Raspberry Pi Rtems-Graphical-Toolkit
Mikhail Svetkin mikhail.svetkin at gmail.com
Mon May 21 17:37:12 UTC 2018
May be RTEMS can support only SPI, I2C input devices?
If somebody want to use USB input devices, they will use RTEMS LIBBSD.
Best regards,
Mikhail
On 21 May 2018 at 18:59, Joel Sherrill <joel at rtems.org> wrote:
> On Mon, May 21, 2018 at 11:48 AM, Kirspel, Kevin <Kevin-Kirspel at idexx.com>
> wrote:
>> I think that is doable for the frame buffer and non-USB touch screen,
>> mouse, and keyboard drivers.  The main problem would be the USB mouse,
>> keyboard, and touch screen drivers.  RTEMS uses LIBBSD for the USB stack.
> Posting inline below
>> Kevin Kirspel
>> Electrical Engineer - Sr. Staff
>> Idexx Roswell
>> 235 Hembree Park Drive
>> <https://maps.google.com/?q=235+Hembree+Park+Drive+%0D%0A+Roswell+GA+30076&entry=gmail&source=g>
>> Roswell GA 30076
>> Tel: (770)-510-4444 ext. 81642
>> Direct: (770)-688-1642
>> Fax: (770)-510-4445
>> *From:* users [mailto:users-bounces at rtems.org] *On Behalf Of *Mikhail
>> Svetkin
>> *Sent:* Monday, May 21, 2018 12:35 PM
>> *To:* Kirspel, Kevin <Kevin-Kirspel at idexx.com>
>> *Cc:* users at rtems.org; Emre Cetin <hsnemrecetin at gmail.com>
>> *Subject:* Re: Raspberry Pi Rtems-Graphical-Toolkit
>> So the minimal example of Qt Widgets + RTEMS LIBBSD + EVDEV will be ~24MB.
>> It is pretty big. If RTEMS has support of EVDEV or libinput it will be
>> only ~9MB.
>> Qt does not require MMAP, only LinuxFB plugin. I wrote my own QPA plugin
>> and it does not need MMAP.
>> Best regards,
>> Mikhail
>> On 21 May 2018 at 17:42, Kirspel, Kevin <Kevin-Kirspel at idexx.com> wrote:
>> To give a little background on this subject, the current support in RTEMS
>> LIBBSD for the EVDEV input system was motivated by the following:
>> - Add a “rtems-arm-4.12-gcc” platform to QT.  This allows you to
>> configure QT with RTEMS compilers and libraries.
>> - Use QT LinuxFB plugin as is for graphics output and system input.
>> The QT LinuxFB plugin supports the following input systems: libinput,
>> tslib, and EVDEV.  I choose EVDEV because it is supported by LIBBSD.
>> As a quick indication of footprint, the EVDEV test in the RTEMS LIBBSD
>> test suite is ~4 times the size of the hello world test.  I compiled
>> against the xilinx_zynq_a9_qemu BSP but the results were similar to my
>> custom LPC3250 BSP.  The hello world test is ~4MB.  The EVDEV test is
>> ~15MB.  The EVDEV test pulls in the USB keyboard and mouse drivers.  This
>> is where most of the footprint increase comes from.  The EVDEV code itself
>> is pretty small.  The frame buffer and touch drivers are also small.
>> That seems large for the normal hello world. Is that the file size or
> size reported by "arm-rtems5-size"? I would expect something under 256K no
> matter how complex the BSP is. It is often under 48K.
> Again is the EVDEV size, file size or real code size?
> I agree that having a USB keyboard and mouse requires the FreeBSD stack
> and that has code but that much?
>> The frame buffer device in RTEMS is not compatible with QT but it is not
>> far off.  QT expects the following Linux headers: “linux/fb.h”,
>> “linux/kd.h”, and “sys/kd.h”.  I had ported the Linux headers and placed
>> them under the “dev/include/linux” and “dev/include/linux/sys” directories
>> in the RTEMS source tree (not currently in the tree because the patches
>> were rejected).  QT also expects the frame buffer device to support the
>> MMAP device handler.  This was added to Gedare’s MMAP work but as Sebastian
>> pointed out it does not follow the design module.  This probably needs to
>> be dealt with at some point.
>> Right now, the only example on how to use EVDEV is in the LIBBSD test
>> suite (evdev01).  I guess the QT source can also be used as an example.
>> Kevin Kirspel
>> Idexx Roswell
>> <https://urldefense.proofpoint.com/v2/url?u=https-3A__maps.google.com_-3Fq-3D235-2BHembree-2BPark-2BDrive-2B-250D-250A-2BRoswell-2BGA-2B30076-26entry-3Dgmail-26source-3Dg&d=DwMFaQ&c=2do6VJGs3LvEOe4OFFM1bA&r=dbavT-WIJ4nBfQFKYnKdAD52Vyq3ZXSzrL9TAm21lZI&m=pNtc9XwM_Um_y7szn11M51nwp2ESm43_FnaEfLoDrVE&s=4DbjexY91IzNSksLounr94j_irJaI8pnAqf29Wc2q6g&e=>
>> Roswell GA 30076
>> Fax: (770)-510-4445
>> *From:* Joel Sherrill [mailto:joel at rtems.org]
>> *Sent:* Monday, May 21, 2018 9:10 AM
>> *Cc:* Chris Johns <chrisj at rtems.org>; Mikhail Svetkin <
>> mikhail.svetkin at gmail.com>; users at rtems.org; Emre Cetin <
>> On Mon, May 21, 2018, 7:52 AM Kirspel, Kevin <Kevin-Kirspel at idexx.com>
>> wrote:
>> RTEMS LIBBSD has support for EVDEV which is a standard API for keyboard,
>> mouse, and touchscreen.  Is it the best choice, I don't know.  Maybe a
>> better question is "What standard input system should RTEMS support?".
>> That's the question.
>> Using the FreeBSD support has a number of advantages but I admit that I
>> didn't know that support was in place. I have no idea what minimum
>> footprint using that implies even if you don't use the TCP IP stack.
>> In the cpukit there has long been support for a frame buffer device
>> framework and a mouse input parsing library. I expect the FreeBSD support
>> comes with specific device support that this is weak on.
>> But footprint is important. Any idea how large a simple non-networked
>> example would be with the FreeBSD code as a base?
>> And we need examples and howtos. If I didn't know about it, it isn't
>> reasonable to expect someone new to find it. :(
>> --joel
>> Kevin Kirspel
>> Idexx Roswell
>> <https://urldefense.proofpoint.com/v2/url?u=https-3A__maps.google.com_-3Fq-3D235-2BHembree-2BPark-2BDrive-2B-250D-250ARoswell-2BGA-2B30076-26entry-3Dgmail-26source-3Dg&d=DwMFaQ&c=2do6VJGs3LvEOe4OFFM1bA&r=dbavT-WIJ4nBfQFKYnKdAD52Vyq3ZXSzrL9TAm21lZI&m=pNtc9XwM_Um_y7szn11M51nwp2ESm43_FnaEfLoDrVE&s=kmmgT8zilp8a-ibdkTczWMS4Xv4e9XPymmkZcbMl88A&e=>
>> Roswell GA 30076
>> Fax: (770)-510-4445
>> -----Original Message-----
>> From: Chris Johns [mailto:chrisj at rtems.org]
>> Sent: Sunday, May 20, 2018 5:51 PM
>> To: Mikhail Svetkin <mikhail.svetkin at gmail.com>; Kirspel, Kevin <
>> Cc: users at rtems.org; Emre Cetin <hsnemrecetin at gmail.com>
>> Subject: Re: Raspberry Pi Rtems-Graphical-Toolkit
>> On 16/5/18 9:39 pm, Mikhail Svetkin wrote:
>> > I think it will be very good if RTEMS has some kind of input subsystem
>> > (keyboards,  mouse, touchscreen) with standard API.
>> Do you have an example standard API what would be suitable?
>> Chris
>> users mailing list
>> users at rtems.org
>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rtems.org_mailman_listinfo_users&d=DwMFaQ&c=2do6VJGs3LvEOe4OFFM1bA&r=HDiJ93ANMEQ32G5JGdpyUxbdebuwKHBbeiHMr3RbR74&m=jEekgiYvWnHgpNcfJlW6X1x8cM7ASFHxgW29on-cOD8&s=fUSHJbQR5SY1RqkgGuU3VIaH-gUdvMJCG2Pr-VhNXNQ&e=>
>> users mailing list
>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20180521/f3948024/attachment-0002.html>
