/rtems/testing/bsps/v850e2sim.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/v850e2v3sim-run.ini (from tester/rtems/testing/bsps/v850e2v3sim-run.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/v850e2v3sim.ini (from tester/rtems/testing/bsps/v850e2v3sim.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/v850esim-run.ini (from tester/rtems/testing/bsps/v850esim-run.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/v850esim.ini (from tester/rtems/testing/bsps/v850esim.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/v850essim-run.ini (from tester/rtems/testing/bsps/v850essim-run.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/v850essim.ini (from tester/rtems/testing/bsps/v850essim.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/v850sim-run.ini (from tester/rtems/testing/bsps/v850sim-run.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/v850sim.ini (from tester/rtems/testing/bsps/v850sim.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/xilinx_zynq_a9_qemu.ini (from tester/rtems/testing/bsps/xilinx_zynq_a9_qemu.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/xilinx_zynq_a9_qemu_smp.ini (from tester/rtems/testing/bsps/xilinx_zynq_a9_qemu_smp.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/xilinx_zynq_zc706.ini (from tester/rtems/testing/bsps/xilinx_zynq_zc706.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/xilinx_zynq_zc706_qemu.ini (from tester/rtems/testing/bsps/xilinx_zynq_zc706_qemu.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/bsps/xilinx_zynq_zedboard.ini (from tester/rtems/testing/bsps/xilinx_zynq_zedboard.ini)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/console.cfg (from tester/rtems/testing/console.cfg)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/defaults.mc (from tester/rtems/testing/defaults.mc)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/gdb.cfg (from tester/rtems/testing/gdb.cfg)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/qemu.cfg (from tester/rtems/testing/qemu.cfg)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/run.cfg (from tester/rtems/testing/run.cfg)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/spike.cfg (from tester/rtems/testing/spike.cfg)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/testing.mc (from tester/rtems/testing/testing.mc)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/testing/tftp.cfg (from tester/rtems/testing/tftp.cfg)
+ install /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/tester/rtems/version.cfg (from tester/rtems/version.cfg)
'install' finished successfully (0.391s)
+ echo ==> %clean:
==> %clean:
copy: /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter => /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-peter/5/rtems-arm
reporting: tools/rtems-tools-5-1.cfg -> rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1.txt
making dir: /home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1-root-peter/home/peter/development/rtems/5/share/rtems/rsb
reporting: tools/rtems-tools-5-1.cfg -> rtems-tools-25863503edb513e7501481ff2074c02bf219f519-1.xml
config: tools/rtems-kernel-5.cfg
package: arm-rtems5-kernel-5-1
script: 1: #!/bin/sh
script: 2: # ___build_pre in as set up in defaults.py
script: 3: # Save the original path away.
script: 4: export SB_ORIG_PATH=${PATH}
script: 5: # Directories
script: 6: SB_PREFIX="/home/peter/development/rtems/5"
script: 7: SB_PREFIX_CLEAN=$(echo "/home/peter/development/rtems/5" | /bin/sed -e 's/^\///')
script: 8: SB_SOURCE_DIR="/home/peter/development/rtems/src/rtems-source-builder/rtems/sources"
script: 9: SB_BUILD_DIR="/home/peter/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems5-kernel-5-1"
script: 10: # host == build, use build; host != build, host uses host and build uses build
script: 11: SB_HOST_CPPFLAGS=""
script: 12: SB_HOST_CFLAGS="-O2 -pipe "
script: 13: SB_HOST_CXXFLAGS="-O2 -pipe "
script: 14: SB_HOST_LDFLAGS=" -L/home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-peter/5/rtems-arm/${SB_PREFIX_CLEAN}/lib"
script: 15: SB_BUILD_CFLAGS="-O2 -pipe -I/home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-peter/5/rtems-arm/${SB_PREFIX_CLEAN}/include"
script: 16: SB_BUILD_CXXFLAGS="-O2 -pipe -I/home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-peter/5/rtems-arm/${SB_PREFIX_CLEAN}/include"
script: 17: SB_BUILD_LDFLAGS=" -L/home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-peter/5/rtems-arm/${SB_PREFIX_CLEAN}/lib"
script: 18: SB_CFLAGS="${SB_BUILD_CFLAGS} "
script: 19: SB_CXXFLAGS="${SB_BUILD_CXXFLAGS} "
script: 20: SB_ARCH="x86_64"
script: 21: SB_OS="linux"
script: 22: export SB_SOURCE_DIR SB_BUILD_DIR SB_ARCH SB_OS
script: 23: export SB_HOST_CPPFLAGS SB_HOST_CFLAGS SB_HOST_CXXFLAGS SB_HOST_LDFLAGS
script: 24: export SB_BUILD_CFLAGS SB_BUILD_CXXFLAGS SB_BUILD_LDFLAGS
script: 25: export SB_CFLAGS SB_CXXFLAGS
script: 26: # Documentation
script: 27: SB_DOC_DIR="/home/peter/development/rtems/5/share/doc"
script: 28: export SB_DOC_DIR
script: 29: # Packages
script: 30: SB_PACKAGE_NAME="arm-rtems5-kernel-5-1"
script: 31: SB_PACKAGE_BUILDNAME="arm-rtems5-kernel-5-1"
script: 32: SB_PACKAGE_VERSION="5"
script: 33: SB_PACKAGE_RELEASE="1"
script: 34: export SB_PACKAGE_NAME SB_PACKAGE_VERSION SB_PACKAGE_RELEASE
script: 35: # Build directories
script: 36: export SB_PREFIX
script: 37: SB_BUILD_DIR="/home/peter/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems5-kernel-5-1"
script: 38: SB_BUILD_ROOT="/home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/arm-rtems5-kernel-5-1-root-peter"
script: 39: SB_BUILD_ROOT_BINDIR="/home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/arm-rtems5-kernel-5-1-root-peter/${SB_PREFIX_CLEAN}/bin"
script: 40: export SB_BUILD_ROOT SB_BUILD_DIR SB_BUILD_ROOT_BINDIR
script: 41: SB_BUILD_CXC_DIR="/home/peter/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems5-kernel-5-1-cxc"
script: 42: SB_BUILD_CXC_ROOT="/home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/arm-rtems5-kernel-5-1-peter-cxc"
script: 43: SB_BUILD_CXC_ROOT_BINDIR="/home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/arm-rtems5-kernel-5-1-peter-cxc/${SB_PREFIX_CLEAN}/bin"
script: 44: export SB_BUILD_CXC_ROOT SB_BUILD_CXC_DIR SB_BUILD_CXC_ROOT_BINDIR
script: 45: SB_TMPROOT="/home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-peter/5/rtems-arm"
script: 46: SB_TMPPREFIX="/home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-peter/5/rtems-arm/${SB_PREFIX_CLEAN}"
script: 47: SB_TMPBINDIR="/home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-peter/5/rtems-arm/${SB_PREFIX_CLEAN}/bin"
script: 48: export SB_TMPROOT SB_TMPPREFIX SB_TMPBINDIR
script: 49: SB_TMPCXCROOT="/home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-peter/5/rtems-arm"
script: 50: SB_TMPCXCPREFIX="/home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-peter-cxc/5/rtems-arm/${SB_PREFIX_CLEAN}"
script: 51: SB_TMPCXCBINDIR="/home/peter/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-peter-cxc/5/rtems-arm/${SB_PREFIX_CLEAN}/bin"
script: 52: export SB_TMPCXCROOT SB_TMPCXCPREFIX SB_TMPCXCBINDIR
script: 53: # Extra path support
script: 54: SB_EXTRAPATH="/home/peter/development/rtems/src/rtems-source-builder/source-builder"
script: 55: # The compiler flags
script: 56:
script: 57:
script: 58: export CFLAGS_FOR_TARGET
script: 59: export CXXFLAGS_FOR_TARGET
script: 60: # Set up the path. Put the CXC path first.
script: 61: if test -n "${SB_TMPBINDIR}" ; then
script: 62: PATH="${SB_TMPBINDIR}:$PATH"
script: 63: fi
script: 64: if test -n "${SB_TMPCXCBINDIR}" ; then
script: 65: PATH="${SB_TMPCXCBINDIR}:$PATH"
script: 66: fi
script: 67: if test -n "${SB_EXTRAPATH}" ; then
script: 68: PATH="${SB_EXTRAPATH}:$PATH"
script: 69: fi
script: 70:
script: 71:
script: 72: export PATH
script: 73: # Default environment set up.
script: 74: LANG=C
script: 75: export LANG
script: 76: unset DISPLAY || :
script: 77: umask 022
script: 78: cd "/home/peter/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems5-kernel-5-1"
script: 79: echo "=> arm-rtems5-kernel-5-1:"
script: 80: echo "==> %prep:"
script: 81: source_dir_rtems="rtems-5"
source setup: arm-rtems5-kernel-5-1: source rtems -q -c -n arm-rtems5-kernel-5-1-5
making dir: /home/peter/development/rtems/src/rtems-source-builder/rtems/sources/git
git: reset: git://git.rtems.org/rtems.git
git: checkout: git://git.rtems.org/rtems.git => 5
error: git command failed (/usr/bin/git): 1
