rsb problem with python
Slide slide.o.mix at gmail.com
Thu May 31 17:42:16 UTC 2018
Hi Pete,
This is the command I used
git config url.https://git.rtems.org/.insteadOf git://git.rtems.org/
If you want to make the configuration global (not per repo) you can use the
following
git config --global url.https://git.rtems.org/.insteadOf git://
git.rtems.org/
Thanks,
Alex
On Wed, May 30, 2018 at 6:35 PM Siddons, David <siddons at bnl.gov> wrote:
> Hi Alex,
>    I'm pretty git-ignorant. How do I use your command git config url
> https://git.rtems.org/ <https://git.rtems.org/rtems.insteadOf> ? If I
> just execute that it says "error: key does not contain a section: url".
> Pete.
> *From:* Slide [slide.o.mix at gmail.com]
> *Sent:* Wednesday, May 30, 2018 5:32 PM
> *To:* Siddons, David
> *Cc:* users at rtems.org
> *Subject:* Re: rsb problem with python
> Hi Pete,
> That's something I would like to know as well. When something fails after
> building GCC, it would be nice to not have to rebuild GCC the next time. I
> don't know enough about the RTEMS build process at this point to be able to
> help you on that part.
> Regards,
> Alex
> On Wed, May 30, 2018 at 2:19 PM D Peter Siddons <siddons at bnl.gov> wrote:
>> Hi Alex,
>>  OK, thanks. I'll try that tonight. Maybe it will work as-is from my home
>> network.
>> Is there a way to skip parts of the build? The first part is very slow.
>> Pete.
>> On 05/30/2018 04:59 PM, Slide wrote:
>> Hi Pete,
>> I also ran into a similar failure :-) I had to use:
>> git config url https://git.rtems.org/.insteadOf
>> <https://git.rtems.org/rtems.insteadOf> git://git.rtems.org
>> My IT blocks the git protocol port on our company firewall. You can make
>> this global by adding --global after config in the command above
>> Alex
>> On Wed, May 30, 2018 at 12:58 PM D Peter Siddons <siddons at bnl.gov> wrote:
>>> Hi Gedare,
>>>     That worked, i.e. commenting out the miniconda path and installing
>>> python3.6-dev. So on to the next stop :)
>>> Processing stopped when building the kernel. At the end of the log file
>>> I see:
>>> script: 72: export PATH
>>> script: 73: # Default environment set up.
>>> script: 74: LANG=C
>>> script: 75: export LANG
>>> script: 76: unset DISPLAY || :
>>> script: 77: umask 022
>>> script: 78: cd "/home/peter/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems5-kernel-5-1"
>>> script: 79: echo "=> arm-rtems5-kernel-5-1:"
>>> script: 80: echo "==> %prep:"
>>> script: 81: source_dir_rtems="rtems-5"
>>> source setup: arm-rtems5-kernel-5-1: source rtems -q -c -n arm-rtems5-kernel-5-1-5
>>> making dir: /home/peter/development/rtems/src/rtems-source-builder/rtems/sources/git
>>> git: reset: git://git.rtems.org/rtems.git
>>> git: checkout: git://git.rtems.org/rtems.git => 5
>>> error: git command failed (/usr/bin/git): 1
>>> I have attached the entire report, FYI. Does this mean that git could
>>> not supply the source?
>>> Pete.
>>> On 05/30/2018 01:01 PM, Gedare Bloom wrote:
>>> Pete,
>>> On Wed, May 30, 2018 at 12:19 PM, D Peter Siddons <siddons at bnl.gov> <siddons at bnl.gov> wrote:
>>> Hi Gedare,
>>>    I didn't get your earlier email (?), but the answer is:
>>> /home/peter/miniconda3/bin/python3.6
>>> so the only way I have 3.6 is through miniconda. Maybe it expects
>>> /usr/bin/python3.6?
>>> Odd that my email didn't come through to you. Anyway, since 'which'
>>> finds it, the paths seem correct. Alex' suggestion to install the
>>> development library is a good one however. I have had problems in the
>>> past with mixed Anaconda python installations and Ubuntu distro ones.
>>> I (like you) had the conda in a subdir of my home directory though, so
>>> I found it was easiest for me to just disable the conda paths e.g. by
>>> commenting out
>>> #export PATH="/home/gedare/anaconda3/bin:$PATH"
>>> in my .bashrc was sufficient for me
>>> Then, I could install/use the Ubuntu distributions Python2/3 packages
>>> without conflicts.
>>> Gedare
>>> Pete.
>>> On 05/30/2018 12:12 PM, Gedare Bloom wrote:
>>> Alex,
>>> Yes that also makes sense, thank you. Usually, I've seen that problem
>>> manifest as missing Python.h, but error messages can be vague and
>>> inconsistent. :)
>>> On Wed, May 30, 2018 at 11:49 AM, Slide <slide.o.mix at gmail.com> <slide.o.mix at gmail.com> wrote:
>>> I ran into a similar issue and the way I solved it was by installing the
>>> -dev package for Python. For me this was libpython3-dev on Ubuntu. I'm not
>>> sure how to do that with the Anaconda installation, but this may help point
>>> you in the right direction.
>>> Regards,
>>> Alex
>>> On Wed, May 30, 2018 at 6:57 AM Gedare Bloom <gedare at rtems.org> <gedare at rtems.org> wrote:
>>> Pete,
>>> Do you get anything with:
>>> $ which python3.6
>>> Probably, it is looking for that invocation command. I ought to try
>>> this, because my Ubuntu does not ship with python3.6 I know, so maybe
>>> it breaks too... hm
>>> On Mon, May 28, 2018 at 6:23 PM, Siddons, David <siddons at bnl.gov> <siddons at bnl.gov> wrote:
>>> Hi Amaan,
>>>    Actually,  /home/peter/miniconda3/bin/python is a soft link to
>>> /home/peter/miniconda3/bin/python3.6 already! Does rsb not follow links?
>>> Pete.
>>> ________________________________
>>> From: Amaan Cheval [amaan.cheval at gmail.com]
>>> Sent: Monday, May 28, 2018 6:05 PM
>>> To: Siddons, David
>>> Cc: users at rtems.org
>>> Subject: Re: rsb problem with python
>>> Hey David!
>>> It looks to me like Anaconda doesn't install the "alias" binaries
>>> specifying
>>> the version (for eg. both "python" and "python3.6"). I believe the fix
>>> in
>>> your case should be as simple as copying your existing binary with the
>>> following command:
>>> cp /home/peter/miniconda3/bin/python
>>> On Tue, May 29, 2018, 3:28 AM Siddons, David <siddons at bnl.gov> <siddons at bnl.gov> wrote:
>>> While building rsb for arm-rtems I got this problem:
>>> checking for python... /home/peter/miniconda3/bin/python
>>> checking for python3.6... no
>>> configure: error: python is missing or unusable
>>> Makefile:9095: recipe for target 'configure-gdb' failed
>>> make[1]: *** [configure-gdb] Error 1
>>> make[1]: Leaving directory
>>> '/home/peter/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems5-gdb-8.0.1-x86_64-linux-gnu-1/build'
>>> Makefile:848: recipe for target 'all' failed
>>> make: *** [all] Error 2
>>> shell cmd failed: /bin/sh -ex
>>> /home/peter/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems5-gdb-8.0.1-x86_64-linux-gnu-1/doit
>>> error: building
>>> arm-rtems5-gdb-8.0.1-x86_64-linux-gnu-1peter at peter-Latitude-E7240:~/development/rtems/src/rtems-source-builder/rtems$
>>> I am running Ubuntu:
>>> peter at peter-Latitude-E7240:/etc$ lsb_release -a
>>> LSB Version:
>>> core-9.20160110ubuntu0.2-amd64:core-9.20160110ubuntu0.2-noarch:printing-9.20160110ubuntu0.2-amd64:printing-9.20160110ubuntu0.2-noarch:security-9.20160110ubuntu0.2-amd64:security-9.20160110ubuntu0.2-noarch
>>> Distributor ID: Ubuntu
>>> Description:    Ubuntu 16.04.4 LTS
>>> Release:        16.04
>>> Codename:       xenial
>>> then:
>>> python -V
>>> Python 3.6.1 :: Continuum Analytics, Inc.
>>> This comes from an Anaconda installation. If I remove the path entry
>>> which
>>> causes that I get python 2.7, which is the default Ubuntu 16.04
>>> version. Do
>>> I need to install Python 3.6?
>>> Pete.
>>> users mailing listusers at rtems.orghttp://lists.rtems.org/mailman/listinfo/users
>>> D. Peter Siddons
>>> Detector Development Group Leader
>>> Photon Science Division, NSLS-II,
>>> Bldg. 535B
>>> Brookhaven National Laboratory
>>> Upton, NY 11973
>>> email: siddons at bnl.gov
>>> Phone: (631) 344-2738
>>> D. Peter Siddons
>>> Bldg. 535B
>>> Upton, NY 11973
>> D. Peter Siddons
>> Bldg. 535B
>> Upton, NY 11973
URL: <http://lists.rtems.org/pipermail/users/attachments/20180531/95a7b310/attachment-0002.html>
